07-05-2016, 14:17 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Samsung G530H PINOUT+ BOOT FILE + PIT, TESTED 100% Here Pinout for Samsung G530H + BOOT FILE +PIT, TESTED 100% WITH ATF LINK: G530H BOOT FILE + PIT USE ONLY THISBUTTON IN DOWN RIGHT CORNER BR allumts |
The Following 76 Users Say Thank You to allumts For This Useful Post: |
07-05-2016, 16:29 | #3 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Have BL and PIT so what are serching more?.... Get one eye here can be understand more.... http://forum.gsmhosting.com/vbb/f609...l#post11900866 Loock post #19.... Br |
The Following 5 Users Say Thank You to allumts For This Useful Post: |
07-05-2016, 17:06 | #4 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | 1. Use Pinout shared on this thread. 2. Download Official TAR.MD5 BL File above: BL_G530HXXU2BOH7_CL773219_QB6125026_REV00_user_low _ship_MULTI_CERT.tar.md5 Then use ATF 12.66/7. Goto ATF Plus ---> eMMC Tool... Click "WRITE" then select TAR.MD5 which you downloaded from STEP 2. Then click "START" This will write BOOT 5.0.2 to your phone. LAST STEP: Full Flash with same fw, (i've used Stock FW but if have issue Flash 4 part file) + Pit when phone is in Download mode as always. FIRMWARE: http://samsung-updates.com/details/5...HXXU2BOH7.html IMPORTANT: FLASH ONLY BOOT FILE, NO MODEM or OTHER FILE Loock one example: http://forum.gsmhosting.com/vbb/10895194-post45.html BR allumts Last edited by allumts; 07-05-2016 at 17:13. |
The Following 7 Users Say Thank You to allumts For This Useful Post: |
07-05-2016, 20:02 | #5 (permalink) |
No Life Poster Join Date: Feb 2010 Location: india. kerala.
Member: 1245320 Status: Offline Sonork: 100.1612126 Thanks Meter: 140 | ok thanks ...its good..... just one file..keep it... |
The Following 2 Users Say Thank You to rasheedc007 For This Useful Post: |
07-07-2016, 12:33 | #6 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | For who have need more clairment just read Sticky Thread here: http://forum.gsmhosting.com/vbb/f609...hread-2048079/ Quote:
allumts | |
07-17-2016, 19:45 | #8 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Read and apply Carefully All step in post #4 above. Only BOOT file must need of flash no Others, like .Img files. Br |
The Following 3 Users Say Thank You to allumts For This Useful Post: |
07-17-2016, 20:07 | #10 (permalink) |
Freak Poster Join Date: Mar 2016
Member: 2541680 Status: Offline Thanks Meter: 68 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : FE014E50314A39354B134F93A28A1227 CSD : D06E01320F5913FFFFFFFFEF92400071 eMMC Boot Information Revision 1.6 (for MMC v4.5, v4.51) BOOT PARTITION : BOOT PARTITION 1 PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 3584 KB HC ERASE GROUP SIZE: 8192 KB USER AREA SIZE : 7818182656 BYTES BOOT PARTITION SIZE: 2048 KB RPMB PARTITION SIZE: 2048 KB eMMC Device Information Manufacturer ID: FE Device Type : Embedded BGA Application ID : 4E Product Name : P1J95K Product Rev : 1.3 Product SN : 4F93A28A Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 3000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: FE014E50314A39354B134F93A28A1227.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ MBR is Corrupted... Start Writing Flash Images... Flash Image: MBR + PGPT Start Writing 0x00000032 Blocks at 0x00000000 Partition Selected: USER AREA Total Elapsed Time 00:00:03 Write Success! Flash Image: PIT Start Writing 0x00000009 Blocks at 0x00000022 Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: SGPT Start Writing 0x00000021 Blocks at 0x00E8FFDF Partition Selected: USER AREA Total Elapsed Time 00:00:00 Write Success! Flash Image: aboot.mbn Start Writing 0x00001000 Blocks at 0x000267C0 Partition Selected: USER AREA Total Elapsed Time 00:00:04 Write Success! Flash Image: sbl1.mbn Start Writing 0x00000400 Blocks at 0x00026380 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: rpm.mbn Start Writing 0x00000400 Blocks at 0x000277C0 Partition Selected: USER AREA Total Elapsed Time 00:00:13 Write Success! Flash Image: tz.mbn Start Writing 0x00000400 Blocks at 0x00027BC0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: hyp.mbn Start Writing 0x00000400 Blocks at 0x00027FC0 Partition Selected: USER AREA Total Elapsed Time 00:00:01 Write Success! Flash Image: non-hlos.bin Start Writing 0x00007800 Blocks at 0x00002000 Partition Selected: USER AREA Total Elapsed Time 00:00:26 Write Success! Total Images Written: 6 Process Done! |
The Following User Says Thank You to proof kemo For This Useful Post: |
07-17-2016, 20:24 | #12 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | You haven't Read nothing Carefully, otherwise wasn't inserting also Modem File and .Img file....what have finish of write above...ONLY BOOT file W/O .IMG file ...you have put all stock Fw...please read carefully if wrong is only becouse not read all. Quote:
The Following User Says Thank You to allumts For This Useful Post: |
07-17-2016, 21:05 | #15 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Please stop of ask useless question. Lol "NON-HLOS.bin" is MODEM FILE, have write 5 times of write ONLY BOOT file...and any PIT... if fail insert PIT but as i can see will be work w/o PIT. |
