08-11-2013, 20:53 | #1 (permalink) |
Freak Poster Join Date: Sep 2012 Location: south africa Age: 39
Member: 1813139 Status: Offline Thanks Meter: 45 | atf network activation problem i have a problem with my atf box its just finish the 1st network activation on last weak so i try to buy new activation via pay pall account so now they cut my money but its still not activate may be it will take some time but i need urgent activation so plz help its 2nd day not active thanx |
08-11-2013, 21:09 | #2 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Free Palestine
Member: 330579 Status: Offline Thanks Meter: 67,515 | Quote:
Regards | |
08-11-2013, 21:32 | #3 (permalink) | |
Member: 1813139 Status: Offline Thanks Meter: 45 | Quote:
thanx for reply so which means my 49 usd is gone but my box is activated its showing ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00020824 Library Version : 00030207 Box Type : ATF Lightning Box Firmware : LogiCore 10.3.70 Software Version : v10.00 AdvanceBox SN : ......................... Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done my problem is atf network activation not box activation coz its still activated thanx | |
08-11-2013, 22:55 | #6 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | If you had credits on your box than you will get them for sure and as well the activation if you had... don't worry, you will not lose anything. More about server you will find here: http://forum.gsmhosting.com/vbb/f609...-down-1698734/ |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
