02-16-2010, 15:02 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: inside USB cable Age: 41
Member: 128122 Status: Offline Thanks Meter: 256 | Post here all successfuly flashed, unlocked and repaired phones with ATF software. Also bugs you found. Here is my test unit I test a unit 6680 Flashing in other tool/box but same result NOKIA Only. And here I flashed it using ATF. Same Files used: Look my Logs. Code: AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : aybyd aybyd aybyd BOX ACTIVATED DDR DELAY : 01 INIT : OK Changing MODE : FLASH Processing Image File : C:\Documents and Settings\Administrator\My Documents\6680\rm36_5.050407_b5.c0r CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0003192101002000 > 000C192101002000 > 0003192101002100 > 000C192101002100 > 0003192101002200 > 000C192101002200 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP1610 GBBM-1.8.1 ALG APE Supported Hardwares : > 17100701 > 17100702 Number of Blocks : 832 Entry Point: 0x0100 Page Format : -1 MAX PAGE : 0x00008000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417216 (0x40) bytes returned Number of Sub Blocks 12 (0x0C) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 17100701 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : C4C283AD ID DWORD 1 : 8115C574 ID DWORD 2 : 65CBC331 ID DWORD 3 : 80B9679C ID DWORD 4 : E89F80D2 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : 2C 05 36 9F 57 CC 3C 4C F9 E7 83 E8 3D 9B 51 2B 00 00 00 00 5 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 1 (01) APE CRC 0 : AB5E4ADB CRC 1 : 27A06946 6 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 000C1921 ID DWORD 4 : 01002100 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 8 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000352 9 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 2360010B ID DWORD 1 : E4D24651 ID DWORD 2 : 0380D762 ID DWORD 3 : CBB15BDD ID DWORD 4 : 1AB9ECB6 10 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 11 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : E9 EF F4 BF AA 53 93 21 7C A6 B1 77 55 FC 3E 14 12 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : F28A211F CRC 1 : AC901AEE Checksum D6 SearchForBootstrap_DCT5.. Boot File MATCH : RAP3Gv2_2nd.fg Boot File - Version : 001.021.000 Boot File - Revision : 0x0000 BB5ProtocolType == : Original MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 2250 -> K8S6415ETB Extended/Fixed ID : 0000 Revision ID : 0121 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 20 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... File MATCH : RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Searching for APE Boot File.. SearchForBootstrap_DCT5... Boot File MATCH : helen3_2nd.fg Boot File - Revision : 0x BB5ProtocolType == : Original TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. APE_CODE_REQUEST_BB5 : 5B 01 24 04 00 00 35 00 A1 SendAPECodeRequest_DCT5 FLS1_NO_ERROR.. ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 02 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : NAND 01 Device Index : 00 Manufacturer Code : 00EC -> SAMSUNG (SEC) Device ID : 0035 -> K5E5657ACB Extended/Fixed ID : 00A5 Revision ID : 00BD 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : APE 01 Device Type : NAND 01 Device Index : 00 Device Contents : 00020000000600000000 Checksum : 00 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 File MATCH : h3_sam_nand_gbbm.fg TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 000F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 01 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 010F72BF9DE5D6711B3B1133EBCAB5914FA419C78D No partition info.... VPP Enabled by Software Using Internal VPP ERASING Skipped ... TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 Processing : rm36_5.050407_b5.c0r Total blocks to write : 832 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> APE Rootkey Hash CERT : KEYS >> APE Rootkey Hash CERT : X-LOADER >> APE Rootkey Hash CERT : PRIMAPP >> APE Rootkey Hash CERT : SOS+LOADER >> APE Rootkey Hash CERT : SOS+XZIP >> APE Rootkey Hash CERT : PASUBTOC >> APE Rootkey Hash CERT : PAPUBKEYS >> APE Rootkey Hash CERT : SOS*CORE ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 01 Device Type : 00 Num Bad Blocks : 009DE5D6 Additional Bad : 001B3B11 Correctable ECC : 00EBCAB5 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:01:01 Making delay between files for 10ms Processing Image File : C:\Documents and Settings\Administrator\My Documents\6680\RM36_5.050407_B5.v37 CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0000000000000000 > 0003192101002000 > 000C192101002000 > 0003192101002100 > 000C192101002100 > 0003192101002200 > 000C192101002200 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 100000Hz APE PHONE Type : BB5 APE ALGORITHM : OMAP1610 GBBM-1.8.1 ALG APE Supported Hardwares : > 17100700 > 17100701 > 17100702 > 17100703 Number of Blocks : 505 Entry Point: 0x0110 Page Format : -1 MAX PAGE : 0x00002000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417216 (0x40) bytes returned Number of Sub Blocks 12 (0x0C) 1 SYSTEM_ASIC_ID 01 Block Length : 5 (05) BB ASIC Index : 1 (01) APE ID DWORD 0 : 17100701 2 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 1 (01) APE Mode Id : 00 3 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 1 (01) APE ID DWORD 0 : C4C283AD ID DWORD 1 : 8115C574 ID DWORD 2 : 65CBC331 ID DWORD 3 : 80B9679C ID DWORD 4 : E89F80D2 4 ROOT_KEY_HASH 14 Block Length : 21 (15) BB ASIC Index : 1 (01) APE Hash : 2C 05 36 9F 57 CC 3C 4C F9 E7 83 E8 3D 9B 51 2B 00 00 00 00 5 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 1 (01) APE CRC 0 : AB5E4ADB CRC 1 : 27A06946 6 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 000C1921 ID DWORD 4 : 01002100 7 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 8 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000352 9 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 2360010B ID DWORD 1 : E4D24651 ID DWORD 2 : 0380D762 ID DWORD 3 : CBB15BDD ID DWORD 4 : 1AB9ECB6 10 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 11 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : E9 EF F4 BF AA 53 93 21 7C A6 B1 77 55 FC 3E 14 12 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : F28A211F CRC 1 : AC901AEE Checksum D6 SearchForBootstrap_DCT5.. Boot File MATCH : RAP3Gv2_2nd.fg Boot File - Version : 001.021.000 Boot File - Revision : 0x0000 BB5ProtocolType == : Original MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 2250 -> K8S6415ETB Extended/Fixed ID : 0000 Revision ID : 0121 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 20 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... File MATCH : RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Searching for APE Boot File.. SearchForBootstrap_DCT5... Boot File MATCH : helen3_2nd.fg Boot File - Revision : 0x BB5ProtocolType == : Original TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. APE_CODE_REQUEST_BB5 : 5B 01 24 04 00 00 35 00 A1 SendAPECodeRequest_DCT5 FLS1_NO_ERROR.. ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000).. MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 02 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : APE 01 Device Type : NAND 01 Device Index : 00 Manufacturer Code : 00EC -> SAMSUNG (SEC) Device ID : 0035 -> K5E5657ACB Extended/Fixed ID : 00A5 Revision ID : 00BD 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : APE 01 Device Type : NAND 01 Device Index : 00 Device Contents : 00020000000600000000 Checksum : 00 SearchForBootstrap_DCT5 : No Error - 0 (0x00) Searching for APE Algorithm File.. SearchForAlgorithm_DCT5 File MATCH : h3_sam_nand_gbbm.fg TransmissionTypeRequest_DCT5.. SuggestedType : 04 DDR & 2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) SendAPECodeRequest_DCT5.. APE Algorithm Sent SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 000F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 01 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 010F72BF9DE5D6711B3B1133EBCAB5914FA419C78D ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x01 APE Device Type : 0x01 NAND Device Index : 0x00 Partition Version : 00010000 Spare : 00000000 Num Partitions : 00000003 Partition 1 ID : 00070000 NBL1 Attribute : 00640000 Start Address : 00000000 Size : 00010000 Partition 2 ID : 01550000 NBL1 Attribute : 00A0C000 Start Address : 00000001 Size : 00010000 Partition 3 ID : 006B0000 NBL1 Attribute : 00EA0000 Start Address : 00000000 Size : 00010000 PARTITION_INFO_REQUEST_BB5 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) VPP Enabled by Software Using Internal VPP ERASING Skipped ... TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 Processing : RM36_5.050407_B5.v37 Total blocks to write : 505 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 2 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 01 Device Type : 01 Device Type : 00 Num Bad Blocks : 009DE5D6 Additional Bad : 001B3B11 Correctable ECC : 00EBCAB5 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:13 Making delay between files for 10ms Rebooting Box ... AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : B57E17A0xxxxxxxxxxxxxxxx (removed serial by frozenice) BOX ACTIVATED DDR DELAY : 01 INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... Waiting for phone to Power On, 8000 ms delay Changing MODE : UART Reading Phone Information... MCU SW version : V 04wk47_m_v14 09-02-06 RM-36 (c) Nokia. HW version : 6021 PCI version : RFIC version : 150a160e DSP version : pb04w47v23 Retu version : 32 Tahvo version : 52 Production serial number : CQC072735 Product code : 0523638 Module code : Basic production code : 0516030 Flash code : Order number : Product specific data : Long production SN : ATO : IMEI plain : 3556xxxxxxxx9 IMEI spare to net : 3A 55 66 04 60 06 88 05 03 2D 27 0C 00 01 53 0C 00 18 00 00 00 17 00 00 00 00 IMEI SV to net : 33 55 66 04 60 06 88 25 F6 Simlock Version : SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task CONFIG KEY: 0000000000000000 PROVIDER KEY: 4402000000000000 Provider : J-phone / Vodaphone Japan ;Japan Counters : 0/3 , 0/10 Block [1] 1:Open Block [2] 1:Open SP Lock Status : Not Locked Look at the Highlighted text. Last edited by frozenice; 02-16-2010 at 20:11. Reason: removed box sn |
