02-18-2013, 16:46 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: bahrain
Member: 587083 Status: Offline Thanks Meter: 31 | advance box. cant install windows 7 64bit help any idea how to fix please thanks for the respond advance team |
02-19-2013, 09:19 | #2 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
Br - srinibas | |
The Following User Says Thank You to srinibas For This Useful Post: |
02-19-2013, 19:42 | #5 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | @ner21 This means ATF Drivers are not installed.... Connect ATF Box with PC, Windows will ask for the drivers, give this path: "C:\AdvanceBox Turbo Flasher\Drivers\ATF_NEW_Drivers" Once drivers are installed, re-connect ATF Box and open EXE ! BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
02-20-2013, 07:07 | #6 (permalink) |
Member: 587083 Status: Offline Thanks Meter: 31 | problem Solved sir using this file FTD2XX download this file open drive C/then open \windows\ paste/to folder /system32. then finaly work fine... thanks to all respond ATF team kindly closed this thread |
