01-03-2014, 23:21 | #63 (permalink) |
No Life Poster Join Date: Apr 2013 Location: morocco Age: 36
Member: 1917054 Status: Offline Thanks Meter: 268 | 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY 3. Connect RJ-45 JTAG Cable to ATF Box 4. Disconnect USB Cable from the Phone 5. DO NOT click RESET JTAG button 6. Click READ CODES button to Start Reading Unlock Codes ---------------------------------------------------------- Disconnect USB Cable from Phone (If Connected) Re-Connect USB Cable to Phone... Connect USB Cable to Phone...OK USB Connected! Waiting for First Event...OK Disconnect USB Cable Now...OK Re-Connect USB Cable to Phone... Waiting for Device Connection 10 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 44816405 ACTIVE Level 1 PUK: 96958981 ACTIVE Level 2 PIN: 62803232 Level 2 PUK: 81106653 Level 3 PIN: 49442390 Level 3 PUK: 03529142 Level 4 PIN: 72777975 Level 4 PUK: 27547633 Level 5 PIN: 58055201 Level 5 PUK: 35644919 =================================== Reading Unlock Codes Done! |
01-15-2014, 18:58 | #70 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Unlock Lumia 900 Default language ID 0x0416 JTAG Interface Connected, S/N 0x81XXXXXE Resetting and Exploring JTAG chain...No Devices found in Chain! Loading AFP (Please Wait)...OK AFP revision 3, compiled 23/09/2013 19:35:00 ================================================== ======== Phone Type : Lumia 900 RM-808, RM-823 Unlock Type : Read PIN and PUK Unlock Codes Other Notes : Automatic Counter Reset (If Needed) ================================================== ======== 1. Make sure JTAG Connection is 100% OK 2. Always Disconnect the Phone BATTERY Flex Cable 3. Connect RJ-45 JTAG Cable to ATF Box 4. Connect USB Cable to Phone 5. Use RESET JTAG button to check the JTAG Connection 6. Click RESTORE BOOT button to Start Reading Unlock Codes ---------------------------------------------------------- Waiting for Device Connection 20 second(s)...OK Resetting and Exploring JTAG chain...OK Halting Core...OK Initializing Device...OK Detecting ONFI #1 ID...MICRON MT29F1G08ABBDAH4, 128 MiB Sending Flash Loader...OK Retrieving Unlock Codes...OK =================================== Service Provider Unlock Codes Found =================================== Level 1 PIN: 86810208 Level 1 PUK: 28137340 Level 2 PIN: 30096370 Level 2 PUK: 48322719 Level 3 PIN: 50591669 Level 3 PUK: 03667757 Level 4 PIN: 56198127 Level 4 PUK: 19312744 Level 5 PIN: 05084376 Level 5 PUK: 39743939 =================================== Reading Unlock Codes Done! ================================================== ========================== 1. Remove JTAG Connection and Assemble Phone 2. Insert SIM Card from different Provider into the Phone 3. Power ON the Phone 4. Enter 8-digit PIN Code or 8-digit PUK Code when Phone Requires it 5. After Code is accepted, wait 30 seconds until Operator Signal Appears This is PERMANENT UNLOCK... Flashing will NOT RE-LOCK PHONE |