The Following 75 Users Say Thank You to dr_aybyd For This Useful Post: |
02-17-2010, 04:04 | #4 (permalink) |
Member: 128122 Status: Offline Thanks Meter: 256 | Another phone repaired Unit: 7210s RM-436 Fault: White Screen Only Settings: Flashing Speed Set to Automatic Done in Flashing.. Here is the logs... Backup RPL: Code: AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : aybyd aybyd aybyd BOX ACTIVATED DDR DELAY : 01 INIT : OK AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417216 (0x40) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0C00010A ID DWORD 1 : 07827C56 ID DWORD 2 : 87D4BA19 ID DWORD 3 : 00D6D6D3 ID DWORD 4 : 7996DDBB 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum E0 SearchForBootstrap_DCT5.. Boot File MATCH : RAP3Gv3_2nd.fg Boot File - Version : 009.011.001 Boot File - Revision : 0x0000 BB5ProtocolType == : Original MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... File MATCH : RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) START READING RPL DATA Reading : NPC OK Reading : VARIANT No VARIANT for this phone / empty Reading : CCC OK Reading : HWC OK FINISHED READING RPL DATA RPL saved to: D:\Advance\AdvanceBox\Nokia\RPL\0C00010A07827C5687D4BA1900D6D6D37996DDBB_63950.rpl Flashing: Code: AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : aybyd aybyd aybyd BOX ACTIVATED DDR DELAY : 01 INIT : OK Changing MODE : FLASH Processing Image File : D:\UFS,JAF, Cyclone Flashfiles\lsd_rm-436_v5.21\rm436__05.21.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1166 Entry Point: 0x5047 Page Format : -1 MAX PAGE : 0x00004000 AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : B57E17A0C7A4ED6DC97700D0 BOX ACTIVATED DDR DELAY : 01 INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417216 (0x40) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0C00010A ID DWORD 1 : 07827C56 ID DWORD 2 : 87D4BA19 ID DWORD 3 : 00D6D6D3 ID DWORD 4 : 7996DDBB 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum E0 SearchForBootstrap_DCT5.. Boot File MATCH : RAP3Gv3_2nd.fg Boot File - Version : 009.011.001 Boot File - Revision : 0x0000 BB5ProtocolType == : Original MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... File MATCH : RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x0036 (54) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x33 (51) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00040000-000BFFFF 3 : 000C0000-0013FFFF 4 : 00140000-0119FFFF 5 : 011A0000-0133FFFF ERASE_REQUEST_BB5 : 5001123300000000000000000006BF000006C00001FFFF00040000000BFFFF000C00000013FFFF001400000119FFFF011A00000133FFFF8C Please wait ERASING......... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:21 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 Processing : rm436__05.21.mcusw Total blocks to write : 1166 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:46 Making delay between files for 10ms Processing Image File : D:\UFS,JAF, Cyclone Flashfiles\lsd_rm-436_v5.21\rm436__05.21.ppm_i CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 473 Entry Point: 0x00B6 Page Format : -1 MAX PAGE : 0x00004000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417216 (0x40) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0C00010A ID DWORD 1 : 07827C56 ID DWORD 2 : 87D4BA19 ID DWORD 3 : 00D6D6D3 ID DWORD 4 : 7996DDBB 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum E0 SearchForBootstrap_DCT5.. Boot File MATCH : RAP3Gv3_2nd.fg Boot File - Version : 009.011.001 Boot File - Revision : 0x0000 BB5ProtocolType == : Original MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... File MATCH : RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01340000-01BDFFFF ERASE_REQUEST_BB5 : 5001120B0000000134000001BDFFFFF0 Please wait ERASING......... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:31 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 Processing : rm436__05.21.ppm_i Total blocks to write : 473 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:18 Making delay between files for 10ms Processing Image File : D:\UFS,JAF, Cyclone Flashfiles\lsd_rm-436_v5.21\rm436__05.21.image_i CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 010C192101013000 > 0103192101003000 > 030C192101033000 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 1424 Entry Point: 0x00C2 Page Format : -1 MAX PAGE : 0x00004000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417216 (0x40) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 030C1921 ID DWORD 4 : 01033000 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 0C00010A ID DWORD 1 : 07827C56 ID DWORD 2 : 87D4BA19 ID DWORD 3 : 00D6D6D3 ID DWORD 4 : 7996DDBB 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 273F6D55 CRC 1 : DFAAF68F Checksum E0 SearchForBootstrap_DCT5.. Boot File MATCH : RAP3Gv3_2nd.fg Boot File - Version : 009.011.001 Boot File - Revision : 0x0000 BB5ProtocolType == : Original MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8982 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 8A31 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 51 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... File MATCH : RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026 No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x0016 (22) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x13 (19) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01BE0000-01F7FFFF 1 : 01F80000-03FBFFFF ERASE_REQUEST_BB5 : 5001121300000001BE000001F7FFFF01F8000003FBFFFF2F Please wait ERASING......... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:03:49 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : -1 Processing : rm436__05.21.image_i Total blocks to write : 1424 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:56 Rebooting Box ... AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : B57E17A0C7A4ED6DC97700D0 BOX ACTIVATED DDR DELAY : 01 INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... Waiting for phone to Power On, 8000 ms delay Changing MODE : UART Reading Phone Information... MCU SW version : V 05.21 20-10-08 RM-436 (c) Nokia HW version : 1001 PCI version : RFIC version : 06540601 DSP version : ICPR72_08w37 Retu version : 15 Tahvo version : 22 Production serial number : DAO863436 Product code : 0566924 Module code : 0203868 Basic production code : 0563951 Flash code : Order number : Product specific data : Long production SN : 0 ATO : IMEI plain : 351xxxxxxxxx0 IMEI spare to net : 3A 15 69 02 13 46 50 08 IMEI SV to net : 33 15 69 02 13 46 50 28 F0 Simlock Version : SIMLOCK SERVER CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked |
The Following 17 Users Say Thank You to dr_aybyd For This Useful Post: |
02-17-2010, 05:48 | #5 (permalink) | ||
Freak Poster Join Date: Nov 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 392166 Status: Offline Thanks Meter: 56 | For the 6680 Quote:
Flashing seems like SUPERMAN is flying? | ||
The Following 7 Users Say Thank You to rontekgsm For This Useful Post: |
02-17-2010, 06:21 | #6 (permalink) |
Freak Poster Join Date: Jan 2010 Location: On UR GF's Azz!
Member: 1219186 Status: Offline Sonork: F_u_c_k_O_f_f Thanks Meter: 19 | whoaaaaaaa! that's fast flashing! if anyone test n97 RM-505 flashing time? it takes a lifetime on jaf etc... plz post here thanks! |
The Following 2 Users Say Thank You to WestGSM™ For This Useful Post: |
02-17-2010, 06:50 | #9 (permalink) |
Temporary banned !! Join Date: Nov 2009 Location: P.H Age: 38
Member: 1151970 Status: Offline Sonork: 100.1597000 Thanks Meter: 378 | here dawonload tool turbu http://advance-box.com/index.php?p=products# |
The Following 6 Users Say Thank You to KIKO_GSM For This Useful Post: |
02-17-2010, 08:44 | #10 (permalink) |
No Life Poster Join Date: Dec 2004 Age: 50
Member: 98139 Status: Offline Thanks Meter: 126 | here is 3110 flashing log Code: AdvanceBox Turbo Flasher Found 21:16:38 : Initialize Device.... 21:16:38 : Init TRY : 1 21:16:38 : Changing Clock to 15mhz.. 21:16:38 : Box Name : AdvanceBox Turbo 21:16:38 : Box Firmware : LogiCore 1.16.10 21:16:38 : Software Version : v2010.0.1.21 21:16:38 : AdvanceBox SN : E727BF7FE74C2B79EF0C3755 21:16:38 : BOX ACTIVATED 21:16:38 : DDR DELAY : 01 21:16:38 : INIT : OK 21:16:38 : 21:16:38 : Changing MODE : FLASH 21:16:38 : Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.mcusw 21:16:39 : CMT Type : BB5 21:16:39 : CMT Algorithm : BB5 ALGORITHM 21:16:39 : CMT Supported Hardwares : 21:16:39 : > 0103192101001101 21:16:39 : > 010C192101001101 21:16:39 : Secondary Sending Speed : 3250000Hz 21:16:39 : Algorithm Sending Speed : 6500000Hz 21:16:39 : Program Sending Speed : 6500000Hz 21:16:39 : Message Reading Speed : 98000Hz 21:16:39 : Number of Blocks : 944 21:16:39 : Entry Point: 0x44FC 21:16:39 : Page Format : -1 21:16:39 : MAX PAGE : 0x00004000 21:16:39 : AdvanceFBox SendBootCodeEx 21:16:39 : InitialiseBootstrap_DCT5 DIR 21:16:39 : BootFlashMode_DCT5 21:16:39 : BootFlashModeDCT5Ex Succeeded First Time 21:16:39 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2118223920 (0x30) bytes returned 21:16:39 : Number of Sub Blocks 7 (0x07) 21:16:39 : 1 SYSTEM_ASIC_ID 01 21:16:39 : Block Length : 21 (15) 21:16:39 : BB ASIC Index : 0 (00) CMT 21:16:39 : ID DWORD 0 : 00000001 21:16:39 : ID DWORD 1 : 00000226 21:16:39 : ID DWORD 2 : 00010006 21:16:39 : ID DWORD 3 : 010C1921 21:16:39 : ID DWORD 4 : 01001101 21:16:39 : 2 ROM_ID 15 21:16:39 : Block Length : 5 (05) 21:16:39 : BB ASIC Index : 0 (00) CMT 21:16:39 : ID DWORD 0 : 00000232 21:16:39 : 3 ROM_ID 15 21:16:39 : Block Length : 5 (05) 21:16:39 : BB ASIC Index : 0 (00) CMT 21:16:39 : ID DWORD 0 : 00000353 21:16:39 : 4 PUBLIC_ID 12 21:16:39 : Block Length : 21 (15) 21:16:39 : BB ASIC Index : 0 (00) CMT 21:16:39 : ID DWORD 0 : 19D00113 21:16:39 : ID DWORD 1 : 10A47C56 21:16:39 : ID DWORD 2 : 4C322332 21:16:39 : ID DWORD 3 : 8219B500 21:16:39 : ID DWORD 4 : 1AEAF1FF 21:16:39 : 5 ASIC_MODE_ID 13 21:16:39 : Block Length : 2 (02) 21:16:39 : BB ASIC Index : 0 (00) CMT 21:16:39 : Mode Id : 00 21:16:39 : 6 ROOT_KEY_HASH 14 21:16:39 : Block Length : 17 (11) 21:16:39 : BB ASIC Index : 0 (00) CMT 21:16:39 : Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 21:16:39 : 7 ROM_ID 15 21:16:39 : Block Length : 9 (09) 21:16:39 : BB ASIC Index : 0 (00) CMT 21:16:39 : CRC 0 : 191EC665 21:16:39 : CRC 1 : DFAAF68F 21:16:39 : Checksum 75 21:16:39 : SearchForBootstrap_DCT5.. 