verry box problem i will parches nmy atf box fron naman jee but from fist time it will burn smales i will camplane to naman je but he will sad dont warry it is normal after 3 month all handset no boot pls tell me what i du i will sent my box to naman je but he told pcb dammage |
2. contact my office and explain them your problem, will try sort out. |
For many peoples box is very good. And for you is bad- so maybe problem is in you or you hand, you didn't think so? |
bro atf is realy good interface but its hardware is have cheap quality............many people complained it see in all forum............plzz improve its hardware quality |
@gsm_future Problem with hardware is only on first revision of PCB. Solution is posted here: http://forum.gsmhosting.com/vbb/f609...ems-o-1021379/ After First PCB, we stopped using that part which causes the problem. PCB Revision was done about 8 months ago already to fix this problem. ATF Lightning also uses a completely redesigned PCB and with carefully selected parts and orginal parts. B.R. |
dear sir many peoples box is very good. And i says bad box because i only flesh12 pc of nokia and my atf is no boot any fone then told me what i say good box or bad box |
@gsm_future Blue Light only problem of NEW PCB can be caused by Wrong BOX Firmware Flashing. That is why in ATF Software now, you can select Manually which FIRMWARE to use when you want to restore your ATF BIG BOX. BLUE LIGHT Problem can also be caused by Wrong drivers etc..., because Drivers are overwritten by other OLD DRIVERS from other Boxes... |
THANKS ATF TEAM I WILL REAPER MY ATF WITH UR GIDENCE modify_pcb IT WILL WORKS WELL THANKS A LOT |
