06-11-2015, 15:43 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: pakistan
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 433 | I need Help I747 Boot Repair i needed help I747 boot deat but when write SDC file with Atf then screen show this but no flahs here is pic. |
06-11-2015, 16:13 | #2 (permalink) |
No Life Poster Join Date: Jul 2012
Member: 1783314 Status: Offline Sonork: 100.1620532 Thanks Meter: 127 | In your picture see " FLASH WRITE FAILURE " This means data cannot write to emmc chip. Try emmc connection / operation.. X-Shadow has a post with emmc connection to I747... but could also be dead emmc not fixable. |
06-11-2015, 23:54 | #3 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi if your eMMC is "Samsung" You can connect PCB via Direct Connection,Then Select "Remove Write Protection" if your eMMC is Read Only Plus You can repair FW +Format |
