Please Help me Nokia E5 only Vibrating flashing ok but not power on Please Help me Nokia E5 only Vibrating flashing ok but not power on Code: 13:59:50 : Number of Image Files: 4 Please Help me Nokia E5 only Vibrating flashing ok but not power on Im waiting Reply Thanks... |
@I_PHONE Tell us how its become like this?? means after flash r u received n this condition. read 1st the full pm and rpl. 2nd flash with same product code. post the result. bro :) |
Download flash file with exact to its product code and flash with it... Hope u will get success... |
how can we found product code explan me plz |
remove battery, you can see your product code in imei label |
@I_PHONE Since your phone can get LOCAL MODE, read phone's FULL PM and Backup RPL of this phone. After try to downgrade the phone to lower version. How to: http://forum.gsmhosting.com/vbb/f609...cable-1461938/ BR |
sometimes, "vibration only" comes from hardware. If flashing goes fine & software program detects the phone after flashing in TEST MODE, but it is still only vibrates, you can check the LCD operating voltages (VAUX1 & VIO) on LCD socket. If u can not find any of these voltages at the LCD socket, it is time to check L2420(VAUX1 comes through this) & R2423 (VIO comes through this) http://i632.photobucket.com/albums/u...ps723a3f06.jpg Good Luck!! |
thanksss....its working |
its working thanks brother |
Sorry bro..!! Image is removed... please upload again |
[Symbian flashing] I had the same problem and I've solved: First change the product code of the phone e.g. with Nemesis, it is going to do it, beside it's dead, change it only if you don't have the approriate product code of the fw and phone. Also the SW version and RM has to fit. Backup your phone memory and take out the memory card. If the flashing runs till the end without visible problem with Phoenix, but it's with Custom fw and the phone is still dead, the solution is the Original fw: delete APE and mem. card content (a flashing file signed with red), leave the Image, Content, PPM-s, Refurbish it and the phone is going to turn on. |