21:16:39 : Boot File MATCH : RAP3Gv3_2nd.fg 21:16:39 : Boot File - Version : 009.011.001 21:16:39 : Boot File - Revision : 0x0000 21:16:39 : BB5ProtocolType == : Original 21:16:40 : MCU_CONFIGURATION_RESPONSE_BB5: 21:16:40 : MessageID : C1 21:16:40 : SubBlocks : 03 21:16:40 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:16:40 : Block Length : 0B 21:16:40 : BB ASIC Index : CMT 00 21:16:40 : Device Type : NOR 00 21:16:40 : Device Index : 00 21:16:40 : Manufacturer Code : 0089 -> 21:16:40 : Device ID : 8981 -> Type not in database 21:16:40 : Extended/Fixed ID : 0000 21:16:40 : Revision ID : 6A21 21:16:40 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 21:16:40 : Block Length : 13 21:16:40 : BB ASIC Index : CMT 00 21:16:40 : Device Type : NOR 00 21:16:40 : Device Index : 00 21:16:40 : Device Contents : 00000000000000000000 21:16:40 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:16:40 : Block Length : 0B 21:16:40 : BB ASIC Index : CMT 00 21:16:40 : Device Type : MMC 04 21:16:40 : Device Index : 00 21:16:40 : Manufacturer Code : FFFF -> Flash 21:16:40 : Device ID : 0000 -> BAD FLASH TYPE 21:16:40 : Extended/Fixed ID : 0000 21:16:40 : Revision ID : 0000 21:16:40 : Checksum : 82 21:16:40 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:16:40 : FLS1SendAlgoCodeEx.. 21:16:40 : SendAlgoCode_DCT5.. 21:16:40 : SearchForAlgorithm_DCT5.. 21:16:40 : Looking for ALL Devices... 21:16:40 : File MATCH : RAP3Gv3_algo.fg 21:16:40 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00) 21:16:40 : TransmissionTypeRequest_DCT5... 21:16:40 : SuggestedType : 01 16BIT 21:16:40 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC 21:16:40 : ReturnedType : 01 16BIT 21:16:40 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 21:16:40 : Uploading ALGO File... 21:16:41 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 21:16:41 : Pabub KEY Request 21:16:41 : PhoneInfoRequest_BB5 (Asic Index 00 ) 21:16:41 : PHONE_INFO_RESPONSE_BB5 21:16:41 : PAPUB_KEYS_HASH_RESP_BB5 2A 21:16:41 : BB Asic Index : 01 21:16:41 : PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D 21:16:41 : No partition info.... 21:16:41 : VPP Enabled by Software 21:16:41 : Using Internal VPP 21:16:41 : StartErase_DCT5... 21:16:41 : BlockLength : 0x004E (78) 21:16:41 : ERASE Blocks : 0x0001 (1) 21:16:41 : 0 ERASE_AREA_BB5 0x12 21:16:41 : Block Length : 0x4B (75) 21:16:41 : BB ASIC Index : 0x00 CMT 21:16:41 : Device Type : 0x00 NOR 21:16:41 : Device Index : 0x00 21:16:41 : 0 : 00000000-000006BF 21:16:41 : 1 : 000006C0-0001FFFF 21:16:41 : 2 : 00020000-0007FFFF 21:16:41 : 3 : 00080000-000DFFFF 21:16:41 : 4 : 00100000-001FFFFF 21:16:41 : 5 : 00200000-0031FFFF 21:16:41 : 6 : 00320000-0105FFFF 21:16:41 : 7 : 01060000-01067FFF 21:16:41 : 8 : 01068000-0107FFFF 21:16:41 : ERASE_REQUEST_BB5 : 5001124B00000000000000000006BF000006C00001FFFF000200000007FFFF00080000000DFFFF00100000001FFFFF002000000031FFFF003200000105FFFF0106000001067FFF010680000107FFFF32 21:16:41 : Please wait ERASING......... 21:17:55 : Status_BB5 STATUS_REQUEST_BB5.. 21:17:55 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 21:17:55 : Block Length : 01 21:17:55 : BB ASIC Index : 00 21:17:55 : Successfully erased.. 21:17:55 : Time Taken to Erase : 00:01:14 21:17:55 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 21:17:55 : ReturnedType : 04 DDRand2TX 21:17:55 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 21:17:55 : Is Flashing CLOCK AUTO : -1 21:17:56 : Processing : rm237__07.21.mcusw 21:17:56 : Total blocks to write : 944 21:18:04 : >> CMT Rootkey Hash CERT : NOLO 21:18:05 : >> CMT Rootkey Hash CERT : KEYS 21:18:05 : >> CMT Rootkey Hash CERT : PRIMAPP 21:18:05 : >> CMT Rootkey Hash CERT : PASUBTOC 21:18:09 : >> CMT Rootkey Hash CERT : PAPUBKEYS 21:18:09 : >> CMT Rootkey Hash CERT : UPDAPP 21:18:09 : >> CMT Rootkey Hash CERT : DSP0 21:18:12 : >> CMT Rootkey Hash CERT : MCUSW 21:18:44 : >> CMT Rootkey Hash CERT : PMM_CONF 21:18:44 : >> CMT Rootkey Hash CERT : SBIF_CONF 21:18:44 : ContinueFlash_DCT5 Complete 21:18:44 : Status_BB5 STATUS_REQUEST_BB5.. 21:18:44 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 21:18:44 : Block Length : 01 21:18:44 : BB ASIC Index : 00 21:18:44 : FlashInfo.RestartMode : 1 21:18:44 : Continue Flash Complete : : No Error - 0 (0x00) 21:18:44 : Time Taken to Flash : 00:00:48 21:18:44 : Making delay between files for 10ms 21:18:44 : Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_mr 21:18:44 : CMT Type : BB5 21:18:44 : CMT Algorithm : BB5 ALGORITHM 21:18:44 : CMT Supported Hardwares : 21:18:44 : > 0103192101001101 21:18:44 : > 010C192101001101 21:18:44 : Secondary Sending Speed : 3250000Hz 21:18:44 : Algorithm Sending Speed : 6500000Hz 21:18:44 : Program Sending Speed : 6500000Hz 21:18:44 : Message Reading Speed : 98000Hz 21:18:44 : Number of Blocks : 227 21:18:44 : Entry Point: 0x00A6 21:18:44 : Page Format : -1 21:18:44 : MAX PAGE : 0x00004000 21:18:44 : AdvanceFBox SendBootCodeEx 21:18:44 : InitialiseBootstrap_DCT5 DIR 21:18:44 : BootFlashMode_DCT5 21:18:44 : BootFlashModeDCT5Ex Succeeded First Time 21:18:44 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2118223920 (0x30) bytes returned 21:18:44 : Number of Sub Blocks 7 (0x07) 21:18:44 : 1 SYSTEM_ASIC_ID 01 21:18:44 : Block Length : 21 (15) 21:18:44 : BB ASIC Index : 0 (00) CMT 21:18:44 : ID DWORD 0 : 00000001 21:18:44 : ID DWORD 1 : 00000226 21:18:44 : ID DWORD 2 : 00010006 21:18:44 : ID DWORD 3 : 010C1921 21:18:44 : ID DWORD 4 : 01001101 21:18:44 : 2 ROM_ID 15 21:18:44 : Block Length : 5 (05) 21:18:44 : BB ASIC Index : 0 (00) CMT 21:18:44 : ID DWORD 0 : 00000232 21:18:44 : 3 ROM_ID 15 21:18:44 : Block Length : 5 (05) 21:18:44 : BB ASIC Index : 0 (00) CMT 21:18:44 : ID DWORD 0 : 00000353 21:18:44 : 4 PUBLIC_ID 12 21:18:44 : Block Length : 21 (15) 21:18:44 : BB ASIC Index : 0 (00) CMT 21:18:44 : ID DWORD 0 : 19D00113 21:18:44 : ID DWORD 1 : 10A47C56 21:18:44 : ID DWORD 2 : 4C322332 21:18:44 : ID DWORD 3 : 8219B500 21:18:44 : ID DWORD 4 : 1AEAF1FF 21:18:44 : 5 ASIC_MODE_ID 13 21:18:44 : Block Length : 2 (02) 21:18:44 : BB ASIC Index : 0 (00) CMT 21:18:44 : Mode Id : 00 21:18:44 : 6 ROOT_KEY_HASH 14 21:18:44 : Block Length : 17 (11) 21:18:44 : BB ASIC Index : 0 (00) CMT 21:18:44 : Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 21:18:44 : 7 ROM_ID 15 21:18:44 : Block Length : 9 (09) 21:18:44 : BB ASIC Index : 0 (00) CMT 21:18:44 : CRC 0 : 191EC665 21:18:44 : CRC 1 : DFAAF68F 21:18:44 : Checksum 75 21:18:44 : SearchForBootstrap_DCT5.. 21:18:45 : Boot File MATCH : RAP3Gv3_2nd.fg 21:18:45 : Boot File - Version : 009.011.001 21:18:45 : Boot File - Revision : 0x0000 21:18:45 : BB5ProtocolType == : Original 21:18:45 : MCU_CONFIGURATION_RESPONSE_BB5: 21:18:45 : MessageID : C1 21:18:45 : SubBlocks : 03 21:18:45 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:18:45 : Block Length : 0B 21:18:45 : BB ASIC Index : CMT 00 21:18:45 : Device Type : NOR 00 21:18:45 : Device Index : 00 21:18:45 : Manufacturer Code : 0089 -> 21:18:45 : Device ID : 8981 -> Type not in database 21:18:45 : Extended/Fixed ID : 0000 21:18:45 : Revision ID : 6A21 21:18:45 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 21:18:45 : Block Length : 13 21:18:45 : BB ASIC Index : CMT 00 21:18:45 : Device Type : NOR 00 21:18:45 : Device Index : 00 21:18:45 : Device Contents : 00000000000000000000 21:18:45 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:18:45 : Block Length : 0B 21:18:45 : BB ASIC Index : CMT 00 21:18:45 : Device Type : MMC 04 21:18:45 : Device Index : 00 21:18:45 : Manufacturer Code : FFFF -> Flash 21:18:45 : Device ID : 0000 -> BAD FLASH TYPE 21:18:45 : Extended/Fixed ID : 0000 21:18:45 : Revision ID : 0000 21:18:45 : Checksum : 82 21:18:45 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:18:45 : FLS1SendAlgoCodeEx.. 21:18:45 : SendAlgoCode_DCT5.. 21:18:45 : SearchForAlgorithm_DCT5.. 21:18:45 : Looking for ALL Devices... 21:18:46 : File MATCH : RAP3Gv3_algo.fg 21:18:46 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00) 21:18:46 : TransmissionTypeRequest_DCT5... 21:18:46 : SuggestedType : 01 16BIT 21:18:46 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC 21:18:46 : ReturnedType : 01 16BIT 21:18:46 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 21:18:46 : Uploading ALGO File... 21:18:46 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 21:18:46 : Pabub KEY Request 21:18:46 : PhoneInfoRequest_BB5 (Asic Index 00 ) 21:18:46 : PHONE_INFO_RESPONSE_BB5 21:18:46 : PAPUB_KEYS_HASH_RESP_BB5 2A 21:18:46 : BB Asic Index : 01 21:18:46 : PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D 21:18:46 : No partition info.... 21:18:46 : VPP Enabled by Software 21:18:46 : Using Internal VPP 21:18:46 : StartErase_DCT5... 21:18:46 : BlockLength : 0x000E (14) 21:18:46 : ERASE Blocks : 0x0001 (1) 21:18:46 : 0 ERASE_AREA_BB5 0x12 21:18:46 : Block Length : 0x0B (11) 21:18:46 : BB ASIC Index : 0x00 CMT 21:18:46 : Device Type : 0x00 NOR 21:18:46 : Device Index : 0x00 21:18:46 : 0 : 01080000-0151FFFF 21:18:46 : ERASE_REQUEST_BB5 : 5001120B000000010800000151FFFF88 21:18:46 : Please wait ERASING......... 21:19:04 : Status_BB5 STATUS_REQUEST_BB5.. 21:19:04 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 21:19:04 : Block Length : 01 21:19:04 : BB ASIC Index : 00 21:19:04 : Successfully erased.. 21:19:04 : Time Taken to Erase : 00:00:17 21:19:04 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 21:19:04 : ReturnedType : 04 DDRand2TX 21:19:04 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 21:19:04 : Is Flashing CLOCK AUTO : -1 21:19:04 : Processing : rm237__07.21.ppm_mr 21:19:04 : Total blocks to write : 227 21:19:13 : ContinueFlash_DCT5 Complete 21:19:13 : Status_BB5 STATUS_REQUEST_BB5.. 