*** official statement about sd card slot problem *** After making a LOT of tests with a LOT of Boxes for the past few days, I have come to the conclusion that Boxes who cannot read SD Card are most probably caused by BOX FIRMWARE PROBLEM. Currently, I am making the new Firmware for all boxes to make it work with ALL BOXES. The Firmware will be finished within 48-72 hours. There are currently BETA Testers using this "TEST FIRMWARE" and so far 2 of them already confirmed that this "TEST FIRMWARE" is working. The problem however with the current "TEST FIRMWARE" is that the FBUS Flashing is not stable because this "TEST FIRMWARE" is still in its early BETA STAGE. If You want to TEST the Firmware, you need to contact me in Sonork 100.40000 Beta TESTING is OPEN to anyone,, but PLEASE KEEP IN MIND THAT FBUS FLASHING IS DISABLED IN THE BETA FIRMWARE!!! So it will be better to wait 72 hours for the STABLE FIRMWARE. I Apologize for the inconvenience this SD Card Slot has caused, but rest assured that I am doing everything I can to get this problem rectified. B.R. X-Shadow |
Yes it works ( read SD card after flash new firmware to ATF modified box ) Thanks 2 ATF team http://i1239.photobucket.com/albums/...World/Read.jpg |
How to Flash new firmware to your Modified ATF box ? Remember :- This is not final release only for test purpose , Fbus flashing will not stable in this firmware . Quote:
Disconnect all BOX n Dongle from your PC Close ATF Program if it running Connect ATF Box Unzip the Firmware pack Double click " test_firmware.bat " It will take 5 - 7 Min You can back to your original firmware by ATF tool > Restore Box ( Select Modified PCB ) |
Before: Quote:
Box PCB v1.3_2010. Before ATF Detection ERROR: Code: ERROR: Failed to Reset Micro SD Card... Password Protected MMC card: Code: Card Reset Done! Code: Card Reset Done! |
what about ATF Lightning ? we need this solution |
Good Luck. |
thats great move by ATF team. we are waiting for bug free ATF firmware, Thanks |
Yes we are waiting................ |
my box normal pcb, working with "test normal pcb firmware" and after check (resolder) this area: http://img827.imageshack.us/img827/3...dslotcheck.jpghttp://img717.imageshack.us/img717/7...2030600003.jpg http://img580.imageshack.us/img580/1...picture1cv.png |
Contact me on Messenger :) |
Thank's to atf team & srinibas for test firmware............ now my box mmc option is working well :) http://gsmcommunication.co.in/image/?di=1313310135741 |
