Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-04-2016, 01:04   #1 (permalink)
SVH
SVH's Avatar
Member: 9889
Thanks Meter: 50
Lumia 925 boot repair problem
Hi
I use ATF Jtag
Lumia 925 RM892 detects as ZEUS flash device
After installing repair drivers now phone detects as Nokia Emergency Connectivity
When select downloaded file 925_RM-892_BIG_BOOT.afp
Phone Type : Lumia 925 RM-892
CPU Type : Qualcomm MSM8960
Storage TYpe: eMMC 16/32GB
Boot Package: 3040.0005.1323.3007 (BIG BOOT)
1. Make sure JTAG Connection is 100% OK
2. Always Disconnect the Phone BATTERY
3. Connect USB Cable to Phone
4. Connect RJ-45 JTAG Cable to ATF Box
5. Select the Correct Phone Type RM-XXX
6. Use RESET JTAG button to check the JTAG Connection
7. Click RESTORE BOOT button to Start Boot Repairs
Resetting and Exploring JTAG chain...1 Device(s)
Device #1 ID 0x4F1F0F0F IR4
Restore Boot...
Waiting for Device Connection 15 second(s)...OK
Resetting and Exploring JTAG chain...OK
Halting Core...Retry
Halting Core...Cannot Halt Core!
When select file from ATF folder LUMIA_925_925T_FFU_FLASHER.afp
Phone Type : Lumia 925, 925T
Storage Type: eMMC 16/32GB
Procedure : WP8 FFU Flasher via JTAG
More Info : <<<<<<<< ATF JTAG Lumia WP8 FFU Flashing Procedure >>>>>>>> - GSM-Forum
Halting Core...OK
Initializing Device...OK
Detecting eMMC #1 ID...eMMC Error, Status 0x000C0242
Does it mean EMMC dead?
The Following User Says Thank You to SVH For This Useful Post:
Old 03-05-2016, 20:06   #2 (permalink)
SVH
SVH's Avatar
Member: 9889
Thanks Meter: 50
any advice from support?
Old 03-05-2016, 22:18   #3 (permalink)
Member: 2342394
check pinouts
its a bad soldering 90%
Old 03-07-2016, 12:03   #4 (permalink)
SVH
SVH's Avatar
Member: 9889
Thanks Meter: 50
soldering is good, checked twice
connected as showed in picture from JTAG sw
any idea?
Old 03-07-2016, 20:06   #5 (permalink)
SVH
SVH's Avatar
Member: 9889
Thanks Meter: 50
when i leave device attached to USB and RJ45 and close and run again JTAG sw i get:
Default language ID 0x0422, LR 14
JTAG Interface Connected, S/N xxxxxxxxx
Resetting and Exploring JTAG chain...2 Device(s)
Device #1 ID 0x4BA00477 IR4
Device #2 ID 0x706B40E1 IR11
but after press REPAIR BOOT i get again:
and after press RESET JTAG :
what does it mean?
why detected 2 devices and what is status 0x000C0242 ?
Old 03-11-2016, 11:39   #6 (permalink)
SVH
SVH's Avatar
Member: 9889
Thanks Meter: 50
Finally after rehot EMMC phone successfully started
Old 03-11-2016, 21:37   #7 (permalink)
Member: 2342394
It's EMMC probleme, phone will come back to same state after a peroid
Old 09-05-2016, 18:19   #8 (permalink)
Member: 797068
Thanks Meter: 75
itīs not file RM-892 in server!suporte please!
Page generated in 0.16705 seconds with 8 queries