21:19:13 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 21:19:13 : Block Length : 01 21:19:13 : BB ASIC Index : 00 21:19:13 : FlashInfo.RestartMode : 2 21:19:13 : Continue Flash Complete : : No Error - 0 (0x00) 21:19:13 : Time Taken to Flash : 00:00:09 21:19:13 : Making delay between files for 10ms 21:19:13 : Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_ctv_india_mr_128 21:19:13 : CMT Type : BB5 21:19:13 : CMT Algorithm : BB5 ALGORITHM 21:19:13 : CMT Supported Hardwares : 21:19:13 : > 0103192101001101 21:19:13 : > 010C192101001101 21:19:13 : Secondary Sending Speed : 3250000Hz 21:19:13 : Algorithm Sending Speed : 6500000Hz 21:19:13 : Program Sending Speed : 6500000Hz 21:19:13 : Message Reading Speed : 98000Hz 21:19:13 : Number of Blocks : 260 21:19:13 : Entry Point: 0x00B2 21:19:13 : Page Format : 0 21:19:13 : MAX PAGE : 0x00004000 21:19:13 : File detected Not 128K format.... 21:19:13 : Converting image to 128k bit..... 21:19:13 : Converted file created : C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_ctv_india_mr_128_128k 21:19:13 : CMT Type : BB5 21:19:13 : CMT Algorithm : BB5 ALGORITHM 21:19:13 : CMT Supported Hardwares : 21:19:13 : > 0103192101001101 21:19:13 : > 010C192101001101 21:19:13 : Secondary Sending Speed : 3250000Hz 21:19:13 : Algorithm Sending Speed : 6500000Hz 21:19:13 : Program Sending Speed : 6500000Hz 21:19:13 : Message Reading Speed : 98000Hz 21:19:13 : Number of Blocks : 264 21:19:13 : Entry Point: 0x00B2 21:19:13 : Page Format : 0 21:19:13 : MAX PAGE : 0x00004000 21:19:14 : AdvanceFBox SendBootCodeEx 21:19:14 : InitialiseBootstrap_DCT5 DIR 21:19:14 : BootFlashMode_DCT5 21:19:14 : BootFlashModeDCT5Ex Succeeded First Time 21:19:14 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2118223920 (0x30) bytes returned 21:19:14 : Number of Sub Blocks 7 (0x07) 21:19:14 : 1 SYSTEM_ASIC_ID 01 21:19:14 : Block Length : 21 (15) 21:19:14 : BB ASIC Index : 0 (00) CMT 21:19:14 : ID DWORD 0 : 00000001 21:19:14 : ID DWORD 1 : 00000226 21:19:14 : ID DWORD 2 : 00010006 21:19:14 : ID DWORD 3 : 010C1921 21:19:14 : ID DWORD 4 : 01001101 21:19:14 : 2 ROM_ID 15 21:19:14 : Block Length : 5 (05) 21:19:14 : BB ASIC Index : 0 (00) CMT 21:19:14 : ID DWORD 0 : 00000232 21:19:14 : 3 ROM_ID 15 21:19:14 : Block Length : 5 (05) 21:19:14 : BB ASIC Index : 0 (00) CMT 21:19:14 : ID DWORD 0 : 00000353 21:19:14 : 4 PUBLIC_ID 12 21:19:14 : Block Length : 21 (15) 21:19:14 : BB ASIC Index : 0 (00) CMT 21:19:14 : ID DWORD 0 : 19D00113 21:19:14 : ID DWORD 1 : 10A47C56 21:19:14 : ID DWORD 2 : 4C322332 21:19:14 : ID DWORD 3 : 8219B500 21:19:14 : ID DWORD 4 : 1AEAF1FF 21:19:14 : 5 ASIC_MODE_ID 13 21:19:14 : Block Length : 2 (02) 21:19:14 : BB ASIC Index : 0 (00) CMT 21:19:14 : Mode Id : 00 21:19:14 : 6 ROOT_KEY_HASH 14 21:19:14 : Block Length : 17 (11) 21:19:14 : BB ASIC Index : 0 (00) CMT 21:19:14 : Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 21:19:14 : 7 ROM_ID 15 21:19:14 : Block Length : 9 (09) 21:19:14 : BB ASIC Index : 0 (00) CMT 21:19:14 : CRC 0 : 191EC665 21:19:14 : CRC 1 : DFAAF68F 21:19:14 : Checksum 75 21:19:14 : SearchForBootstrap_DCT5.. 21:19:14 : Boot File MATCH : RAP3Gv3_2nd.fg 21:19:14 : Boot File - Version : 009.011.001 21:19:14 : Boot File - Revision : 0x0000 21:19:14 : BB5ProtocolType == : Original 21:19:14 : MCU_CONFIGURATION_RESPONSE_BB5: 21:19:14 : MessageID : C1 21:19:14 : SubBlocks : 03 21:19:14 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:19:14 : Block Length : 0B 21:19:14 : BB ASIC Index : CMT 00 21:19:14 : Device Type : NOR 00 21:19:14 : Device Index : 00 21:19:14 : Manufacturer Code : 0089 -> 21:19:14 : Device ID : 8981 -> Type not in database 21:19:14 : Extended/Fixed ID : 0000 21:19:14 : Revision ID : 6A21 21:19:14 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 21:19:14 : Block Length : 13 21:19:14 : BB ASIC Index : CMT 00 21:19:14 : Device Type : NOR 00 21:19:14 : Device Index : 00 21:19:14 : Device Contents : 00000000000000000000 21:19:14 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:19:14 : Block Length : 0B 21:19:14 : BB ASIC Index : CMT 00 21:19:14 : Device Type : MMC 04 21:19:14 : Device Index : 00 21:19:14 : Manufacturer Code : FFFF -> Flash 21:19:14 : Device ID : 0000 -> BAD FLASH TYPE 21:19:14 : Extended/Fixed ID : 0000 21:19:14 : Revision ID : 0000 21:19:14 : Checksum : 82 21:19:14 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:19:14 : FLS1SendAlgoCodeEx.. 21:19:14 : SendAlgoCode_DCT5.. 21:19:14 : SearchForAlgorithm_DCT5.. 21:19:14 : Looking for ALL Devices... 21:19:15 : File MATCH : RAP3Gv3_algo.fg 21:19:15 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00) 21:19:15 : TransmissionTypeRequest_DCT5... 21:19:15 : SuggestedType : 01 16BIT 21:19:15 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC 21:19:15 : ReturnedType : 01 16BIT 21:19:15 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 21:19:15 : Uploading ALGO File... 21:19:15 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 21:19:15 : Pabub KEY Request 21:19:15 : PhoneInfoRequest_BB5 (Asic Index 00 ) 21:19:15 : PHONE_INFO_RESPONSE_BB5 21:19:15 : PAPUB_KEYS_HASH_RESP_BB5 2A 21:19:16 : BB Asic Index : 01 21:19:16 : PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D 21:19:16 : No partition info.... 21:19:16 : VPP Enabled by Software 21:19:16 : Using Internal VPP 21:19:16 : StartErase_DCT5... 21:19:16 : BlockLength : 0x000E (14) 21:19:16 : ERASE Blocks : 0x0001 (1) 21:19:16 : 0 ERASE_AREA_BB5 0x12 21:19:16 : Block Length : 0x0B (11) 21:19:16 : BB ASIC Index : 0x00 CMT 21:19:16 : Device Type : 0x00 NOR 21:19:16 : Device Index : 0x00 21:19:16 : 0 : 01520000-01FDFFFF 21:19:16 : ERASE_REQUEST_BB5 : 5001120B0000000152000001FDFFFF92 21:19:16 : Please wait ERASING......... 21:20:25 : Status_BB5 STATUS_REQUEST_BB5.. 21:20:29 : FAILED ERASING.... 21:20:29 : Operations Failed.... 21:20:45 : AdvanceBox Turbo Flasher Found 21:20:45 : Initialize Device.... 21:20:45 : Init TRY : 1 21:20:45 : Changing Clock to 15mhz.. 21:20:45 : Box Name : AdvanceBox Turbo 21:20:45 : Box Firmware : LogiCore 1.16.10 21:20:45 : Software Version : v2010.0.1.21 21:20:45 : AdvanceBox SN : E727BF7FE74C2B79EF0C3755 21:20:45 : BOX ACTIVATED 21:20:45 : DDR DELAY : 01 21:20:45 : INIT : OK 21:20:45 : 21:20:45 : Changing MODE : FLASH 21:20:45 : Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.mcusw 21:20:45 : CMT Type : BB5 21:20:45 : CMT Algorithm : BB5 ALGORITHM 21:20:45 : CMT Supported Hardwares : 21:20:45 : > 0103192101001101 21:20:45 : > 010C192101001101 21:20:45 : Secondary Sending Speed : 3250000Hz 21:20:45 : Algorithm Sending Speed : 6500000Hz 21:20:45 : Program Sending Speed : 6500000Hz 21:20:45 : Message Reading Speed : 98000Hz 21:20:45 : Number of Blocks : 944 21:20:45 : Entry Point: 0x44FC 21:20:45 : Page Format : -1 21:20:45 : MAX PAGE : 0x00004000 21:20:46 : AdvanceBox Turbo Flasher Found 21:20:46 : Initialize Device.... 21:20:46 : Init TRY : 1 21:20:46 : Changing Clock to 15mhz.. 21:20:46 : Box Name : AdvanceBox Turbo 21:20:46 : Box Firmware : LogiCore 1.16.10 21:20:46 : Software Version : v2010.0.1.21 21:20:46 : AdvanceBox SN : E727BF7FE74C2B79EF0C3755 21:20:46 : BOX ACTIVATED 21:20:46 : DDR DELAY : 01 21:20:46 : INIT : OK 21:20:46 : 21:20:46 : VBATT OFF ... 21:20:50 : VBATT ON 21:20:50 : Setting VBATT Done!... 21:20:51 : AdvanceFBox SendBootCodeEx 21:20:51 : InitialiseBootstrap_DCT5 DIR 21:20:51 : BootFlashMode_DCT5 21:20:51 : BootFlashModeDCT5Ex Succeeded First Time 21:20:51 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2118223920 (0x30) bytes returned 21:20:51 : Number of Sub Blocks 7 (0x07) 21:20:51 : 1 SYSTEM_ASIC_ID 01 21:20:51 : Block Length : 21 (15) 21:20:51 : BB ASIC Index : 0 (00) CMT 21:20:51 : ID DWORD 0 : 00000001 21:20:51 : ID DWORD 1 : 00000226 21:20:51 : ID DWORD 2 : 00010006 21:20:51 : ID DWORD 3 : 010C1921 21:20:51 : ID DWORD 4 : 01001101 21:20:51 : 2 ROM_ID 15 21:20:51 : Block Length : 5 (05) 21:20:51 : BB ASIC Index : 0 (00) CMT 21:20:51 : ID DWORD 0 : 00000232 21:20:51 : 3 ROM_ID 15 21:20:51 : Block Length : 5 (05) 21:20:51 : BB ASIC Index : 0 (00) CMT 21:20:51 : ID DWORD 0 : 00000353 21:20:51 : 4 PUBLIC_ID 12 21:20:51 : Block Length : 21 (15) 21:20:51 : BB ASIC Index : 0 (00) CMT 21:20:51 : ID DWORD 0 : 19D00113 21:20:51 : ID DWORD 1 : 10A47C56 21:20:51 : ID DWORD 2 : 4C322332 21:20:51 : ID DWORD 3 : 8219B500 21:20:51 : ID DWORD 4 : 1AEAF1FF 21:20:51 : 5 ASIC_MODE_ID 13 21:20:51 : Block Length : 2 (02) 21:20:51 : BB ASIC Index : 0 (00) CMT 21:20:51 : Mode Id : 00 21:20:51 : 6 ROOT_KEY_HASH 14 21:20:51 : Block Length : 17 (11) 21:20:51 : BB ASIC Index : 0 (00) CMT 21:20:51 : Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 21:20:51 : 7 ROM_ID 15 21:20:51 : Block Length : 9 (09) 21:20:51 : BB ASIC Index : 0 (00) CMT 21:20:51 : CRC 0 : 191EC665 21:20:51 : CRC 1 : DFAAF68F 21:20:51 : Checksum 75 21:20:51 : SearchForBootstrap_DCT5.. 21:20:51 : Boot File MATCH : RAP3Gv3_2nd.fg 21:20:51 : Boot File - Version : 001.030.000 21:20:51 : Boot File - Revision : 0x0000 21:20:51 : BB5ProtocolType == : Original 21:20:51 : MCU_CONFIGURATION_RESPONSE_BB5: 21:20:51 : MessageID : C1 21:20:51 : SubBlocks : 03 21:20:51 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:20:51 : Block Length : 0B 21:20:51 : BB ASIC Index : CMT 00 21:20:51 : Device Type : NOR 00 21:20:51 : Device Index : 00 21:20:51 : Manufacturer Code : 0089 -> 21:20:51 : Device ID : 8981 -> Type not in database 21:20:51 : Extended/Fixed ID : 0000 21:20:51 : Revision ID : 0000 21:20:51 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 21:20:51 : Block Length : 13 21:20:51 : BB ASIC Index : CMT 00 21:20:51 : Device Type : NOR 00 21:20:51 : Device Index : 00 21:20:51 : Device Contents : 00000000000000000000 21:20:51 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:20:51 : Block Length : 0B 21:20:51 : BB ASIC Index : CMT 00 21:20:51 : Device Type : MMC 04 21:20:51 : Device Index : 00 21:20:51 : Manufacturer Code : FFFF -> Flash 21:20:51 : Device ID : 0000 -> BAD FLASH TYPE 21:20:51 : Extended/Fixed ID : 0000 21:20:51 : Revision ID : 0000 21:20:51 : Checksum : 0D 21:20:51 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:20:51 : FLS1SendAlgoCodeEx.. 21:20:51 : SendAlgoCode_DCT5.. 21:20:51 : SearchForAlgorithm_DCT5.. 21:20:51 : Looking for ALL Devices... 21:20:51 : File MATCH : RAP3Gv3_algo.fg 21:20:51 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00) 21:20:51 : TransmissionTypeRequest_DCT5... 