Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 03-29-2011, 07:50   #1 (permalink)
azhergoga007's Avatar
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Talking try C1 flash but error - [Problem Solved]
ii try C1_RM_689 but error chack plzzzzzzz but phone is on ......
Old 03-29-2011, 08:05   #2 (permalink)
Member: 973412
Thanks Meter: 117
bro restore box and try again
Old 03-29-2011, 08:15   #3 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Talking
bro same error ........
Old 03-29-2011, 08:26   #4 (permalink)
Member: 973412
Thanks Meter: 117
r u sure your cable is ok
Old 03-29-2011, 08:35   #5 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
yes bro 1000% okay............
Old 03-29-2011, 08:42   #6 (permalink)
Member: 973412
Thanks Meter: 117
wht problem in your phone
Old 03-29-2011, 08:48   #7 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Red face
phone book not save
Divert opitions on
Old 03-29-2011, 08:58   #8 (permalink)
Member: 973412
Thanks Meter: 117
bro click live phone and try again
Old 03-29-2011, 08:58   #9 (permalink)
..:::YMG:::..'s Avatar
Member: 667126
Sonork: 100.1651201
Thanks Meter: 229
only support usb..try usb flashing
Old 03-29-2011, 08:59   #10 (permalink)
Member: 973412
Thanks Meter: 117
12:02:51 : AdvanceBox Turbo Flasher Found
12:02:51 : Driver Version : 00020422
12:02:51 : Library Version : 00030119
12:02:51 : Initialize Device....
12:02:52 : Init TRY : 1
12:02:53 : Box Name : AdvanceBox Turbo
12:02:53 : Box Firmware : LogiCore 9.02.10
12:02:53 : Software Version : v7.24
12:02:53 : AdvanceBox SN : E59FEA39D4440070A01EF6D2
12:02:53 : BOX Status : ACTIVATED
12:02:53 : INIT : OK
12:02:53 :
12:02:53 : VBATT OFF...
12:02:57 : VBATT ON
12:02:57 : Setting VBATT Done!...
12:02:57 :
12:02:57 :
12:02:57 : ///////// /// /// /////// /////// /////////
12:02:57 : /// /// /// /// // /// /// /// ///
12:02:57 : /// /// /// /////// /////// /// ///
12:02:57 : /// /// /// /// /// /// /// /// ///
12:02:57 : /// ///// /// /// /////// //////
12:02:57 :
12:02:57 : =======================================
12:02:57 : /// /// /// ///////// /////// //////
12:02:57 : ///// /// /// /// /// // /// ///
12:02:57 : /// ///// /// /// /////// /// ///
12:02:57 : /// //// /// /// /// /// /// ///
12:02:57 : /// /// /// /// /// /// //////
12:02:57 :
12:03:01 :
12:03:01 : Make sure that you plugged the cable to the
12:03:01 : RJ-45 Port Marked << EXTENSION >>
12:03:01 :
12:03:01 : =======================================
|| FLASHBUS EXTENSION ||
|| | | (O) (O) (O) | CABLE | ||
PLUG IN
CABLE HERE
12:03:03 :
12:03:03 : Booting Phone...
12:03:05 : CPU ID Response: A200341100
12:03:05 : CPU Type: XG110 2.1B
12:03:05 : Phone Booted at after First attempt...
12:03:05 :
12:03:05 : ************************************************** ****
12:03:05 : START INFINEON BUS CHECK
12:03:05 :
12:03:05 :
12:03:05 : Sending PBL 37888 bytes...
12:03:07 : PBL Successfully Sent...
12:03:07 : Sending SBL 65024 bytes...
12:03:08 : SBL Successfully Sent...
12:03:08 :
12:03:08 : Flash Chip Manufacturer: Samsung Electronics Corp.
12:03:08 : Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
12:03:08 : Extended Information: Multiple Bank / Burst / 1.8v
12:03:08 :
12:03:08 : ************************************************** ****
12:03:08 : INFINEON BUS CHECK DONE
12:03:08 :
12:03:09 :
12:03:10 : MCU: V 02.51 29-07-10 RM-689 (c) Nokia
12:03:10 : IMEI: 353794043932038
12:03:10 : Mastercode : 3440450156
12:03:10 : Product Serial Number: DRY995516
12:03:10 : Product Code : 059B341
12:03:10 : Module Code : 0204671
12:03:10 : Basic Production Code: 0597858
12:03:10 : MCU SW Version : V 02.51 29-07-10 RM-689 (c) Nokia IJ
12:03:10 : ADSP Version : p V 02.51\n29-07-10\nRM-689\n(c) NMP\nij
12:03:11 : PPM Version : V 02.51 29-07-10 RM-689 (c) Nokia
12:03:11 : HW Version : 1000
12:03:11 : UEM Version : 1328
12:03:11 : UPP Version : 8850
12:03:11 : LCD Version : UNKWN: IDs: 00:00:00
12:03:12 : ********** SIMLOCK INFO **********
12:03:12 : CONFIG_DATA : 0010100000000000
12:03:12 : PROFILE_BITS : 0000000000030002
12:03:12 : Asic : 11
12:03:12 : Provider : Default Test Operator
12:03:12 :
12:03:13 : Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
12:03:13 : Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
12:03:13 : Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
12:03:13 : Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
12:03:13 : Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
12:03:13 : Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
12:03:13 : Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
Old 03-29-2011, 09:33   #11 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Bro C1 ha RM_689_00 ...............not ccccc1_01
Old 03-29-2011, 09:35   #12 (permalink)
Member: 973412
Thanks Meter: 117
not supported usb cable
Old 03-29-2011, 09:39   #13 (permalink)
Member: 1489030
Sonork: 100.1649409
Thanks Meter: 5,368
Bro wasi plz give me yahooo id then i give u a teamwere ID lz ........thanxxxx
Old 03-29-2011, 09:53   #14 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
@azhergoga007
1. Check your cable, is it working one?
2. Restore box from product support page
3. Be sure, You have pluged cable into 'EXTENSION' port NOT in 'FLASHBUS'
Old 03-29-2011, 10:01   #15 (permalink)
Member: 1531840
Thanks Meter: 4
try to ather version and make restart your pc
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.25826 seconds with 9 queries
