08-08-2014, 12:10 | #317 (permalink) |
No Life Poster Join Date: Sep 2005
Member: 185255 Status: Offline Thanks Meter: 42 | Card Reset Done! Initializing Micro SD Card... Card Initialized OK (V2.0 Compliant) Waiting for IDLE State... Card is now IDLE! Reading Micro SD Card Information... Manufacturer ID : 0x00 Application ID : Product Name : 00000 Product Revision : 1.0 Serial Number : 000066AA Manufacture Date: June 2014 Card CID: 000000303030303010000066AA00E66F Card CSD: 400E00325B590000770F7F800A40008D Card SCR: 02B5800000000000 Card OCR: 00C0FF8000 SD Card Size : 15980298240 Bytes SD Block Size: 512 Bytes Maximum Speed: 25000000 Hertz SDHC / SDXC Card Detected... Checking Lock Status... Micro SD Card is NOT Password Protected!!! Erasing SDC... Samsung SCH-I535 UNBRICK 4.3 Start Writing to SDC at 0x00000000... Number of Blocks: 0x00040000 Process Done... Total Elapsed Time 00:01:44 Write Success! the phone cannot boot only show a blink of red light on the indicator light if pluged to a charger so i assume boot is damaged when i prepared with 4.3 i got thie error boot recovery mode check boot partitions copy from t-flash boot recovery.. write 159488 sectors. flash write failure factory mode pruduct name: sgh-i535 custom binary download: no current binary: samsung official system status: none qualcom secureboot:enable warranty bit:0 bootloader ap swrev:1 without this sdc file phone remains totally dead ,not booting i hope this will to give possible solution |
08-18-2014, 04:13 | #318 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | SDC File Created with "G7102XXUBNH3_G7102ODDBNG7_G7102DDUBNG1_HOME.tar.md5" SM-G7102_4.4.2_8GB_G7102XXUBNH3.sdc Flash File from s a m m o b i l e . c o m http://www.s a m m o b i l e . c o m...download=33779 remove spaces... our forum not allow linking to this site. So try with SDC first... |
The Following User Says Thank You to Advance-Box For This Useful Post: |
08-19-2014, 10:53 | #319 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,345 | Quote:
one question, now is possible to "Create Immage File" also with single FW putting in PDA?, no more need AP, CP, BL and PIT files? thank for answer, br allumts | |
08-21-2014, 13:22 | #320 (permalink) | |
SAMSUNG SDC FILES by Linus H. - Page 3 - 4shared for .afp file, downlod directly from you Atf Jtag if is supported model, please read update of section Atf, Br allumts | |
08-22-2014, 22:57 | #321 (permalink) |
Insane Poster Join Date: Nov 2011 Age: 42
Member: 1683660 Status: Offline Thanks Meter: 14 | |
08-28-2014, 10:02 | #323 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi SM-G730W8 i see supported for create SDC but i can't find .Pit file or full FW...So Need SDC for G730w8 or JTAG Way or Dump File -- Also have I8200 and I8200N bricked ... need SDC file if Supported Thanks |
08-28-2014, 14:19 | #324 (permalink) | |
Remove spaces and download. Is INDIA Fw, but i can flash my country fw or have need first Flash this one that's created sdc file? in N9005 i've flashed after phone in D.Mode fw of my country, last fw more high...is the same? | |
08-29-2014, 21:05 | #325 (permalink) |
No Life Poster Join Date: Aug 2014 Location: brazil - brasilia
Member: 2235684 Status: Offline Thanks Meter: 419 | sdc more here SAMSUNG SDC FILES by Linus H. - Page 4 - 4shared va in atf tab atf plus / sdc tool / plays the file in sd card and and does prodeminto |
09-01-2014, 09:12 | #328 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,345 | |
09-01-2014, 09:16 | #329 (permalink) |
09-01-2014, 10:51 | #330 (permalink) |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Download from here official web Link ATF| AdvanceTurbo Box Support Site,ATF Lumia Boot Repair,ATF Lumia Emmc Repair files,ATF Samsung Boot Repair,ATF Samsung SDC Files,ATF Cherrymobile Boot Repair,ATF Starmobile Boot Repair ATF| AdvanceTurbo Box Support Site,ATF Lumia Boot Repair,ATF Lumia Emmc Repair files,ATF Samsung Boot Repair,ATF Samsung SDC Files,ATF Cherrymobile Boot Repair,ATF Starmobile Boot Repair |
