05-05-2015, 16:10 | #17 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | i m going to start goat farming next year investors are welcome |
The Following 7 Users Say Thank You to chand_gee For This Useful Post: |
05-07-2015, 18:31 | #21 (permalink) |
Junior Member Join Date: Apr 2015 Location: Russia Petrovsk-Zabaikalsk
Member: 2375933 Status: Offline Thanks Meter: 0 | eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. WARNING: Wrong Test Point Connected! 0x00EE4321 |
05-09-2015, 10:22 | #24 (permalink) |
Member: 2375933 Status: Offline Thanks Meter: 0 | [QUOTE=chand_gee;11029292]Write EXT_CSD file https://mega.co.nz/#!tIkWgCaK!vXpXDL...Rwq8vEZpJr79u0 error link does not work |
05-09-2015, 10:46 | #25 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | [QUOTE=WWWmomentoWWW;11039042] Quote:
if isn't clear use google and search about this. | |
05-09-2015, 11:24 | #26 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @chand_gee, ok i've understand that you have used VCC and VCCQ with a unique wires from old photo for VCC and VCCQ... giving 2.8V how always, it's very clear!!! From other near capacitor you have find TP that goes under eMMc .... for to do it you have solder this wire to this piece of pole with the tip very thin but also other wire for connect this TP to GND is right?.... becouse from you first photo you show only one pole with double wires and stop.... I not have tryed for my time problem... but i think that also you remove glue, (is small thingh this), you not need of warm up a bit the emmc for enter this pole.... are only asking, repeat not have tryed too...also have a couple of these eMMc for repair... Can answere please to this question?, P.d. this you call "Coil" after removed you must need od resolder or can leave w/o it?... BR allumts |
05-09-2015, 15:21 | #27 (permalink) |
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | @allumts one single wire from adapter <2.8v> conect to vcc and vccq on board is also working for me.. TP is under emmc and its not connected to any parts on-board in picture i draw a line for highlight instruction in box.. its not for capacitor no need heat for warm up emmc.glue is removable easily removing coil is not effect on power or any emmc or odin operation butt putt back after done |
The Following User Says Thank You to chand_gee For This Useful Post: |
05-09-2015, 21:23 | #28 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @chand_gee, ok for you answer....was how i had thinked from the first day of TP under eMMc to Gnd... nothingh of new at the end..you have used a pole instead of one very small wire... Yes..of course how me you use only one wire for VCC and VCCQ connected in 2.80V in adapter...ok when have a little of time want to try to repair w/o BGA adapter.... BR allumts |
05-10-2015, 00:50 | #29 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Abidjan Age: 38
Member: 1418143 Status: Offline Thanks Meter: 353 | VCC and VCCQ connected with one wire it meaning we should short both ? I tried one today without success , but me I used separate wire for VCC and VCCQ ! I wanna know if that's why I failed .. |
