02-17-2016, 09:45 | #33 (permalink) | |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
BR | |
The Following User Says Thank You to allumts For This Useful Post: |
02-17-2016, 10:04 | #36 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Post Log and Screen, but also most important what type of EMMC and CPU have in this phone and What Bootloader File have used, if last version or what, Any Stock FW must use. BR allumts |
02-17-2016, 12:44 | #37 (permalink) |
Junior Member Join Date: Sep 2013 Location: Iran shahrRey
Member: 2033821 Status: Offline Thanks Meter: 2 | ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x00000000 |
02-17-2016, 15:36 | #40 (permalink) | ||||
For other question of this type READ carefully Easy digram and steps in first post!!! BR | ||||
02-17-2016, 15:39 | #41 (permalink) |
Freak Poster Join Date: May 2013
Member: 1939490 Status: Offline Sonork: 100.1638723 Thanks Meter: 22 | Done , Success. https://www.youtube.com/watch?v=Mck1Eto4iKc |
02-18-2016, 19:35 | #42 (permalink) |
Major Poster Join Date: May 2007 Location: morocco
Member: 499918 Status: Offline Thanks Meter: 2 | . DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 110100343030303733003D32B2C9B2ED CSD : D07E00320F5903FFFFFFFFE78A4000D1 eMMC Boot Information Revision 1.0 (for MMC v4.0) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 0 KB HC ERASE GROUP SIZE: 0 KB USER AREA SIZE : 0 BYTES BOOT PARTITION SIZE: 0 KB RPMB PARTITION SIZE: 0 KB eMMC Device Information Manufacturer ID: TOSHIBA Device Type : Embedded BGA Application ID : 00 Product Name : 400073 Product Rev : 0.0 Product SN : 3D32B2C9 Manufactured : January 1999 Card Specific Data CSD_STRUCTURE : Extended SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 8000 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 110100343030303733003D32B2C9B2ED.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ MBR is Corrupted... ERROR: PIT Partition NOT FOUND! Please Provide a PIT File via Selecting "Re-Partition" |
02-19-2016, 07:06 | #43 (permalink) | |
No Life Poster Join Date: Jun 2010 Location: Xique-Xique-Bahia, Brasil Age: 46
Member: 1320000 Status: Offline Sonork: 100.1667898 Thanks Meter: 272 | Quote:
02-19-2016, 07:24 | #44 (permalink) |
Freak Poster Join Date: Mar 2006 Location: peshawar,pakistan
Member: 241705 Status: Offline Thanks Meter: 4,294,967,295 | getting this eror again and again test point are ok as in pic ================================================== ==== ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. ERROR: EMMC WAS NOT Detected! (CMD1) Check your Test Point Soldering! CMD1 Reply: 0x00000000 |
02-20-2016, 05:40 | #45 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Shibgonj6340
Member: 844312 Status: Offline Sonork: 100.1640471 Thanks Meter: 257 | data pin out others pin site help please very hard work so iron soldaring pin out help plsese solder pin easy pin out emmc repaire |
