Puk code request in LUMIA 900, i can solve whith UNLOCK PHONE? Hello, i've one Lumia AT&T, first was requesting Pin code, AT&T sended this Pin code, but now, after many attempt, this Nokia require Puk Code how procedure. Can reset it whith Flash ATF?, Unlock via TP or Jtag isn't too supported!! In other word, it isn't supported by TP or JTAG Unlock, if i unlock for other way, Phone Requiere always this Puk Code? tkx for reply br Max |
Hi, some of Lumia 900 can unlock with PIN code and some with PUK code. If provided code doesn't work on PIN -saying "incorrect PIN code". Then use the same provided code on PUK - it works this way. BR |
The first Pin Code by AT&T was working, but the user had enter more of 10 attempt this Pin Code and Now phone requiere PUK CODE, pardon my English, but if i send now request for Full Unlock Code, seen isn't too supported by Atf, can Unlock this Lumia 900?, tx Br Max |
i have same problem can atf do magic on this?? |
Just reinstall the software of your Lumia, I already do this trick with Lumia 610/800. |
@Spreewel Lumia 610 can reset counter via flashing? |
@ALL 1. Lumia 900 RM-808 and RM-823 will not RESET COUNTERS after flashing. This trick is NOT WORKING FOR THIS PHONE. 2. If you bought AT&T Code in eBay, then there is a BIG CHANCE it is PUK Code and not PIN Code. |
what about lumia 610:? |
@sharaz191 Working on all WP7 except Lumia 900... So any WP7 will reset counters,, except Lumia 900. |
i have a lumia 900 with sim disabled by wrong unlock codes inserted.. How i can enter the unlock code now? |
Br - srinibas |
@ALL Maybe some solution will be released tomorrow (9-24-2013)... OR maybe nothing at all... Just wait 36 hours to see if something will be released... If nothing, then give phone back to Customer. B.R. |
