Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 05-03-2011, 18:13   #1 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Thanks Meter: 29,599
Tutorial: How to install oclHashcat-lite In Linux
Basic requirement:
1. Download Ubuntu from official website 32 bit or 64 bit:
Download | Ubuntu
2. Install Catalyst 11.4 in Ubuntu 32 bit or 64 bit:
The terminal can be found at Applications menu -> Accessories -> Terminal.
Best information for install:
Ubuntu Maverick Installation Guide - cchtml.com
3. Download AMD APP SDK 2.4 32 bit or 64 bit:
AMD APP SDK Downloads | AMD Developer Central
Read this installation note before install:
http://developer.amd.com/gpu/AMDAPPS...tion_Notes.pdf
Most people has error when run olcHashcat-lite because of this SDK not install correctly, that is why cause error.
Over Clock in Ubuntu:
Steps for overclocking:
1. The first step obviously is to turn on Overdrive:
aticonfig --od-enable If your card is not supported, you will get a message saying so.
2. Next we get the current clocks and the valid overclocking range for your card:
aticonfig --odgc
Default Adapter - ATI Radeon HD 4800 Series
                            Core (MHz)    Memory (MHz)
           Current Clocks :    500           750
             Current Peak :    625           993
  Configurable Peak Range : [500-700]     [750-1200]
                 GPU load :     2%
3.Now we can specify valid frequencies for our overclock
aticonfig --odsc=700,1000
                  New Core Peak   : 700
                  New Memory Peak : 1000
4. Finally we apply the new frequencies:
aticonfig --odcc
5. Check your new overclock:
aticonfig --odgc
             Current Peak :    700           1000
                 GPU load :    2%
You can also use Overdrive for Crossfire setups. The process is identical, with the difference that you need to specify the device being overclocked. Example:
aticonfig --list-adapters
#each card will be given a number that you append to the normal Overdrive commands
aticonfig --adapter=0 --odgc
#and so on...
To run oclHashcat-lite:
Open Terminal window: Applications menu -> Accessories -> Terminal.
Example:
./oclHashcat-lite64.bin 3D5D9E11835243015407B7BA327E30CCB70F4DB0:003519730379149500 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 160 --outfile-format=1 --outfile=351973037914952.txt
You can also put the above text in .sh file.
.sh file same as bat file in windows.
Hope this tutorial will help who is interest to install linux.
Thomas
The Following 32 Users Say Thank You to gsmfun For This Useful Post:
Old 05-03-2011, 18:22   #2 (permalink)
Member: 1116719
Thanks Meter: 542
Very Good Tutorial
yes this tutorial very help fully
Old 05-03-2011, 18:23   #3 (permalink)
MMDEBILI's Avatar
Member: 360073
Thanks Meter: 2,180
Very Good Tutorial Brother
Old 05-03-2011, 19:39   #4 (permalink)
Member: 61595
Sonork: 100.1610188
Thanks Meter: 91
thanks i need calculate within i hour so which kind of pc confugration need ? please i badly need about detail
Old 05-03-2011, 20:24   #5 (permalink)
riajul1988's Avatar
Member: 1511441
Sonork: 100.1604057
Thanks Meter: 1,158
Good Tutorial but need real solutions for windows
Old 05-03-2011, 21:09   #6 (permalink)
Member: 695201
Sonork: 100.1592455
Thanks Meter: 5
windows fast code calculator ? linux fast code calcualtor ?
pc configuration same
Old 05-04-2011, 06:42   #7 (permalink)
Member: 752151
Thanks Meter: 211
can run bruteforce to ubuntu 11.04 64bit?
Old 05-04-2011, 08:10   #8 (permalink)
Member: 141022
Sonork: 100.1603976
Originally Posted by gsmfun View Post
Basic requirement:
Download | Ubuntu
aticonfig --odgc
                 GPU load :     2%
                  New Core Peak   : 700
aticonfig --odcc
aticonfig --odgc
                 GPU load :    2%
#and so on...
Example:
Thomas
can i use linux ubuntu with 6970x4 gpu?
Old 05-04-2011, 11:33   #9 (permalink)
hoang's Avatar
Member: 10485
Sonork: 100.66876
Thanks Meter: 396
For lazy people, here SDK 2.4 in deb file format:
Ubuntu 32bit: http://orwell.fiit.stuba.sk/~nou/amd-app_2.4_i386.deb
Ubuntu 64bit: http://orwell.fiit.stuba.sk/~nou/amd-app_2.4_amd64.deb
The Following User Says Thank You to hoang For This Useful Post:
Old 05-05-2011, 04:11   #10 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Yes, you can. Someone already test 6970 x 8 in ubuntu!!
Thomas
Old 05-05-2011, 04:14   #11 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Thanks, this will make install easier.
Thomas
Old 05-05-2011, 11:07   #12 (permalink)
Member: 141022
Sonork: 100.1603976
Thomas
6970x4 to 8 with linux can see
Old 05-05-2011, 17:33   #13 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Yes 100% working.
Thomas
Old 05-05-2011, 18:11   #14 (permalink)
Member: 384775
Sonork: 100.1605469
Thanks Meter: 158
is linux support remote desktop? do you know?
Old 05-05-2011, 18:19   #15 (permalink)
gsmfun's Avatar
Member: 611
Sonork: 100.33333
Yes support.
TightVNC etc.
Thomas
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.21297 seconds with 8 queries
