Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 07-03-2016, 10:06   #316 (permalink)
Member: 1778926
Thanks Meter: 60
hi help me pls
i got this error
eMMC Boot Information
Revision 1.0 (for MMC v4.0)
BOOT PARTITION : NOT BOOT ENABLED
PARTITION ACCESS : R/W USER PARTITION
PERM_BOOT_CFG_PROT : DISABLED
PWR_BOOT_CFG_PROT : DISABLED
BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED
RESET BUS WIDTH : ENABLED
eMMC FirmW UPDATE : DISABLED
EMMC CACHE SIZE : 0 KB
SUPER PAGE SIZE : 0 KB
HC ERASE GROUP SIZE: 0 KB
USER AREA SIZE : 0 BYTES
BOOT PARTITION SIZE: 0 KB
RPMB PARTITION SIZE: 0 KB
eMMC Device Information
Manufacturer ID: TOSHIBA
Device Type : Embedded BGA
Application ID : 00
Product Name : 400073
Product Rev : 0.0
Product SN : A6823883
Manufactured : January 1999
Card Specific Data
CSD_STRUCTURE : Extended
SPEC_VERS : Version 4.1/4.2/4.3
TAAC : 8000 ns
TRAN_SPEED : 4000000 KHz
READ_BL_LEN : 512 Bytes
C_SIZE : HIGH CAPACITY
WP_GRP_ENABLE : YES
WRITE_BL_LEN : 512 Bytes
CONTENT_PROT_APP : NO
PERM_WRITE_PROTECT: NO
TMP_WRITE_PROTECT : NO
Extended CSD Saved:
11010034303030373300A6823883A299.ext_csd
Backup Directory:
C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\
MBR is Corrupted...
ERROR: PIT Partition NOT FOUND!
Please Provide a PIT File via Selecting "Re-Partition"
Old 07-04-2016, 06:15   #317 (permalink)
Member: 1778926
Thanks Meter: 60
pls masters help me ro solve my problem
Old 07-04-2016, 09:43   #318 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
J700H success
eMMC Test Point Connection Module
1. DO NOT USE THE PHONE"S BATTERY
2. Connect the Soldered TP Connections to ATF Box
3. Disconnect the USB Cable and Wait until the
the ATF Software will tell you to Connect the USB.
Interface Reset OK!
eMMC Access Type: SECTOR MODE
eMMC Supported Voltage Range:
3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V
3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V
CID : 11010034303030373300C2D04B75B245
CSD : D07E00320F5903FFFFFFFFE78A4000D1
Revision 1.7 (for MMC v5.0, v5.01)
BOOT PARTITION : BOOT PARTITION 1
BOOT MODE : x4 SINGLE DATA RATE + LOW SPEED
SUPER PAGE SIZE : 4096 KB
HC ERASE GROUP SIZE: 4096 KB
USER AREA SIZE : 15758000128 BYTES
BOOT PARTITION SIZE: 4096 KB
RPMB PARTITION SIZE: 4096 KB
Application ID : 00
Product Rev : 0.0
Product SN : C2D04B75
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
11010034303030373300C2D04B75B245.ext_csd
Backup Directory:
Start Writing Flash Images...
Flash Image: sboot.bin
Start Writing 0x00002000 Blocks at 0x00000000
Partition Selected: BOOT 1
Total Elapsed Time 00:02:07
Write Success!
Flash Image: cm.bin
Partition Selected: BOOT 2
Total Elapsed Time 00:01:42
Write Success!
Total Images Written: 2
Process Done!
The Following 2 Users Say Thank You to ashraf_bcs For This Useful Post:
Old 07-04-2016, 09:53   #319 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
Another one J700H
Interface Reset OK!
CID : 11010034303030373300AB4142B5A235
Application ID : 00
Product Rev : 0.0
Product SN : AB4142B5
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
11010034303030373300AB4142B5A235.ext_csd
Backup Directory:
Total Elapsed Time 00:01:41
Write Success!
