GSMSERVER GSM Shop
Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-22-2010, 09:34   #1 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,988
Some facts of dct4 flashings with ATF
- Dont Flash Patch Unlocked Phones.If you flash an "patch-unlocked" phone, normally it would get bad simlocks and result will be contact service.
- always to use easy cable only.we dont support fbus cable
-CDMA handset still not supported
-patch unlock still not supported
- this dct4 update is only made for testing speed in dct4 handsets
in Next release
- patch unlock will be available
- flashing will be more stable with easy cable
Note :- please understand us as we are working step by step to make the product best and good for customers so please have some patient and wait for proper release
please test much phones and post logs ,errors,bugs in bug thread so we can see and fixed that as soon as possible
The Following 8 Users Say Thank You to Javajohn For This Useful Post:
Old 03-22-2010, 10:55   #2 (permalink)
twentyonecell's Avatar
Member: 664744
Thanks Meter: 156
bus check rh 93 1112 show error
Old 03-22-2010, 10:57   #3 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,988
which cable you are using?
Old 03-22-2010, 11:00   #4 (permalink)
Member: 664744
Thanks Meter: 156
with easy cable sir
bus check in hwk
1st Boot: Ok, DCT4, UPP: 2201 [Rh-93] [2.0.9.0]
2nd Boot: u_2nd.fia, Ver: 4.79.0
Fl0: 0x01000000-0x013FFFFF,00012A7E,Amd 29BDS320
Algorithm: u_amd.fia, Ver: 4.79.0
Rebooting Mobile
Old 03-22-2010, 11:05   #5 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,988
ok try with easy cable and pulse power button while bus check
Old 03-22-2010, 11:11   #6 (permalink)
ulymar's Avatar
Member: 81952
Sonork: 1597268
Thanks Meter: 2,306
hi!
goto C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader
remove loader starting with m_ ex. m_amd.fia,m_intel.fia,m_st_i.fia
br,
Old 03-22-2010, 11:15   #7 (permalink)
Member: 664744
Thanks Meter: 156
already in the press and power button remains the same problems arise as the above error
Old 03-22-2010, 11:22   #8 (permalink)
Member: 664744
Thanks Meter: 156
hi!
AdvanceBox Turbo Flasher Found
Driver Version : 00020422
Library Version : 00030119
Initialize Device....
Init TRY : 1
Box Name : AdvanceBox Turbo
Box Firmware : LogiCore 3.21.10
Software Version : v4.6
AdvanceBox SN : E587615ACC698404AC45442E
BOX Status : ACTIVATED
INIT : OK
Boot Check, Please wait...
MCUID Response
MessageID : 92
msbUPP_ID : 22
lsbUPP_ID : 01
Boot OK
Boot File: C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\u_2nd.fia
Boot OK!
MCU_CONFIGURATION_RESPONSE_DCT4_MUL3
DCT4 Mess 9F MUL3 Mess 9F
TransMode : 03
NumFlash : 02
DevAddr0 : 01
ManuId0 : 0001 - SPANSION
DevId0 : 2A7E - Type not in database
ExtId0 : 0024
RevId0 : 0111
SectorSize0: 10
Reserved0 : 00
DevAddr1 : 02
ManuId1 : 0000 - Flash
DevId1 : 0001 - not used
ExtId1 : 0000
RevId1 : 0000
SectorSize1: 00
Reserved1 : 00
ExtBUSC : AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
CheckSum : E0
ReceiveConfigurationResponse_DCT4 - FLS1_NO_ERROR
SearchForBootstrap_DCT4 : No Error
Algo Match File : C:\Program Files\AdvanceBox Turbo Flasher\Nokia\DCT4_Loader\uh_amd.fia
ALGO SENT..
Perform AUTHENTICATION..
MSID: 844A4FFB502830C211D0E52779
DecodedMSID: 84C436BAEF00910539A90006F0
EncodedFAID: 6DB22CC3D922BA853E7A5337
Authentication : SUCCESSFULL
Repowering Phone....
VBATT OFF ...
VBATT ON
Setting VBATT Done!...