21:20:51 : SuggestedType : 01 16BIT 21:20:51 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC 21:20:51 : ReturnedType : 01 16BIT 21:20:51 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 21:20:51 : Uploading ALGO File... 21:20:52 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 21:20:52 : Pabub KEY Request 21:20:52 : PhoneInfoRequest_BB5 (Asic Index 00 ) 21:20:52 : PHONE_INFO_RESPONSE_BB5 21:20:52 : PAPUB_KEYS_HASH_RESP_BB5 2A 21:20:52 : BB Asic Index : 01 21:20:52 : PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D 21:20:52 : No partition info.... 21:20:52 : VPP Enabled by Software 21:20:52 : Using Internal VPP 21:20:52 : StartErase_DCT5... 21:20:52 : BlockLength : 0x004E (78) 21:20:52 : ERASE Blocks : 0x0001 (1) 21:20:52 : 0 ERASE_AREA_BB5 0x12 21:20:52 : Block Length : 0x4B (75) 21:20:52 : BB ASIC Index : 0x00 CMT 21:20:52 : Device Type : 0x00 NOR 21:20:52 : Device Index : 0x00 21:20:52 : 0 : 00000000-000006BF 21:20:52 : 1 : 000006C0-0001FFFF 21:20:52 : 2 : 00020000-0007FFFF 21:20:52 : 3 : 00080000-000DFFFF 21:20:52 : 4 : 00100000-001FFFFF 21:20:52 : 5 : 00200000-0031FFFF 21:20:52 : 6 : 00320000-0105FFFF 21:20:52 : 7 : 01060000-01067FFF 21:20:52 : 8 : 01068000-0107FFFF 21:20:52 : ERASE_REQUEST_BB5 : 5001124B00000000000000000006BF000006C00001FFFF000200000007FFFF00080000000DFFFF00100000001FFFFF002000000031FFFF003200000105FFFF0106000001067FFF010680000107FFFF32 21:20:52 : Please wait ERASING......... 21:22:12 : Status_BB5 STATUS_REQUEST_BB5.. 21:22:12 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 21:22:12 : Block Length : 01 21:22:12 : BB ASIC Index : 00 21:22:12 : Successfully erased.. 21:22:12 : Time Taken to Erase : 00:01:19 21:22:12 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 21:22:12 : ReturnedType : 04 DDRand2TX 21:22:12 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 21:22:12 : Is Flashing CLOCK AUTO : -1 21:22:12 : Processing : rm237__07.21.mcusw 21:22:12 : Total blocks to write : 944 21:22:20 : >> CMT Rootkey Hash CERT : NOLO 21:22:21 : >> CMT Rootkey Hash CERT : KEYS 21:22:21 : >> CMT Rootkey Hash CERT : PRIMAPP 21:22:21 : >> CMT Rootkey Hash CERT : PASUBTOC 21:22:25 : >> CMT Rootkey Hash CERT : PAPUBKEYS 21:22:25 : >> CMT Rootkey Hash CERT : UPDAPP 21:22:26 : >> CMT Rootkey Hash CERT : DSP0 21:22:29 : >> CMT Rootkey Hash CERT : MCUSW 21:23:01 : >> CMT Rootkey Hash CERT : PMM_CONF 21:23:01 : >> CMT Rootkey Hash CERT : SBIF_CONF 21:23:01 : ContinueFlash_DCT5 Complete 21:23:01 : Status_BB5 STATUS_REQUEST_BB5.. 21:23:01 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 21:23:01 : Block Length : 01 21:23:01 : BB ASIC Index : 00 21:23:01 : FlashInfo.RestartMode : 1 21:23:01 : Continue Flash Complete : : No Error - 0 (0x00) 21:23:01 : Time Taken to Flash : 00:00:49 21:23:01 : Making delay between files for 10ms 21:23:01 : Processing Image File : c:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_mr 21:23:01 : CMT Type : BB5 21:23:01 : CMT Algorithm : BB5 ALGORITHM 21:23:01 : CMT Supported Hardwares : 21:23:01 : > 0103192101001101 21:23:01 : > 010C192101001101 21:23:01 : Secondary Sending Speed : 3250000Hz 21:23:01 : Algorithm Sending Speed : 6500000Hz 21:23:01 : Program Sending Speed : 6500000Hz 21:23:01 : Message Reading Speed : 98000Hz 21:23:01 : Number of Blocks : 227 21:23:01 : Entry Point: 0x00A6 21:23:01 : Page Format : -1 21:23:01 : MAX PAGE : 0x00004000 21:23:01 : AdvanceFBox SendBootCodeEx 21:23:01 : InitialiseBootstrap_DCT5 DIR 21:23:01 : BootFlashMode_DCT5 21:23:01 : BootFlashModeDCT5Ex Succeeded First Time 21:23:01 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2118223920 (0x30) bytes returned 21:23:01 : Number of Sub Blocks 7 (0x07) 21:23:01 : 1 SYSTEM_ASIC_ID 01 21:23:01 : Block Length : 21 (15) 21:23:01 : BB ASIC Index : 0 (00) CMT 21:23:01 : ID DWORD 0 : 00000001 21:23:01 : ID DWORD 1 : 00000226 21:23:01 : ID DWORD 2 : 00010006 21:23:01 : ID DWORD 3 : 010C1921 21:23:01 : ID DWORD 4 : 01001101 21:23:01 : 2 ROM_ID 15 21:23:01 : Block Length : 5 (05) 21:23:01 : BB ASIC Index : 0 (00) CMT 21:23:01 : ID DWORD 0 : 00000232 21:23:01 : 3 ROM_ID 15 21:23:01 : Block Length : 5 (05) 21:23:01 : BB ASIC Index : 0 (00) CMT 21:23:01 : ID DWORD 0 : 00000353 21:23:01 : 4 PUBLIC_ID 12 21:23:01 : Block Length : 21 (15) 21:23:01 : BB ASIC Index : 0 (00) CMT 21:23:01 : ID DWORD 0 : 19D00113 21:23:01 : ID DWORD 1 : 10A47C56 21:23:01 : ID DWORD 2 : 4C322332 21:23:01 : ID DWORD 3 : 8219B500 21:23:01 : ID DWORD 4 : 1AEAF1FF 21:23:01 : 5 ASIC_MODE_ID 13 21:23:01 : Block Length : 2 (02) 21:23:01 : BB ASIC Index : 0 (00) CMT 21:23:01 : Mode Id : 00 21:23:01 : 6 ROOT_KEY_HASH 14 21:23:01 : Block Length : 17 (11) 21:23:01 : BB ASIC Index : 0 (00) CMT 21:23:01 : Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 21:23:01 : 7 ROM_ID 15 21:23:01 : Block Length : 9 (09) 21:23:01 : BB ASIC Index : 0 (00) CMT 21:23:01 : CRC 0 : 191EC665 21:23:01 : CRC 1 : DFAAF68F 21:23:01 : Checksum 75 21:23:01 : SearchForBootstrap_DCT5.. 21:23:02 : Boot File MATCH : RAP3Gv3_2nd.fg 21:23:02 : Boot File - Version : 001.030.000 21:23:02 : Boot File - Revision : 0x0000 21:23:02 : BB5ProtocolType == : Original 21:23:02 : MCU_CONFIGURATION_RESPONSE_BB5: 21:23:02 : MessageID : C1 21:23:02 : SubBlocks : 03 21:23:02 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:23:02 : Block Length : 0B 21:23:02 : BB ASIC Index : CMT 00 21:23:02 : Device Type : NOR 00 21:23:02 : Device Index : 00 21:23:02 : Manufacturer Code : 0089 -> 21:23:02 : Device ID : 8981 -> Type not in database 21:23:02 : Extended/Fixed ID : 0000 21:23:02 : Revision ID : 0000 21:23:02 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 21:23:02 : Block Length : 13 21:23:02 : BB ASIC Index : CMT 00 21:23:02 : Device Type : NOR 00 21:23:02 : Device Index : 00 21:23:02 : Device Contents : 00000000000000000000 21:23:02 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:23:02 : Block Length : 0B 21:23:02 : BB ASIC Index : CMT 00 21:23:02 : Device Type : MMC 04 21:23:02 : Device Index : 00 21:23:02 : Manufacturer Code : FFFF -> Flash 21:23:02 : Device ID : 0000 -> BAD FLASH TYPE 21:23:02 : Extended/Fixed ID : 0000 21:23:02 : Revision ID : 0000 21:23:02 : Checksum : 0D 21:23:02 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:23:02 : FLS1SendAlgoCodeEx.. 21:23:02 : SendAlgoCode_DCT5.. 21:23:02 : SearchForAlgorithm_DCT5.. 21:23:02 : Looking for ALL Devices... 21:23:02 : File MATCH : RAP3Gv3_algo.fg 21:23:02 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00) 21:23:02 : TransmissionTypeRequest_DCT5... 21:23:02 : SuggestedType : 01 16BIT 21:23:02 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC 21:23:02 : ReturnedType : 01 16BIT 21:23:02 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 21:23:02 : Uploading ALGO File... 21:23:03 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 21:23:03 : Pabub KEY Request 21:23:03 : PhoneInfoRequest_BB5 (Asic Index 00 ) 21:23:03 : PHONE_INFO_RESPONSE_BB5 21:23:03 : PAPUB_KEYS_HASH_RESP_BB5 2A 21:23:03 : BB Asic Index : 01 21:23:03 : PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D 21:23:03 : No partition info.... 21:23:03 : VPP Enabled by Software 21:23:03 : Using Internal VPP 21:23:03 : StartErase_DCT5... 21:23:03 : BlockLength : 0x000E (14) 21:23:03 : ERASE Blocks : 0x0001 (1) 21:23:03 : 0 ERASE_AREA_BB5 0x12 21:23:03 : Block Length : 0x0B (11) 21:23:03 : BB ASIC Index : 0x00 CMT 21:23:03 : Device Type : 0x00 NOR 21:23:03 : Device Index : 0x00 21:23:03 : 0 : 01080000-0151FFFF 21:23:03 : ERASE_REQUEST_BB5 : 5001120B000000010800000151FFFF88 21:23:03 : Please wait ERASING......... 21:23:21 : Status_BB5 STATUS_REQUEST_BB5.. 21:23:21 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 21:23:21 : Block Length : 01 21:23:21 : BB ASIC Index : 00 21:23:21 : Successfully erased.. 21:23:21 : Time Taken to Erase : 00:00:18 21:23:22 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 21:23:22 : ReturnedType : 04 DDRand2TX 21:23:22 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 21:23:22 : Is Flashing CLOCK AUTO : -1 21:23:22 : Processing : rm237__07.21.ppm_mr 21:23:22 : Total blocks to write : 227 21:23:30 : ContinueFlash_DCT5 Complete 21:23:30 : Status_BB5 STATUS_REQUEST_BB5.. 21:23:31 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 21:23:31 : Block Length : 01 21:23:31 : BB ASIC Index : 00 21:23:31 : FlashInfo.RestartMode : 2 21:23:31 : Continue Flash Complete : : No Error - 0 (0x00) 21:23:31 : Time Taken to Flash : 00:00:08 21:23:31 : Making delay between files for 10ms 21:23:31 : Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_ctv_india_mr_128 21:23:31 : CMT Type : BB5 21:23:31 : CMT Algorithm : BB5 ALGORITHM 21:23:31 : CMT Supported Hardwares : 21:23:31 : > 0103192101001101 21:23:31 : > 010C192101001101 21:23:31 : Secondary Sending Speed : 3250000Hz 21:23:31 : Algorithm Sending Speed : 6500000Hz 21:23:31 : Program Sending Speed : 6500000Hz 21:23:31 : Message Reading Speed : 98000Hz 21:23:31 : Number of Blocks : 260 21:23:31 : Entry Point: 0x00B2 21:23:31 : Page Format : 0 21:23:31 : MAX PAGE : 0x00004000 21:23:31 : File detected Not 128K format.... 21:23:31 : Converting image to 128k bit..... 21:23:31 : Converted file created : C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_ctv_india_mr_128_128k 21:23:31 : CMT Type : BB5 21:23:31 : CMT Algorithm : BB5 ALGORITHM 21:23:31 : CMT Supported Hardwares : 21:23:31 : > 0103192101001101 21:23:31 : > 010C192101001101 21:23:31 : Secondary Sending Speed : 3250000Hz 21:23:31 : Algorithm Sending Speed : 6500000Hz 21:23:31 : Program Sending Speed : 6500000Hz 21:23:31 : Message Reading Speed : 98000Hz 21:23:31 : Number of Blocks : 264 21:23:31 : Entry Point: 0x00B2 21:23:31 : Page Format : 0 21:23:31 : MAX PAGE : 0x00004000 21:23:31 : AdvanceFBox SendBootCodeEx 21:23:31 : InitialiseBootstrap_DCT5 DIR 21:23:31 : BootFlashMode_DCT5 21:23:31 : BootFlashModeDCT5Ex Succeeded First Time 21:23:31 : SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2118223920 (0x30) bytes returned 21:23:31 : Number of Sub Blocks 7 (0x07) 21:23:31 : 1 SYSTEM_ASIC_ID 01 21:23:31 : Block Length : 21 (15) 21:23:31 : BB ASIC Index : 0 (00) CMT 21:23:31 : ID DWORD 0 : 00000001 21:23:31 : ID DWORD 1 : 00000226 21:23:31 : ID DWORD 2 : 00010006 21:23:31 : ID DWORD 3 : 010C1921 21:23:31 : ID DWORD 4 : 01001101 21:23:31 : 2 ROM_ID 15 21:23:31 : Block Length : 5 (05) 21:23:31 : BB ASIC Index : 0 (00) CMT 21:23:31 : ID DWORD 0 : 00000232 21:23:31 : 3 ROM_ID 15 21:23:31 : Block Length : 5 (05) 21:23:31 : BB ASIC Index : 0 (00) CMT 21:23:31 : ID DWORD 0 : 00000353 21:23:31 : 4 PUBLIC_ID 12 21:23:31 : Block Length : 21 (15) 21:23:31 : BB ASIC Index : 0 (00) CMT 21:23:31 : ID DWORD 0 : 19D00113 21:23:31 : ID DWORD 1 : 10A47C56 21:23:31 : ID DWORD 2 : 4C322332 21:23:31 : ID DWORD 3 : 8219B500 21:23:31 : ID DWORD 4 : 1AEAF1FF 21:23:31 : 5 ASIC_MODE_ID 13 21:23:31 : Block Length : 2 (02) 21:23:31 : BB ASIC Index : 0 (00) CMT 21:23:31 : Mode Id : 00 21:23:31 : 6 ROOT_KEY_HASH 14 21:23:31 : Block Length : 17 (11) 21:23:31 : BB ASIC Index : 0 (00) CMT 21:23:31 : Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 21:23:31 : 7 ROM_ID 15 21:23:31 : Block Length : 9 (09) 21:23:31 : BB ASIC Index : 0 (00) CMT 21:23:31 : CRC 0 : 191EC665 21:23:31 : CRC 1 : DFAAF68F 21:23:31 : Checksum 75 21:23:31 : SearchForBootstrap_DCT5.. 