Flash Image: cm.bin
Total Elapsed Time 00:01:19
Write Success!
Process Done!
The Following User Says Thank You to ashraf_bcs For This Useful Post:
Old 07-04-2016, 10:12   #320 (permalink)
ashraf_bcs's Avatar
Member: 303373
Sonork: 100.1584377
Thanks Meter: 1,241
This time J700F
Interface Reset OK!
CID : 11010034303030373300A3E0BC729243
Application ID : 00
Product Rev : 0.0
Product SN : A3E0BC72
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
11010034303030373300A3E0BC729243.ext_csd
Backup Directory:
Total Elapsed Time 00:05:43
Write Success!
Flash Image: param.bin
Start Writing 0x00004000 Blocks at 0x0001A800
Partition Selected: USER AREA
Total Elapsed Time 00:04:14
Write Success!
Flash Image: cm.bin
Total Elapsed Time 00:02:43
Write Success!
Total Images Written: 3
Process Done!
Old 07-04-2016, 11:32   #321 (permalink)
kamiran's Avatar
Member: 223973
Thanks Meter: 155
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
Write Success!
Flash Image: cm.bin
Write Success!
Process Done!
can u please tell me what firmware u used for repair....
K@mi
Old 07-04-2016, 11:46   #322 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
@Kamiran,
As you have writed:
dont wast your time see the previous posts from around the world in this thread only a few people succeed to get their phone alive there must be a glitch for toshiba emmc .... i have tried every single file from sammobile but no luck
Old 07-04-2016, 12:12   #323 (permalink)
kamiran's Avatar
Member: 223973
Thanks Meter: 155
Originally Posted by allumts View Post
@Kamiran,
As you have writed:
i can post 100 of such logs with no proof of download mode )
Old 07-04-2016, 15:02   #324 (permalink)
AgicAga's Avatar
Member: 866455
Sonork: SAMSUNG CPID ONLINE
Thanks Meter: 579
Interface Reset OK!
CID : 110100343030303733009571BFD0B267
Application ID : 00
Product Rev : 0.0
Product SN : 9571BFD0
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
110100343030303733009571BFD0B267.ext_csd
Backup Directory:
Total Elapsed Time 00:00:05
Write Success!
Flash Image: cm.bin
Total Elapsed Time 00:00:04
Write Success!
Process Done!
[IMG]***** photo sharing[/IMG]
Old 07-04-2016, 17:11   #325 (permalink)
kamiran's Avatar
Member: 223973
Thanks Meter: 155
Interface Reset OK!
Application ID : 00
Product Rev : 0.0
Card Specific Data
TAAC : 8000 ns
WP_GRP_ENABLE : YES
Extended CSD Saved:
Backup Directory:
Write Success!
Flash Image: cm.bin
Write Success!
Process Done!
phone goes to download mode???
Old 07-05-2016, 23:53   #326 (permalink)
AgicAga's Avatar
Member: 866455
Thanks Meter: 579
[QUOTE][phone goes to download mode???/QUOTE]
yes phone successfully repaired model j700h-ds regards team
Old 07-06-2016, 08:21   #327 (permalink)
Member: 1218019
Thanks Meter: 6
[QUOTE=AgicAga;11911768]
what firmware you used, bro? many have tried but it does not work
Old 07-06-2016, 12:08   #328 (permalink)
AgicAga's Avatar
Member: 866455
Thanks Meter: 579
J700HXXU2APE3_J700HOXY2APE3_CAU working for my
Old 07-07-2016, 17:23   #329 (permalink)
Member: 1418143
Thanks Meter: 353
I succefully fixed about 10 pcs , but today I tried one w/o succes .
I tried even with a 6.0 firmware but handset is till dead ..
Old 07-10-2016, 13:14   #330 (permalink)
Crazy Poster
Member: 1918840
Thanks Meter: 11
hi
i have a j700f ds with dead boot and i try with this methode and prosses done
but phone still dead ..
plzzzzzz help
Page generated in 0.40484 seconds with 9 queries
