Post here successfully unlocked lumia phones with ATF JTAG Lumia 610 Successfully Unlocked Via ATF Jtag http://img59.imageshack.us/img59/4223/f9am.jpg http://img194.imageshack.us/img194/3209/8auq.jpg Code: Default language ID 0x0409 LEMOR Edit: Thread was cleaned with off-topic posts, DO NOT post any question in this thread only successfully unlocked lumia phones via JTAG. :-) |
Unlock Done nokia Lumia 505 Thx.. ATF-Team good work. http://i44.tinypic.com/29urrf4.png ______________ Regards! MobileZone |
Unlock Nokia Lumia 610. http://www.subeimagenes.com/thumb/610-784518.jpg Subido en subir imagenes ______________ Regards! MobileZone |
Yeah I had a lumia 610 from tesco uk which one wont accepting codes read by from atf sofware. for details check log below ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...Retry Resetting and Exploring JTAG chain...No Devices found in Chain! Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...No Devices found in Chain! Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN Unlock Code: 81098268 PUK Unlock Code: 95704022 ========================= Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== All Done!OK These code wont work for mine unit so i try some trick like I did flash unit but failure then back flash to original pc but same then i made disturb my dear friend,teacher x-shadow ( Advance-Box ) at sonork, i found him kind as well as he always and he solve mine problem with his own method using a spacial file after he calculate code via his method its great as new code unlock mine unit in first attempt. :D I am thank full to my Freind Advance-Box. warm regards. |
thank you for all 3 Attachment(s) thank you for all please use lumia 610 unlock error http://174.120.45.27/tmp/610_610C_510_505_UNLOCK.rar |
Lumia 510 tesco Lock Unlock Successfully ATF Jtag |
Here is Tesco Uk Locked 510 Unlock Done With This New APF File Prefect http://i40.tinypic.com/246l5ph.jpg |
Nokia lumia 610 tesco successfully unlock ATF team is the best i succsessfully unlock nokia lumia 610 today locked on tesco mobile here is log http://s29.postimg.org/g7tzte4x3/lumia_610_unlock.jpg http://postimg.org/image/7ct5ivg4j/ Zubair ZK MOBILES LTD UK |
Lumia 510 successfully unlocked codes accept O2 Tesco: |
1 Attachment(s) my first nokia 610 unlock done |
Hi, Next Time use this file: http://174.120.45.27/tmp/610_610C_51..._UNLOCK_V2.rar This will read all 5 Lock Levels... Sometimes the phone is locked to more than 1 lock level, in that case your AFP file will not be able to read it. B.R. |