21:23:31 : Boot File MATCH : RAP3Gv3_2nd.fg 21:23:31 : Boot File - Version : 001.030.000 21:23:31 : Boot File - Revision : 0x0000 21:23:31 : BB5ProtocolType == : Original 21:23:32 : MCU_CONFIGURATION_RESPONSE_BB5: 21:23:32 : MessageID : C1 21:23:32 : SubBlocks : 03 21:23:32 : 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:23:32 : Block Length : 0B 21:23:32 : BB ASIC Index : CMT 00 21:23:32 : Device Type : NOR 00 21:23:32 : Device Index : 00 21:23:32 : Manufacturer Code : 0089 -> 21:23:32 : Device ID : 8981 -> Type not in database 21:23:32 : Extended/Fixed ID : 0000 21:23:32 : Revision ID : 0000 21:23:32 : 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 21:23:32 : Block Length : 13 21:23:32 : BB ASIC Index : CMT 00 21:23:32 : Device Type : NOR 00 21:23:32 : Device Index : 00 21:23:32 : Device Contents : 00000000000000000000 21:23:32 : 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 21:23:32 : Block Length : 0B 21:23:32 : BB ASIC Index : CMT 00 21:23:32 : Device Type : MMC 04 21:23:32 : Device Index : 00 21:23:32 : Manufacturer Code : FFFF -> Flash 21:23:32 : Device ID : 0000 -> BAD FLASH TYPE 21:23:32 : Extended/Fixed ID : 0000 21:23:32 : Revision ID : 0000 21:23:32 : Checksum : 0D 21:23:32 : SearchForBootstrap_DCT5 : No Error - 0 (0x00) 21:23:32 : FLS1SendAlgoCodeEx.. 21:23:32 : SendAlgoCode_DCT5.. 21:23:32 : SearchForAlgorithm_DCT5.. 21:23:32 : Looking for ALL Devices... 21:23:32 : File MATCH : RAP3Gv3_algo.fg 21:23:32 : SearchForAlgorithm_DCT5 : No Error - 0 (0x00) 21:23:32 : TransmissionTypeRequest_DCT5... 21:23:32 : SuggestedType : 01 16BIT 21:23:32 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC 21:23:32 : ReturnedType : 01 16BIT 21:23:32 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 21:23:32 : Uploading ALGO File... 21:23:32 : SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) 21:23:32 : Pabub KEY Request 21:23:32 : PhoneInfoRequest_BB5 (Asic Index 00 ) 21:23:32 : PHONE_INFO_RESPONSE_BB5 21:23:32 : PAPUB_KEYS_HASH_RESP_BB5 2A 21:23:32 : BB Asic Index : 01 21:23:32 : PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D 21:23:32 : No partition info.... 21:23:32 : VPP Enabled by Software 21:23:32 : Using Internal VPP 21:23:32 : StartErase_DCT5... 21:23:32 : BlockLength : 0x000E (14) 21:23:32 : ERASE Blocks : 0x0001 (1) 21:23:32 : 0 ERASE_AREA_BB5 0x12 21:23:32 : Block Length : 0x0B (11) 21:23:32 : BB ASIC Index : 0x00 CMT 21:23:32 : Device Type : 0x00 NOR 21:23:32 : Device Index : 0x00 21:23:32 : 0 : 01520000-01FDFFFF 21:23:32 : ERASE_REQUEST_BB5 : 5001120B0000000152000001FDFFFF92 21:23:32 : Please wait ERASING......... 21:23:44 : Status_BB5 STATUS_REQUEST_BB5.. 21:23:44 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 21:23:44 : Block Length : 01 21:23:44 : BB ASIC Index : 00 21:23:44 : Successfully erased.. 21:23:44 : Time Taken to Erase : 00:00:11 21:23:44 : TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 21:23:44 : ReturnedType : 04 DDRand2TX 21:23:44 : TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) 21:23:44 : Is Flashing CLOCK AUTO : -1 21:23:45 : Processing : rm237__07.21.image_ctv_india_mr_128_128k 21:23:45 : Total blocks to write : 264 21:23:54 : ContinueFlash_DCT5 Complete 21:23:55 : Status_BB5 STATUS_REQUEST_BB5.. 21:23:55 : 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 21:23:55 : Block Length : 01 21:23:55 : BB ASIC Index : 00 21:23:55 : FlashInfo.RestartMode : 2 21:23:55 : Continue Flash Complete : : No Error - 0 (0x00) 21:23:55 : Time Taken to Flash : 00:00:10 21:23:55 : Rebooting Box ... 21:23:55 : AdvanceBox Turbo Flasher Found 21:23:55 : Initialize Device.... 21:23:55 : Init TRY : 1 21:23:55 : Changing Clock to 15mhz.. 21:23:55 : Box Name : AdvanceBox Turbo 21:23:55 : Box Firmware : LogiCore 1.16.10 21:23:55 : Software Version : v2010.0.1.21 21:23:55 : AdvanceBox SN : E727BF7FE74C2B79EF0C3755 21:23:55 : BOX ACTIVATED 21:23:55 : DDR DELAY : 01 21:23:55 : INIT : OK 21:23:55 : 21:23:55 : VBATT OFF ... 21:23:58 : VBATT ON 21:23:58 : Setting VBATT Done!... 21:23:58 : Waiting for phone to Power On, 8000 ms delay 21:24:06 : Changing MODE : UART 21:24:06 : Reading Phone Information... 21:24:09 : MCU SW version : V 07.21 05-11-08 RM-237 (c) Nokia. 21:24:09 : HW version : 5007 21:24:09 : PCI version : 21:24:09 : RFIC version : 17211721 21:24:09 : DSP version : ICPR61_08w10 21:24:09 : Retu version : 32 21:24:09 : Tahvo version : 53 21:24:09 : Production serial number : M9G540437 21:24:09 : Product code : 0550573 21:24:09 : Module code : 0203291 21:24:09 : Basic production code : 0542523 21:24:09 : Flash code : 21:24:09 : Order number : 21:24:09 : Product specific data : 21:24:09 : Long production SN : 21:24:09 : ATO : 21:24:09 : IMEI plain : 359309020107308 21:24:09 : IMEI spare to net : 3A 95 03 09 02 01 37 00 21:24:09 : IMEI SV to net : 33 95 03 09 02 01 37 20 F5 21:24:09 : 21:24:09 : Simlock Version : 21:24:09 : Unable to read SP Data.. 21:24:19 : AdvanceBox Turbo Flasher Found 21:24:19 : Initialize Device.... 21:24:19 : Init TRY : 1 21:24:19 : Changing Clock to 15mhz.. 21:24:19 : Box Name : AdvanceBox Turbo 21:24:19 : Box Firmware : LogiCore 1.16.10 21:24:19 : Software Version : v2010.0.1.21 21:24:19 : AdvanceBox SN : E727BF7FE74C2B79EF0C3755 21:24:19 : BOX ACTIVATED 21:24:19 : DDR DELAY : 01 21:24:19 : INIT : OK 21:24:19 : 21:24:19 : VBATT OFF ... 21:24:21 : VBATT ON 21:24:21 : Setting VBATT Done!... 21:24:22 : Changing MODE : UART 21:24:22 : Reading Phone Information... 21:24:24 : MCU SW version : V 07.21 05-11-08 RM-237 (c) Nokia. 21:24:24 : HW version : 5007 21:24:24 : PCI version : 21:24:24 : RFIC version : 17211721 21:24:24 : DSP version : ICPR61_08w10 21:24:24 : Retu version : 32 21:24:24 : Tahvo version : 53 21:24:24 : Production serial number : M9G540437 21:24:25 : Product code : 0550573 21:24:25 : Module code : 0203291 21:24:25 : Basic production code : 0542523 21:24:25 : Flash code : 21:24:25 : Order number : 21:24:25 : Product specific data : 21:24:25 : Long production SN : 21:24:25 : ATO : 21:24:25 : IMEI plain : 359309020107308 21:24:25 : IMEI spare to net : 3A 95 03 09 02 01 37 00 21:24:25 : IMEI SV to net : 33 95 03 09 02 01 37 20 F5 21:24:25 : 21:24:25 : Simlock Version : SIMLOCK SERVER VERSION 63 21:24:25 : CONFIG KEY: 0000000000000000 21:24:25 : PROVIDER KEY: 2440700000000000 21:24:25 : Provider : AT&T;U.S.A. (3650) 21:24:25 : Counters : 0/3 , 0/10 21:24:25 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open 21:24:25 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open 21:24:25 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open 21:24:25 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open 21:24:25 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open 21:24:25 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open 21:24:25 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open 21:24:25 : SP Lock Status : Not Locked Last edited by lemor; 02-21-2010 at 04:18. |
The Following 8 Users Say Thank You to cdma-india For This Useful Post: |
02-17-2010, 09:30 | #11 (permalink) |
Registered User Join Date: Jun 2007 Location: Philippines
Member: 528692 Status: Offline Thanks Meter: 65 | 6120C FBUS - Full Flashing Code: AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : E43C85E1F5CD8A8BD157919B BOX ACTIVATED DDR DELAY : 01 INIT : OK Changing MODE : FLASH Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-243\rm243_06.51_prd_core.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101002003 > 400C192101002003 > 0003192101002003 > 000C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101011105 > 400C192101011105 > 4003192101021105 > 400C192101021105 > 400C192101031105 > 4003192101031105 > 4003192101031103 > 400C192101031103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 385 Entry Point: 0x1F248E Page Format : -1 MAX PAGE : 0x00020000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417160 (0x08) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01021103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 15100004 ID DWORD 1 : 98630052 ID DWORD 2 : F9AF5719 ID DWORD 3 : 4F494759 ID DWORD 4 : 24EC3015 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : A8C1D671 CRC 1 : 3E691FF8 Checksum 67 SearchForBootstrap_DCT5.. Boot File MATCH : RAPIDOv11_2nd.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 BB5ProtocolType == : New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" CCFF48DA090000000900 TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0030 -> K5W1G13ACB Extended/Fixed ID : 0000 Revision ID : 0121 Checksum : 25 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Algo File MATCH : RAPIDOv11_XSR15_alg.