Done!
okay running smoothly will be trying to do my flashing and will share his more results
thanks
Old 03-22-2010, 11:26   #9 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 601
Hi,, about easy cable... Use the one which does not have a RED VBATT Clip. If this cable is used, then no need to press
power button etc... Just click and wait for the phone to boot.
Our DCT4 booting is optimized for easy cable use because all new DCT4
phone are using easy cables.
B.R.
X-Shadow
Old 03-22-2010, 11:33   #10 (permalink)
Member: 664744
Thanks Meter: 156
oke flashing done
PHP Code:
Driver Version
00020422
Library Version
00030119
Initialize Device
Init TRY : 1
Box Name
AdvanceBox Turbo
Box Firmware
LogiCore 3.21.10
Software Version
v4.6
AdvanceBox SN
BOX Status
ACTIVATED
INIT
OK
Driver Version
00020422
Library Version
00030119
Initialize Device
Init TRY : 1
Box Name
AdvanceBox Turbo
Box Firmware
LogiCore 3.21.10
Software Version
v4.6
AdvanceBox SN
BOX Status
ACTIVATED
INIT
OK
ImageFile
:c:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02me
PhoneType
DCT4
Algorithm
DCT4 ALGORITHM
Supported Hardwares
0120
0121
1021
1120
1130
1131
1201
2140
2142
2201
2031
2030
2032
2033
Secondary Sending Speed
100000Hz
Algorithm Sending Speed
:  6500000Hz
Program Sending Speed
:  6500000Hz
Message Reading Speed
:  51000Hz
Number of Blocks
:  95
Entry Point
:  0x00EC
Is128k
:   True
Boot Check
Please wait...
MCUID Response
MessageID  92
      msbUPP_ID
22
      lsbUPP_ID
01
Boot OK
Boot File
Boot OK
TransMode
03
NumFlash
02
  DevAddr0
01
  ManuId0
0001 SPANSION
  DevId0
2A7E Type not in database
  ExtId0
0024
  RevId0
0111
  SectorSize0
10
  Reserved0
00
  DevAddr1
02
  ManuId1
0000 Flash
  DevId1
0001 not used
  ExtId1
0000
  RevId1
0000
  SectorSize1
00
  Reserved1
00
ExtBUSC
CheckSum
E0
FLS1_NO_ERROR
No Error
Algo Match File
ALGO SENT
MSID845C04508B879CF348F631415F
DecodedMSID
843E4EBAE900910539AA000000
EncodedFAID
48420E7CDF9EACAFF77E61DA
Authentication
SUCCESSFULL
Erasing address
011E0000 011EFFFF
>>  011F0000 0137FFFF
Erasing Done
Flashing ImageFile
ContinueFlash_DCT4 Complete
Write Time Elapse
00:00:10
FLASH Mode Set to
PHONEMODE_FLASHBUS
ProgrammingStatus_DCT4
BB_PROGRAMMING_STATUS_REQUEST
04 FF  -- Progamming status
BB_PERM_DATA_RESTORE_REQ
18 FF
BB_RESTART
07 FF
MCURestart
SUCCESS
Making delay between files
for 1000ms
ImageFile
:c:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02me
PhoneType
DCT4
Algorithm
DCT4 ALGORITHM
Supported Hardwares
0120
0121
1021
1120
1130
1131
1201
2140
2142
2201
2031
2030
2032
2033
100000Hz
:  6500000Hz
:  6500000Hz
:  51000Hz
Number of Blocks
:  10
Entry Point
:  0x00E4
Is128k
:   True
Boot Check
Please wait...
