12-16-2013, 11:58 | #46 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Pakistan
Member: 1417911 Status: Offline Sonork: 100.109719 Thanks Meter: 128 | Lumia 610 Unlock Done Successfully ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button, then Connect USB Cable ---------------------------------------------------------- Waiting for Device Connection 10 second(s)... OK Resetting and Exploring JTAG chain... OK Halting Core... OK Initializing Device... 1. Disconnect USB Cable from Phone 2. Reconnect USB Cable to Phone 3. Wait for 15 Seconds after First Vibration <--- Very Important 4. Disconnect USB Cable from Phone 5. Click RESTORE BOOT Button Again OK Waiting for Device Connection 10 second(s)... OK Resetting and Exploring JTAG chain... OK Halting Core... OK Initializing Device... Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN LEVEL 1: 93981024 - LOCKED PUK LEVEL 1: 60007960 - LOCKED PIN LEVEL 2: 94678091 PUK LEVEL 2: 13818476 PIN LEVEL 3: 14406694 PUK LEVEL 3: 22073644 PIN LEVEL 4: 64159507 PUK LEVEL 4: 80972540 PIN LEVEL 5: 42957365 PUK LEVEL 5: 47303808 ========================= Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== All Done!OK Last edited by .:Gsm_Expert:.; 12-16-2013 at 12:04. |
12-18-2013, 16:24 | #48 (permalink) |
No Life Poster Join Date: Jan 2005 Location: PT Age: 40
Member: 108180 Status: Offline Sonork: 100.106866 Thanks Meter: 381 | Lumia 610 unlock OK Loading AFP (Please Wait)...OK AFP revision 4, compiled 02-12-2013 10:01:00 ================================================== ======== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button, then Connect USB Cable ---------------------------------------------------------- Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... 1. Disconnect USB Cable from Phone 2. Reconnect USB Cable to Phone 3. Wait for 15 Seconds after First Vibration <--- Very Important 4. Disconnect USB Cable from Phone 5. Click RESTORE BOOT Button Again OK Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN LEVEL 1: 03530966 - LOCKED PUK LEVEL 1: 59218946 - LOCKED PIN LEVEL 2: 45601649 PUK LEVEL 2: 10015448 PIN LEVEL 3: 12935603 PUK LEVEL 3: 34995594 PIN LEVEL 4: 31270438 PUK LEVEL 4: 61035312 PIN LEVEL 5: 63144029 PUK LEVEL 5: 00143825 ========================= Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ================================================== ========================== All Done!OK B.r guedes666 |
12-23-2013, 04:06 | #51 (permalink) |
No Life Poster Join Date: Jul 2009 Location: Ganimedes
Member: 1067814 Status: Offline Sonork: 100.1618982 Thanks Meter: 82 | ================================================== ======== Phone Type : Lumia 900 RM-808, RM-823 Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Automatic Counter Reset (If Needed) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY Flex Cable 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to Phone 5. Use RESET JTAG button to check the JTAG Connection 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- Resetting and Exploring JTAG chain...2 Device(s) Device #1 ID 0x100590E1 IR7 Device #2 ID 0x203F10E1 IR4 Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting ONFI #1 ID...MICRON MT29F1G08ABBDAH4, 128 MiB Sending Flash Loader...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 58012894 ACTIVE Level 1 PUK: 73787780 ACTIVE Level 2 PIN: 76110981 Level 2 PUK: 54592011 Level 3 PIN: 11010328 Level 3 PUK: 03981713 Level 4 PIN: 67926339 Level 4 PUK: 24014713 Level 5 PIN: 11991082 Level 5 PUK: 70258618 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears This is PERMANENT UNLOCK... Flashing will NOT RE-LOCK PHONE ================================================== ========================== |
12-30-2013, 04:14 | #55 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
Use this: http://174.120.45.27/tmp/610_610C_51..._UNLOCK_V2.rar | |
12-31-2013, 08:59 | #57 (permalink) |
No Life Poster Join Date: Feb 2004 Location: DZ W09 Age: 43
Member: 53408 Status: Offline Sonork: 100.1593951 Thanks Meter: 1,261 | Code: Default language ID 0x040C JTAG Interface Connected, S/N Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 4, compiled 02/12/2013 10:01:00 ========================================================== Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported : Lumia 510 RM-889 - Supported : Lumia 510 RM-898 - Supported : Lumia 505 RM-923 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ========================================================== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click RESTORE BOOT button, then Connect USB Cable ---------------------------------------------------------- Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... 1. Disconnect USB Cable from Phone 2. Reconnect USB Cable to Phone 3. Wait for 15 Seconds after First Vibration <--- Very Important 4. Disconnect USB Cable from Phone 5. Click RESTORE BOOT Button Again OK Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device... Searching for PIN/PUK Unlock Codes... Please wait for a while... Codes Found! ========================= PIN LEVEL 1: 34272767 - LOCKED PUK LEVEL 1: 61982402 - LOCKED PIN LEVEL 2: 18455350 PUK LEVEL 2: 47784312 PIN LEVEL 3: 20494180 PUK LEVEL 3: 15632157 PIN LEVEL 4: 42968318 PUK LEVEL 4: 33817271 PIN LEVEL 5: 19550607 PUK LEVEL 5: 61041680 ========================= Reading Unlock Codes Done! ============================================================================ 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ============================================================================ |
12-31-2013, 16:42 | #58 (permalink) |
Freak Poster Join Date: Mar 2011
Member: 1527517 Status: Offline Sonork: 100.1607096 Thanks Meter: 9 | lumia610 Phone Type : Lumia 610 RM-835 - Supported : Lumia 610 RM-849 - Supported : Lumia 610C RM-836 - Supported Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Disconnect USB Cable before Reading Codes ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 42650260 ACTIVE Level 1 PUK: 13835346 ACTIVE Level 2 PIN: 63720048 Level 2 PUK: 50602800 Level 3 PIN: 37419770 Level 3 PUK: 32817258 Level 4 PIN: 57721878 Level 4 PUK: 21958879 Level 5 PIN: 85351453 Level 5 PUK: 77895960 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears Write Down 8-digit PIN CODE on a piece of paper and attach it to the phone under the battery. This will allow the owner of the phone to unlock this phone again if he will flash the phone firmware in the future. ============================================ |
