03-06-2014, 10:42 | #62 (permalink) | |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | Quote:
BAD BLOCKS are handled (remapped) internally by the eMMC Firmware inside the eMMC Chip. It is "INVISIBLE" to the eyes of the external world. | |
03-06-2014, 10:44 | #63 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @hans salim If you have: 1. Working DUMP from a working phone 512 MB or 1GB 2. Pinout for eMMC Direct Connection 3. If eMMC CHIP is NOT DAMAGED then you can repair it. |
03-06-2014, 12:03 | #64 (permalink) | |
Freak Poster Join Date: Mar 2004 Location: Romania Age: 48
Member: 59869 Status: Offline Thanks Meter: 132 | Quote:
Code: 12:36:21 : Factory Erasing Supported FLASH AREA... 12:36:21 : Normal Factory Erase Done! ------------------------------------------------------ 12:36:28 : Interface Reset OK! 12:36:28 : eMMC Access Type: SECTOR MODE ------------------------------------------------------ 12:36:28 : CID : 15010056545530304DF1A97C1705 12:36:28 : CSD : D02701320F5903FFF6DBFFFF8E40406D 12:36:28 : 12:36:28 : eMMC Boot Information 12:36:28 : Revision 1.6 (for MMC v4.5) 12:36:28 : BOOT PARTITION : BOOT PARTITION 1 12:36:28 : PARTITION ACCESS : R/W USER PARTITION 12:36:28 : PERM_BOOT_CFG_PROT : DISABLED 12:36:28 : PWR_BOOT_CFG_PROT : DISABLED 12:36:28 : eMMC FirmW UPDATE : DISABLED 12:36:28 : EMMC CACHE SIZE : 0 KB 12:36:28 : SUPER PAGE SIZE : 3584 KB 12:36:28 : HC ERASE GROUP SIZE: 512 KB 12:36:28 : USER AREA SIZE : 15758000128 BYTES 12:36:28 : BOOT PARTITION SIZE: 2048 KB 12:36:28 : RPMB PARTITION SIZE: 128 KB 12:36:28 : 12:36:28 : 12:36:28 : eMMC Device Information 12:36:28 : Manufacturer ID: SAMSUNG 12:36:28 : Device Type : Embedded BGA 12:36:28 : Application ID : 00 12:36:28 : Product Name : VTU00M 12:36:28 : Product Rev : 15.1 12:36:28 : Product SN : A97C1705 12:36:28 : Manufactured : January 2012 12:36:28 : 12:36:28 : Card Specific Data 12:36:28 : CSD_STRUCTURE : Extended 12:36:28 : SPEC_VERS : Version 4.1/4.2/4.3 12:36:28 : TAAC : 13 ns 12:36:28 : TRANS_SPEED : 4000000 KHz 12:36:28 : READ_BL_LEN : 512 Bytes 12:36:28 : C_SIZE : HIGH CAPACITY 12:36:28 : WP_GRP_ENABLE : YES 12:36:28 : WRITE_BL_LEN : 512 Bytes 12:36:28 : CONTENT_PROT_APP : NO 12:36:28 : PERM_WRITE_PROTECT: NO 12:36:28 : TMP_WRITE_PROTECT : NO 12:36:28 : 12:36:28 : Extended CSD Saved: 12:36:28 : 15010056545530304DF1A97C1705_472049E9.ext_csd 12:36:28 : Backup Directory: 12:36:28 : C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ 12:36:28 : 12:36:30 : 12:36:30 : Task Selected: Samsung Factory Format --------------------------------------------------------- 12:36:30 : Samsung Factory Format Start... 12:36:30 : ERROR: SAMSUNG_FACTORY_FORMAT FAILED 0x02 -------------------------------------------------- 12:37:02 : Task Selected: Write EXT_CSD Backup 12:37:03 : Task Done! ---------------------------------------------------------- 12:38:08 : Start Writing 0x001EC209 Blocks at 0x00000000 12:38:08 : Partition Selected: USER AREA 12:38:09 : TANDEM DELAY ERROR 0xFF | |
03-06-2014, 17:28 | #65 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | Quote:
03-06-2014, 17:33 | #66 (permalink) |
Major Poster Join Date: Aug 2009
Member: 1108505 Status: Offline Thanks Meter: 2 | ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type is BYTE MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V ERROR: EMMC_ALL_SEND_CID FAILED (CMD2) Check your Test Point Soldering! Try to Adjust VCCIO Voltage |
03-06-2014, 18:52 | #67 (permalink) |
No Life Poster Join Date: Aug 2007 Location: India\China
Member: 561947 Status: Offline Sonork: 100.1580399 Thanks Meter: 948 | bro, Can I use 4 in 1 adapter with advance metal crome box or not. because after connecting all testpoint, i could not revive my N7100. pls suggest me. Regards |
03-06-2014, 21:18 | #68 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
Br allumts | |
03-07-2014, 03:53 | #69 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | @gsm_links Yes, working with any ATF BOX type. If you get connection error "00FF8080" then it means eMMC is dead. @allumts This is my internal version. It is NOT for PUBLIC! |
The Following User Says Thank You to Advance-Box For This Useful Post: |
03-07-2014, 08:46 | #70 (permalink) | |
Freak Poster Join Date: May 2012
Member: 1757924 Status: Offline Sonork: 100.1675762 Thanks Meter: 40 | Quote:
03-08-2014, 11:12 | #73 (permalink) |
No Life Poster Join Date: Dec 2009 Location: pilapil marangle
Member: 1190283 Status: Offline Thanks Meter: 67 | |
03-08-2014, 11:40 | #74 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | If have BIG Atf, (for Nitro need use External power), can do yourself a adapter working in 10/15 min.s if you want buy ready order in China and wait 15/25 days, Here made in home: http://forum.gsmhosting.com/vbb/10140238-post44.html Above the 4 in 1 adapter from China, regards allumts |
03-09-2014, 20:08 | #75 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Atf team, I can use the boot files from another box (box gpg EMMC) in the EMMC Tool Atf box? Can you say yes or no.? The files are bin format. |
