Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Advance-Box
Old 04-02-2011, 07:29   #1 (permalink)
Member: 1351542
Thanks Meter: 31
Pls help 7210 flashing
Number of Image Files: 3
MCU: V 07.23 17-07-09 RM-436 (c) Nokia
IMEI: 359310026063339
Model : Nokia 7210 Supernova
Product Serial Number: DTD130606
Product Code : 0572571
Module Code : 0203868
Basic Production Code: 0563951
Default SN Type : 0
MCU SW Version : V 07.23 17-07-09 RM-436 (c) Nokia I
BT MCM Version : 2222-143C
PPM Version : V 07.23 17-07-09 RM-436 (c) Nokia
HW Version : 1001
RFIC Version : 064c0601
DSP Version : ICPR72_09w17
LCD Version : SHARP
AHNE Version : 30
Retu Version : 15
Tahvo Version : 22
******** Reading SimLock ********
CONFIG KEY: 0000000000000000
PROVIDER KEY: 2440700000000000
Provider : AT&T;U.S.A. (3650)
Counters : 0/3 , 0/10
Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status : Not Locked
SIMLOCK_TEST : PASSED
SECURITY_TEST : PASSED
PHONE_MODE : TEST MODE
Dynamic Camera Configuration
DCC ID : NIMMIIIIRRFF094B2F01
DCC Ver: 002012
Status : OK
PM 120 Found...
PM 308 Found...
SimLock Certificate Saved to : C:\AdvanceBox Turbo Flasher\Nokia\Backup\359310026063339\SL2_certifica te_V 07.23 17-07-09 RM-436 (c) Nokia_359310026063339_Not Locked_115816.pm
Changing MODE : FLASH
AdvanceFBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded First Time
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 80608712 (0xC8) bytes returned
Number of Sub Blocks 7 (0x07)
1 SYSTEM_ASIC_ID 01
Block Length : 21 (15)
BB ASIC Index : 0 (00) CMT
ID DWORD 0 : 00000001
ID DWORD 1 : 00000226
ID DWORD 2 : 00010006
ID DWORD 3 : 030C1921
ID DWORD 4 : 01033000
2 ROM_ID 15
Block Length : 5 (05)
ID DWORD 0 : 00000295
3 ROM_ID 15
ID DWORD 0 : 00000B22
4 PUBLIC_ID 12
ID DWORD 0 : 04700110
ID DWORD 1 : 98F67C56
ID DWORD 2 : 6AC84AE7
ID DWORD 3 : 3EBD3C72
ID DWORD 4 : D305DCF2
5 ASIC_MODE_ID 13
Block Length : 2 (02)
Mode Id : 00
6 ROOT_KEY_HASH 14
Block Length : 17 (11)
Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
7 ROM_ID 15
Block Length : 9 (09)
CRC 0 : 273F6D55
CRC 1 : DFAAF68F
Checksum 0F
SearchForBootstrap_DCT5..
CMT Loader : C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv30_2nd.fg
PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
SearchForBootstrap_DCT5 : No Error - 0 (0x00)
Secondary Loader Sent...
TransmissionTypeRequest_DCT5_NewProtocol
TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
Transmission Type Request Sent...
ConfigurationRequest_DCT5 (RAM_SIZE_BB5 0x0000)..
MCU_CONFIGURATION_RESPONSE_BB5:
MessageID : C1
SubBlocks : 04
1 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
BB ASIC Index : CMT 00
Device Type : RAM 05
Device Index : 00
Manufacturer Code : 0000 -> Flash
Device ID : 0000 -> not detected
Extended/Fixed ID : 0000
Revision ID : 0000
2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : MMC 04
Device Index : 00
Manufacturer Code : FFFF -> Flash
Device ID : 0000 -> BAD FLASH TYPE
Revision ID : 0000
3 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Type : NOR 00
Device Index : 00
Manufacturer Code : 0089 ->
Device ID : 8982 -> NU48F512
Revision ID : 8A31
4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
Block Length : 0B
Device Index : 01
Manufacturer Code : 0000 -> SPANSION
Device ID : 0001 -> not used
Revision ID : 0000
Checksum : 37
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
RAP3Gv30_XSR14_alg.fg
First Algo byte : 56
Flash Descriptor
Device ID : 8982
Revision ID : 0000
Size : 04000000 (64 MB)
VPP Info : 0009
Erase10s : 28
Block1s : 64
BErase1s : 02
Reserved0 : 00
Reserved1 : 00
Reserved2 : 00
VPP INFO : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
C: \AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv30_XSR14_alg.fg
Algo Loader Sent...
SendCodeStart_NewProtocol :
SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
SendAlgoCodeFile_DCT5 : No Error - 0 (0x00)
FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
FUR control Ok...
VPP Enabled by Software
Using Internal VPP
FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
Pabub KEY Request
PhoneInfoRequest_BB5 (Asic Index 00 )
PHONE_INFO_RESPONSE_BB5
PAPUB_KEYS_HASH_RESP_BB5 2A
BB Asic Index : 01
PAPUB Keys Hash : F1DCA5EA5203CD30A64D4D95ABCD621F4AB23026
START READING RPL DATA
Reading : NPC
OK
Reading : VARIANT
VARIANT : Empty
Reading : CCC
OK
Reading : HWC
OK
Reading : R&D
OK
FINISHED READING RPL DATA
RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\359310026063339\3593100260633 39_115852.rpl
FlashInfo.RestartMode : 2
Processing Image File : rm436__07.23.mcusw
CMT Type :
CMT Algorithm :
Secondary Sending Speed : 0Hz
Algorithm Sending Speed : 0Hz
Program Sending Speed : 0Hz
Message Reading Speed : 0Hz
Number of Blocks : 0
Entry Point: 0x0000
Page Format : -1
MAX PAGE : 0x00000000
Operations Failed....
Old 04-02-2011, 07:36   #2 (permalink)
Member: 973412
Thanks Meter: 117
Bro use good cable and try again
Old 04-02-2011, 07:52   #3 (permalink)
Advance-Box's Avatar
Member: 651945
Thanks Meter: 20,118
@harishlalwani
You loaded flash files manually and you are using OLD VERSION of ATF
ATF Software.
Download and install version 7.20 from here:
http://rapidshare.com/files/45176213..._Installer.rar
or
Hotfile.com: One click file hosting: ATF_v7.20_Full_Installer.rar
or
Download ATF_v7.20_Full_Installer.rar from Mirrorcreator - Upload files to multiple file sharing sites
The Following User Says Thank You to Advance-Box For This Useful Post:
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Page generated in 0.25106 seconds with 9 queries