MCUID Response
MessageID  92
      msbUPP_ID
22
      lsbUPP_ID
01
Boot OK
Boot File
Boot OK
TransMode
03
NumFlash
02
  DevAddr0
01
  ManuId0
0001 SPANSION
  DevId0
  ExtId0
0024
  RevId0
0111
  SectorSize0
10
  Reserved0
00
  DevAddr1
02
  ManuId1
0000 Flash
  DevId1
0001 not used
  ExtId1
0000
  RevId1
0000
  SectorSize1
00
  Reserved1
00
ExtBUSC
CheckSum
E0
FLS1_NO_ERROR
No Error
Algo Match File
ALGO SENT
DecodedMSID
EncodedFAID
Authentication
SUCCESSFULL
Erasing address
01380000 013BFFFF
Erasing Done
Flashing ImageFile
Write Time Elapse
00:00:00
FLASH Mode Set to
PHONEMODE_FLASHBUS
18 FF
BB_RESTART
07 FF
MCURestart
SUCCESS
for 1000ms
ImageFile
:c:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
PhoneType
DCT4
Algorithm
DCT4 ALGORITHM
Supported Hardwares
0120
0121
1021
1120
1130
1131
1201
2140
2142
2201
2031
2030
2032
2033
100000Hz
:  6500000Hz
:  6500000Hz
:  51000Hz
Number of Blocks
:  122
Entry Point
:  0x0101
Is128k
:   True
Boot Check
Please wait...
MCUID Response
MessageID  92
      msbUPP_ID
22
      lsbUPP_ID
01
Boot OK
Boot File
Boot OK
TransMode
03
NumFlash
02
  DevAddr0
01
  ManuId0
0001 SPANSION
  DevId0
  ExtId0
0024
  RevId0
0111
  SectorSize0
10
  Reserved0
00
  DevAddr1
02
  ManuId1
0000 Flash
  DevId1
0001 not used
  ExtId1
0000
  RevId1
0000
  SectorSize1
00
  Reserved1
00
ExtBUSC
CheckSum
E0
FLS1_NO_ERROR
No Error
Algo Match File
ALGO SENT
DecodedMSID
EncodedFAID
Authentication
SUCCESSFULL
Erasing address
01000000 0100FFFF
>>  01010000 013BFFFF
>>  013C0000 013EFFFF
>>  017C0000 017EFFFF
>>  01FC0000 01FEFFFF
Erasing Done
Flashing ImageFile
Write Time Elapse
00:00:09
FLASH Mode Set to
PHONEMODE_FLASHBUS
18 FF
BB_RESTART
07 FF
MCURestart
SUCCESS
for 1000ms
Time Elapse
00:01:27
Old 03-22-2010, 14:09   #11 (permalink)
akhil_bbsr's Avatar
Member: 271478
Sonork: 1590868
Thanks Meter: 1,046
advanceBox Turbo Flasher Found
Init TRY : 1
AdvanceBox SN : C5BC7762D8A06439C79E60B5
INIT : OK
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
.............................................Advan ceBox Turbo Flasher Found
Init TRY : 1
Please update your Box Firmware..
INIT : OK
MCU:
IMEI:
Mastercode :
>> : LOCK INFO
Simlock Info ERROR
DCT4 Failed to BOOT
BUSCheck FAILED
nokia1200 rm105......bus check.phone scan in local mode boot fail
Old 03-22-2010, 14:28   #12 (permalink)
Javajohn's Avatar
Member: 122246
Sonork: 100.50000
Thanks Meter: 4,988
akhil_bbsr
can you catch me on yahoo messenger so i can help you
Old 03-22-2010, 16:02   #13 (permalink)
X-Shadow's Avatar
Member: 871
Thanks Meter: 601
@akhil_bbsr
Easy Cable connection ...
FOR Flashing,,, DO NOT PUT BATTERY TO THE PHONE
FOR Local / Test Mode... PUT BATTERY TO THE PHONE
The Following User Says Thank You to X-Shadow For This Useful Post:
Old 04-17-2010, 01:49   #14 (permalink)
Member: 901335
Sonork: 100.1652281
Thanks Meter: 150
plz sir update full dct 4 flashing with fbus cables . its great box ,better speed from other boxes . nice programming . but...... gsm need some more function as fully dct4 flashing with fbus . thanks sir . its superman,s super atf box. thanks sir
video flashing with ATF tsabila Advance-Box 6 02-24-2010 05:17
Put in this thread all successfull story of Dct4 Imei???? with Mxkey mobilecitycbk MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 06-17-2009 21:28
looking any offer of c1200 flash with RU --==Dixon==-- LG 0 09-04-2004 07:08
what is the name of C100 flash with turkish language? sat Trident/AGERE Platform 0 10-14-2003 08:52
Page generated in 0.70437 seconds with 8 queries