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) VPP Enabled by Software Using Internal VPP VPPSwitchInfo : VPP1 VPP_GENERATED_IN_PROMMER - VPP2 VPP_GENERATED_IN_PROMMER CMT Does Not Support 12V VPP CMT Does Not Support Group Erase VPP Enabled by Software 00 unsupported VPP Voltage setting Using Internal VPP SendFlashVoltageInit_DCT5 VPP1 0000 VPP2 0000 FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 000FE1BA92D924A658E4800780FA6F4868100AC947 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) Certificate 1 Name : NPC ASIC Index : CMT 0 Certificate 2 Name : CCC ASIC Index : CMT 0 Certificate 3 Name : HWC ASIC Index : CMT 0 Certificate 4 Name : R&D ASIC Index : CMT 0 STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D7 STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5... Partition Info Partition Blocks : 1 1 PARTITION_INFO_BB5 BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Partition Version : 00010000 Spare : FFFFFFFF Num Partitions : 00000004 Partition 1 ID : 00000003 COPIEDOS Attribute : 00000002 RO Start Address : 00080000 Size : 01480000 Partition 2 ID : 00000004 DEMANDONOS Attribute : 00000002 RO Start Address : 01500000 Size : 03900000 Partition 3 ID : 00000008 FILESYSTEM Attribute : 00000001 RW Start Address : 04E00000 Size : 02D40000 Partition 4 ID : 0000000A Attribute : 00000001 RW Start Address : 07B40000 Size : 00160000 PARTITION_INFO_REQUEST_BB5 PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00) ProcessPartitionInfo_DCT5 : No Error - 0 (0x00) StartErase_DCT5... BlockLength : 0x004F (79) ERASE Blocks : 0x0002 (2) 0 ERASE_AREA_BB5 0x12 Block Length : 0x1B (27) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 00040000-00082FFF 1 : 00083400-0087FFFF 2 : 00B80000-04DFFFFF 1 FORMAT_PARTITION_BB5 0x19 Block Length : 0x2F (47) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 Format Info ID :0x00000000 Format Info :000000000000000A000000000000000200000064000000030000000100000001000000000000 ERASE_REQUEST_BB5 : 5003120B0003000004000000082FFF120B000300000834000087FFFF120B00030000B8000004DFFFFF08 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 ERASE_REQUEST_BB5 : 5001192F00030000000000000000000000000A0000000000000002000000640000000300000001000000010000000000003E Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. Is Flashing CLOCK AUTO : -1 CCFF48DA3C0000003C00 Processing : rm243_06.51_prd_core.fpsx Total blocks to write : 385 >> CMT Rootkey Hash CERT : ADA >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : RAP3NAND >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : SOS*UPDAPP >> CMT Rootkey Hash CERT : SOS*DSP0 >> CMT Rootkey Hash CERT : SOS*ISASW >> CMT Rootkey Hash CERT : SOS*CORE >> CMT Rootkey Hash CERT : SOS+ROFS ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:31 Making delay between files for 7000ms Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-243\rm243_06.51_prd_vB01_01_euro1.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101002003 > 400C192101002003 > 0003192101002003 > 000C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101011105 > 400C192101011105 > 4003192101021105 > 400C192101021105 > 400C192101031105 > 4003192101031105 > 4003192101031103 > 400C192101031103 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 180 Entry Point: 0x011A Page Format : -1 MAX PAGE : 0x00020000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417160 (0x08) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01021103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 15100004 ID DWORD 1 : 98630052 ID DWORD 2 : F9AF5719 ID DWORD 3 : 4F494759 ID DWORD 4 : 24EC3015 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : A8C1D671 CRC 1 : 3E691FF8 Checksum 67 SearchForBootstrap_DCT5.. Boot File MATCH : RAPIDOv11_2nd.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 BB5ProtocolType == : New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" CCFF48DA090000000900 TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0030 -> K5W1G13ACB Extended/Fixed ID : 0000 Revision ID : 0121 Checksum : 25 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Algo File MATCH : RAPIDOv11_XSR15_alg.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) VPP Enabled by Software Using Internal VPP VPPSwitchInfo : VPP1 VPP_GENERATED_IN_PROMMER - VPP2 VPP_GENERATED_IN_PROMMER CMT Does Not Support 12V VPP CMT Does Not Support Group Erase VPP Enabled by Software 00 unsupported VPP Voltage setting Using Internal VPP SendFlashVoltageInit_DCT5 VPP1 0000 VPP2 0000 FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 000FE1BA92D924A658E4800780FA6F4868100AC947 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE No partition info.... StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 03300000-04DFFFFF ERASE_REQUEST_BB5 : 5001120B0003000330000004DFFFFFCA Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. Is Flashing CLOCK AUTO : -1 CCFF48DA3C0000003C00 Processing : rm243_06.51_prd_vB01_01_euro1.fpsx Total blocks to write : 180 >> CMT Rootkey Hash CERT : SOS+ROFX ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:15 Making delay between files for 7000ms Processing Image File : C:\Program Files\Nokia\Phoenix\Products\RM-243\rm243_06.51_prd_uda_v01_EM46_luxgsm_lu.fpsx CMT Type : BB5 CMT Algorithm : XSR 1.5 CMT Supported Hardwares : > 4003192101002003 > 400C192101002003 > 0003192101002003 > 000C192101002003 > 4003192101011103 > 400C192101011103 > 4003192101021103 > 400C192101021103 > 4003192101011105 > 400C192101011105 > 4003192101021105 > 400C192101021105 Secondary Sending Speed : 650000Hz Algorithm Sending Speed : 13000000Hz Program Sending Speed : 13000000Hz Message Reading Speed : 98000Hz Number of Blocks : 55 Entry Point: 0x00F4 Page Format : -1 MAX PAGE : 0x00020000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417160 (0x08) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 400C1921 ID DWORD 4 : 01021103 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000295 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000B22 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 15100004 ID DWORD 1 : 98630052 ID DWORD 2 : F9AF5719 ID DWORD 3 : 4F494759 ID DWORD 4 : 24EC3015 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : CA EE BB 65 D3 C4 8E 6D C7 3B 49 DC 50 63 A2 EE 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : A8C1D671 CRC 1 : 3E691FF8 Checksum 67 SearchForBootstrap_DCT5.. Boot File MATCH : RAPIDOv11_2nd.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 BB5ProtocolType == : New PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0" PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0" CCFF48DA090000000900 TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000) MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 05 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : RAM 05 Device Index : 00 Manufacturer Code : 0000 -> Flash Device ID : 0000 -> Not detected Extended/Fixed ID : 0000 Revision ID : 0000 2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0400 -> Flash Device ID : 0000 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 0000 4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 01 Manufacturer Code : 0000 -> SPANSION Device ID : 0001 -> Not used Extended/Fixed ID : 0000 Revision ID : 0000 5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MuxOneNAND 03 Device Index : 00 Manufacturer Code : 00EC -> Device ID : 0030 -> K5W1G13ACB Extended/Fixed ID : 0000 Revision ID : 0121 Checksum : 25 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... Algo File MATCH : RAPIDOv11_XSR15_alg.fg Boot File - Version : 009.048.000 Boot File - Revision : 0x0200 Algo Loader Sent... SendCodeStart_NewProtocol : SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5_NewProtocol TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0 TransmissionTypeRequest_DCT5_NewProtocol FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready) VPP Enabled by Software Using Internal VPP VPPSwitchInfo : VPP1 VPP_GENERATED_IN_PROMMER - VPP2 VPP_GENERATED_IN_PROMMER CMT Does Not Support 12V VPP CMT Does Not Support Group Erase VPP Enabled by Software 00 unsupported VPP Voltage setting Using Internal VPP SendFlashVoltageInit_DCT5 VPP1 0000 VPP2 0000 FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4 Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 000FE1BA92D924A658E4800780FA6F4868100AC947 Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01) Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only) No RESTORE CERTIFICATE FOUND IN IMAGE FILE No partition info.... StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x03 MuxOneNAND Device Index : 0x00 0 : 04E00000-07B3FFFF ERASE_REQUEST_BB5 : 5001120B00030004E0000007B3FFFF42 Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 Successfully erased.. Is Flashing CLOCK AUTO : -1 CCFF48DA3C0000003C00 Processing : rm243_06.51_prd_uda_v01_EM46_luxgsm_lu.fpsx Total blocks to write : 55 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 15 STATUS_NAND_OK_BB5 Block Length : 0F BB ASIC Index : 00 Device Type : 03 Device Type : 00 Num Bad Blocks : 00000000 Additional Bad : 00000000 Correctable ECC : 00000000 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:06 Rebooting Box ... AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : E43C85E1F5CD8A8BD157919B BOX ACTIVATED DDR DELAY : 01 INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... Waiting for phone to Power On, 8000 ms delay Changing MODE : UART Reading Phone Information... MCU SW version : V 06.51 04-02-09 RM-243 (c) Nokia HW version : 0801 PCI version : RFIC version : 17141715 DSP version : 06w41pb_08w28.0.1_rm243 Retu version : 15 Tahvo version : 22 Production serial number : MBH786039 Product code : 0541799 Module code : Basic production code : 0548116 Flash code : Order number : Product specific data : Long production SN : 0 ATO : IMEI plain : 359807019734495 IMEI spare to net : 3A 95 08 07 91 37 44 09 IMEI SV to net : 33 95 08 07 91 37 44 59 F0 Simlock Version : SIMLOCK SERVER CONFIG KEY: 0000000000000000 PROVIDER KEY: 5150300000000000 Provider : Smart Communications;Philippines Counters : 0/3 , 0/10 Block [1] 1:Close Block [2] 1:Close SP Lock Status : Locked |
The Following 9 Users Say Thank You to who am i For This Useful Post: |
02-18-2010, 06:06 | #12 (permalink) |
Freak Poster Join Date: Mar 2005 Location: inside USB cable Age: 41
