02-24-2016, 15:52 | #1 (permalink) |
Insane Poster Join Date: Jun 2014 Location: iran
Member: 2213455 Status: Offline Thanks Meter: 17 | samsung J700f-dd dead after flash i have a j700f-dd after flash dead repair boot by atf and done but no download mode i download : J700FXXU1APA7_J700FOJV1APA5_BTC.zip J700FXXU1AOGD_J700FODD1AOG4_INS.zip and repair by bl file BL_J700FXXU1APA1_CL890178_QB8006652_REV00_user_low _ship.tar but not ok scan emmc PHP Code: write log PHP Code: PHP Code: |
The Following User Says Thank You to Kiyan1391 For This Useful Post: |
02-24-2016, 18:05 | #4 (permalink) |
Member: 2213455 Status: Offline Thanks Meter: 17 | tnx mr angel write done. but not ok Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:04:10 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:02:17 Write Success! Total Images Written: 2 Process Done! |
02-24-2016, 18:14 | #5 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Use lastest version MD5 firmware in Sammobile. |
The Following User Says Thank You to toninhosantos For This Useful Post: |
02-25-2016, 03:35 | #7 (permalink) |
Registered User Join Date: Feb 2012 Location: swimming
Member: 1725884 Status: Offline Sonork: swimming Thanks Meter: 293 | J700FXXU1APA1_J700FOJV1APA1_5.1.1_UnitedArab_Home. zip try with this version is newer than yours.... |
The Following User Says Thank You to abo anas zayan For This Useful Post: |
02-25-2016, 19:54 | #10 (permalink) |
Moderator Join Date: Jan 2008 Location: <jeddah al saudia> Age: 36
Member: 668050 Status: Offline Sonork: 100.1656307 Thanks Meter: 991 | TRY AND POST RESULT BL_J700FXXU1AOL2_CL916897_QB7693529_REV00_user_low _ship.tar |
The Following User Says Thank You to chand_gee For This Useful Post: |
02-25-2016, 20:16 | #11 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Karachi, Pakistan Age: 33
Member: 643472 Status: Offline Sonork: 100.96901 Thanks Meter: 16,589 | Did you remove wires and check like toninhosantos said? Or you are just checking with wires connected? Your phone has same SK Hynix IC as my phone had (but that's not eMMC IC, eMMC is Toshiba). I repaired mine with this BL already and I am sure should work for your phone as well. So check without wire, make sure there are no soldering left on PCB near eMMC area. BR |
The Following User Says Thank You to ..::Angel::.. For This Useful Post: |
02-26-2016, 16:28 | #13 (permalink) | |
Member: 2213455 Status: Offline Thanks Meter: 17 | Quote:
Start Writing Flash Images... Flash Image: sboot.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 1 Total Elapsed Time 00:00:07 Write Success! Flash Image: cm.bin Start Writing 0x00002000 Blocks at 0x00000000 Partition Selected: BOOT 2 Total Elapsed Time 00:00:07 Write Success! Total Images Written: 2 Process Done! | |
02-26-2016, 16:34 | #14 (permalink) | |
Junior Member Join Date: May 2009
Member: 1040322 Status: Offline Sonork: milad Thanks Meter: 2 | Quote:
ur phone its done or not with this file ???? | |
The Following User Says Thank You to sky2222 For This Useful Post: |
