09-05-2016, 02:20 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | error repair i9300 ================================================== ==== eMMC Test Point Connection Module ================================================== ==== ================================================== ==== 1. DO NOT USE THE PHONE"S BATTERY 2. Connect the Soldered TP Connections to ATF Box 3. Disconnect the USB Cable and Wait until the the ATF Software will tell you to Connect the USB. Interface Reset OK! eMMC Access Type: SECTOR MODE eMMC Supported Voltage Range: 3.5-3.6V, 3.4-3.5V, 3.3-3.4V, 3.2-3.3V, 3.1-3.2V 3.0-3.1V, 2.9-3.0V, 2.8-2.9V, 2.7-2.8V, 1.9-2.0V CID : 1501003030303030305620110726589D CSD : 902701320F5903FFF6DBFFEF8A404023 eMMC Boot Information Revision 1.5 (for MMC v4.41) BOOT PARTITION : NOT BOOT ENABLED PARTITION ACCESS : R/W USER PARTITION PERM_BOOT_CFG_PROT : DISABLED PWR_BOOT_CFG_PROT : DISABLED BOOT MODE : x1 SINGLE DATA RATE + LOW SPEED RESET BUS WIDTH : ENABLED eMMC FirmW UPDATE : DISABLED EMMC CACHE SIZE : 0 KB SUPER PAGE SIZE : 4096 KB HC ERASE GROUP SIZE: 512 KB USER AREA SIZE : 17179869184 BYTES BOOT PARTITION SIZE: 512 KB RPMB PARTITION SIZE: 128 KB eMMC Device Information Manufacturer ID: SAMSUNG Device Type : Embedded BGA Application ID : 00 Product Name : 000000 Product Rev : 5.6 Product SN : 20110726 Manufactured : January 2005 Card Specific Data CSD_STRUCTURE : Version 1.2 SPEC_VERS : Version 4.1/4.2/4.3 TAAC : 13 ns TRAN_SPEED : 4000000 KHz READ_BL_LEN : 512 Bytes C_SIZE : HIGH CAPACITY WP_GRP_ENABLE : YES WRITE_BL_LEN : 512 Bytes CONTENT_PROT_APP : NO PERM_WRITE_PROTECT: NO TMP_WRITE_PROTECT : NO Extended CSD Saved: 1501003030303030305620110726589D.ext_csd Backup Directory: C:\AdvanceBox Turbo Flasher\eMMC\EXT_CSD\ Task Selected: Samsung eMMC Firmware Update ================================================== ==== --> This will ERASE USER AREA, BOOT1, BOOT2, and RPMB --> This will RESET EXT_CSD Programming Such as BOOT Options, Bus Characteristics and Partition Sizes.. ================================================== ==== Please Manually Select the Correct Part Number of your eMMC Device. ================================================== ==== If you select a WRONG PART NUMBER, then YOU WILL PROBABLY KILL THE EMMC !!! ================================================== ==== ================================================== ==== Loading ATF eMMC Firmware File... (Please Wait) ================================================== ==== File Author: ATF Team @ X-Shadow Date Created: 21/02/2015 (dd/mm/yyyy) Description: Samsung eMMC Firmware eMMC Part Number: KMVTU000LM-B503 eMMC Product Name: VTU00M eMMC Product Rev: 15.7 Preparing eMMC for Firmware Update... ERROR: SET_BLOCK_COUNT FAILED (CMD23) 0x08 Total Elapsed Time 00:00:19 |
09-05-2016, 12:34 | #2 (permalink) | |
Freak Poster Join Date: Dec 2010 Location: Uzbekistan/Jizzakh
Member: 1470188 Status: Offline Sonork: 100.1638921 Thanks Meter: 88 | Quote:
