11-04-2013, 15:14 | #1 (permalink) |
Freak Poster Join Date: Feb 2012 Location: pakistan Age: 30
Member: 1724706 Status: Offline Sonork: 100.1622356 Thanks Meter: 63 | NOKIA 301 flash done with Atf Processing Image File : rm840__02.51.mcusw Processing Image File : rm840__02.51.ppm_m5 Processing Image File : rm840__02.51.image_m5_059Q9B1_059S3L0_220_01 AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, and 3... 1. Remove USB Cable and Battery... 2. Connect USB Cable. 3. Connect Battery. ***** IF PHONE STARTS CHARGING OR DOES NOT BOOT ***** ******* REMOVE BATTERY AND PUT IT BACK AGAIN. ******* ================================================== ==== Infineon Boot: F01650A9070100030101A040140900144A824A70CEB6FFFF <<<< Connect Battery Now >>>> Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Flash Chip Manufacturer: STMicroelectronics Flash Boot Successful... Unique Data: A040140900144A82-4A70CEB6 Original Product Code: 059S6M7 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\3555200 Current File : rm840__02.51.mcusw Number of Images: 8 psi_flash_unsigned.fls slb_signed.fls main_toc_signed.fls rm840__02.51.mcusw_signed_mcusw.fls swap_signed.fls s dynsw.fls aeneas_signed.fls s fota_signed.fls s Processing Data Block 0x00 Erase Block: 0x00090000~0x000A0FAE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x01 Erase Block: 0x60000000~0x6003FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x02 Erase Block: 0x60040000~0x600403FE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x03 Erase Block: 0x62E00000~0x63D04D2A Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0xFFF00000~0xFFF7FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Processing Data Block 0x04 Erase Block: 0x80000000~0x80C1B932 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x05 Erase Block: 0x62080000~0x620C3FFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x06 Erase Block: 0x63F79C00~0x63FC046E Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Processing Data Block 0x07 Erase Block: 0x61F00004~0x620454BA Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm840__02.51.ppm_m5 Number of Images: 1 package_m5.ppm_ebl_psi.fls Processing Data Block 0x00 Erase Block: 0x80F00000~0x814393C2 Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Current File : rm840__02.51.image_m5_059Q9B1_059S3L0_220_01 Number of Images: 1 rm840__02.51.image_m5_059Q9B1_059S3L0_220_01.fls Processing Data Block 0x00 Erase Block: 0xA1000000~0xA28E2DFE Start Erasing... Erasing Please Wait... Block Erase Done... Start Writing... Finalizing... Data Block Write Done... Erase Block: 0xAE000000~0xAE2FFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Total Flashing Time (Erase + Flashing) : 00:00:19 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 02.51 07-06-13 RM-840 (c) Nokia IMEI Plain : 3555200 IMEI Spare : A3555200 IMEI SV : 335552005 Phone Model: Nokia 301 Category : Phone Phone Type : RM-840 ================================================ Extended Phone Information ================================================ Product Serial Number: 040EB6ABH Product Code : 059S6M7 Module Code : 0205267 Basic Production Code: 059P5R1 Long Production SN : 0 ADSP Version : V 02.51 07-06-13 RM-840 (c) Nokia M5 AEM Version : PMU_MAXIM8939B HW Version : V 02.51 07-06-13 RM-840 (c) Nokia PCI Version : 1000 RFIC Version : MFR:0x20,DEV:0x40,REV:0x131 DSP Version : 152 Camera : TPO Content Pack Version : Content: m5_059Q9B1 V 02.51 07-06-13 RM-840 (c) Nokia AHNE Version : 13 RETU Version : PMU_MAXIM8939B Bluetooth ID : F4:F5:A5:A0:B01 CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 13456 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : 01035602 DCC Ver: 006004 Status : OK ================================================== ==== Selected VPL File: RM840_059S3L0_02.51_019.vpl ================================================== ==== Variant Details : RM-840 VAR MEA-M5 ZA MTN BLACK Software Version : 02.51 Product Type : RM-840 Product Code : 059S3L0 Variant Version : 019 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK RESET LIFE TIMER TO : 0000:00 OK |