Member: 128122 Status: Offline Thanks Meter: 256 | 3110c Full flashing. History. Unit is dead when its came to my hands. Here is the logs RPL Backup Code: AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : B57E17A0C7A4ED6DC97700D0 BOX ACTIVATED DDR DELAY : 01 INIT : OK AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417216 (0x40) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 22100118 ID DWORD 1 : 6F3B7E56 ID DWORD 2 : D99EEABA ID DWORD 3 : 8EF51967 ID DWORD 4 : B6767016 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum 76 SearchForBootstrap_DCT5.. Boot File MATCH : RAP3Gv3_2nd.fg Boot File - Version : 009.011.001 Boot File - Revision : 0x0000 BB5ProtocolType == : Original MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8981 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 82 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... File MATCH : RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) START READING RPL DATA Reading : NPC OK Reading : VARIANT OK Reading : CCC OK Reading : HWC OK FINISHED READING RPL DATA RPL saved to: D:\Advance\AdvanceBox\Nokia\RPL\221001186F3B7E56D99EEABA8EF51967B6767016_82652.rpl Flashing Speed Setting is set to 5mhz. Code: AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : B57E17A0C7A4ED6DC97700D0 BOX ACTIVATED DDR DELAY : 01 INIT : OK Changing MODE : FLASH Processing Image File : D:\UFS,JAF, Cyclone Flashfiles\3110c\rm237__07.21.mcusw CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 944 Entry Point: 0x44FC Page Format : -1 MAX PAGE : 0x00004000 AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : B57E17A0C7A4ED6DC97700D0 BOX ACTIVATED DDR DELAY : 01 INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417216 (0x40) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 22100118 ID DWORD 1 : 6F3B7E56 ID DWORD 2 : D99EEABA ID DWORD 3 : 8EF51967 ID DWORD 4 : B6767016 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum 76 SearchForBootstrap_DCT5.. Boot File MATCH : RAP3Gv3_2nd.fg Boot File - Version : 009.011.001 Boot File - Revision : 0x0000 BB5ProtocolType == : Original MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8981 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 82 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... File MATCH : RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x004E (78) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x4B (75) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 00000000-000006BF 1 : 000006C0-0001FFFF 2 : 00020000-0007FFFF 3 : 00080000-000DFFFF 4 : 00100000-001FFFFF 5 : 00200000-0031FFFF 6 : 00320000-0105FFFF 7 : 01060000-01067FFF 8 : 01068000-0107FFFF ERASE_REQUEST_BB5 : 5001124B00000000000000000006BF000006C00001FFFF000200000007FFFF00080000000DFFFF00100000001FFFFF002000000031FFFF003200000105FFFF0106000001067FFF010680000107FFFF32 Please wait ERASING......... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:16 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 Processing : rm237__07.21.mcusw Total blocks to write : 944 >> CMT Rootkey Hash CERT : NOLO >> CMT Rootkey Hash CERT : KEYS >> CMT Rootkey Hash CERT : PRIMAPP >> CMT Rootkey Hash CERT : PASUBTOC >> CMT Rootkey Hash CERT : PAPUBKEYS >> CMT Rootkey Hash CERT : UPDAPP >> CMT Rootkey Hash CERT : DSP0 >> CMT Rootkey Hash CERT : MCUSW >> CMT Rootkey Hash CERT : PMM_CONF >> CMT Rootkey Hash CERT : SBIF_CONF ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 1 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:44 Making delay between files for 10ms Processing Image File : D:\UFS,JAF, Cyclone Flashfiles\3110c\rm237__07.21.ppm_v CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 279 Entry Point: 0x00A6 Page Format : -1 MAX PAGE : 0x00004000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417216 (0x40) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 22100118 ID DWORD 1 : 6F3B7E56 ID DWORD 2 : D99EEABA ID DWORD 3 : 8EF51967 ID DWORD 4 : B6767016 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum 76 SearchForBootstrap_DCT5.. Boot File MATCH : RAP3Gv3_2nd.fg Boot File - Version : 009.011.001 Boot File - Revision : 0x0000 BB5ProtocolType == : Original MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8981 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 82 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... File MATCH : RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01080000-0151FFFF ERASE_REQUEST_BB5 : 5001120B000000010800000151FFFF88 Please wait ERASING......... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:00:22 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 Processing : rm237__07.21.ppm_v Total blocks to write : 279 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:10 Making delay between files for 10ms Processing Image File : D:\UFS,JAF, Cyclone Flashfiles\3110c\rm237__07.21.image_v CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 320 Entry Point: 0x00B2 Page Format : 0 MAX PAGE : 0x00004000 File detected Not 128K format.... Converting image to 128k bit..... Converted file created : D:\UFS,JAF, Cyclone Flashfiles\3110c\rm237__07.21.image_v_128k CMT Type : BB5 CMT Algorithm : BB5 ALGORITHM CMT Supported Hardwares : > 0103192101001101 > 010C192101001101 Secondary Sending Speed : 3250000Hz Algorithm Sending Speed : 6500000Hz Program Sending Speed : 6500000Hz Message Reading Speed : 98000Hz Number of Blocks : 320 Entry Point: 0x00B2 Page Format : 0 MAX PAGE : 0x00004000 AdvanceFBox SendBootCodeEx InitialiseBootstrap_DCT5 DIR BootFlashMode_DCT5 BootFlashModeDCT5Ex Succeeded First Time SYSTEM_ID_RESPONSE_BB5 (0xC0) - 2010417216 (0x40) bytes returned Number of Sub Blocks 7 (0x07) 1 SYSTEM_ASIC_ID 01 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000001 ID DWORD 1 : 00000226 ID DWORD 2 : 00010006 ID DWORD 3 : 010C1921 ID DWORD 4 : 01001101 2 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000232 3 ROM_ID 15 Block Length : 5 (05) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 00000353 4 PUBLIC_ID 12 Block Length : 21 (15) BB ASIC Index : 0 (00) CMT ID DWORD 0 : 22100118 ID DWORD 1 : 6F3B7E56 ID DWORD 2 : D99EEABA ID DWORD 3 : 8EF51967 ID DWORD 4 : B6767016 5 ASIC_MODE_ID 13 Block Length : 2 (02) BB ASIC Index : 0 (00) CMT Mode Id : 00 6 ROOT_KEY_HASH 14 Block Length : 17 (11) BB ASIC Index : 0 (00) CMT Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1 7 ROM_ID 15 Block Length : 9 (09) BB ASIC Index : 0 (00) CMT CRC 0 : 191EC665 CRC 1 : DFAAF68F Checksum 76 SearchForBootstrap_DCT5.. Boot File MATCH : RAP3Gv3_2nd.fg Boot File - Version : 009.011.001 Boot File - Revision : 0x0000 BB5ProtocolType == : Original MCU_CONFIGURATION_RESPONSE_BB5: MessageID : C1 SubBlocks : 03 1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Manufacturer Code : 0089 -> Device ID : 8981 -> Type not in database Extended/Fixed ID : 0000 Revision ID : 6A21 2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5 Block Length : 13 BB ASIC Index : CMT 00 Device Type : NOR 00 Device Index : 00 Device Contents : 00000000000000000000 3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5 Block Length : 0B BB ASIC Index : CMT 00 Device Type : MMC 04 Device Index : 00 Manufacturer Code : FFFF -> Flash Device ID : 0000 -> BAD FLASH TYPE Extended/Fixed ID : 0000 Revision ID : 0000 Checksum : 82 SearchForBootstrap_DCT5 : No Error - 0 (0x00) FLS1SendAlgoCodeEx.. SendAlgoCode_DCT5.. SearchForAlgorithm_DCT5.. Looking for ALL Devices... File MATCH : RAP3Gv3_algo.fg SearchForAlgorithm_DCT5 : No Error - 0 (0x00) TransmissionTypeRequest_DCT5... SuggestedType : 01 16BIT TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC ReturnedType : 01 16BIT TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Uploading ALGO File... SendAlgoCodeFile_DCT5 : No Error - 0 (0x00) Pabub KEY Request PhoneInfoRequest_BB5 (Asic Index 00 ) PHONE_INFO_RESPONSE_BB5 PAPUB_KEYS_HASH_RESP_BB5 2A BB Asic Index : 01 PAPUB Keys Hash : 00C0E691EA16A7593A9BB28832D7312A39F7ED668D No partition info.... VPP Enabled by Software Using Internal VPP StartErase_DCT5... BlockLength : 0x000E (14) ERASE Blocks : 0x0001 (1) 0 ERASE_AREA_BB5 0x12 Block Length : 0x0B (11) BB ASIC Index : 0x00 CMT Device Type : 0x00 NOR Device Index : 0x00 0 : 01520000-01FDFFFF ERASE_REQUEST_BB5 : 5001120B0000000152000001FDFFFF92 Please wait ERASING......... Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 Successfully erased.. Time Taken to Erase : 00:01:10 TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9 ReturnedType : 04 DDRand2TX TransmissionTypeRequest_DCT5 : No Error - 0 (0x00) Is Flashing CLOCK AUTO : 0 Processing : rm237__07.21.image_v_128k Total blocks to write : 320 ContinueFlash_DCT5 Complete Status_BB5 STATUS_REQUEST_BB5.. 1 Sub Block ID : 14 STATUS_NOR_OK_BB5 Block Length : 01 BB ASIC Index : 00 FlashInfo.RestartMode : 2 Continue Flash Complete : : No Error - 0 (0x00) Time Taken to Flash : 00:00:11 Rebooting Box ... AdvanceBox Turbo Flasher Found Initialize Device.... Init TRY : 1 Changing Clock to 15mhz.. Box Name : AdvanceBox Turbo Box Firmware : LogiCore 1.16.10 Software Version : v2010.0.1.21 AdvanceBox SN : B57E17A0C7A4ED6DC97700D0 BOX ACTIVATED DDR DELAY : 01 INIT : OK VBATT OFF ... VBATT ON Setting VBATT Done!... Waiting for phone to Power On, 8000 ms delay Changing MODE : UART Reading Phone Information... MCU SW version : V 07.21 05-11-08 RM-237 (c) Nokia. HW version : 5008 PCI version : RFIC version : 17211721 DSP version : ICPR61_08w10 Retu version : 32 Tahvo version : 53 Production serial number : MPG658639 Product code : 0514947 Module code : 0203291 Basic production code : 0542523 Flash code : Order number : Product specific data : Long production SN : ATO : IMEI plain : 351963030087773 IMEI spare to net : 3A 15 69 03 03 80 77 07 IMEI SV to net : 33 15 69 03 03 80 77 27 F5 Simlock Version : SIMLOCK SERVER VERSION 63 CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked |
The Following 8 Users Say Thank You to dr_aybyd For This Useful Post: |
02-18-2010, 06:10 | #13 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | pls mention model and total time taken complete flash |
The Following 5 Users Say Thank You to akhil_bbsr For This Useful Post: |
02-18-2010, 06:14 | #14 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Philippines
Member: 324705 Status: Offline Thanks Meter: 192 | thats why they say TURBO FLASHER.... wow nice box!!! hope we can avail this here in the philippines... coder said that..its not available here in the philippines... |
The Following 4 Users Say Thank You to dyowei For This Useful Post: |
02-18-2010, 06:19 | #15 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: around the globe
Member: 418852 Status: Offline Sonork: 100:1587670 Thanks Meter: 839 | Quote:
please go to sticky thread on this section for Resellers list.. or.. reseller will auto detect your IP address and look for a reseller for you please go to www.advance-box.com/index.php?p=reseller br frozenice | |
The Following 13 Users Say Thank You to frozenice For This Useful Post: |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
