What is ATF [Advance Turbo Flasher] ? ATF [Advance Turbo Flasher] Features: Unique Hardware Features: 480 mbps HIGH-SPEED USB 2.0 Connection ( First In World ) - PC connection is 40 times faster than any other box in the market 100% FPGA based implementation of the flash bus protocols( First In World ) -Significantly faster and more stable than regular MCU based boxes Adjustable VCCIO Logic Levels (3.30v, 2.80v and 1.80v) -Compatible with old phone model Logic Level (3.30v) -Compatible with new phone model Logic Level (2.80v) -Compatible with future phone model Logic Level (1.80v) Proper ESD protection on the FLASHBUS port -Protects phone damage due to Electro Static Discharge Ultra Fast Flash Clock currently upto 15 Mhz (First In World ) -Firmware updatable to support upto 60 Mhz without the need of hardware modifications Internal VPP Flash Voltage Generator (3.0v, 5.0v, 9.0v and 12.0v) -Makes Flash Erasing on slow phones faster -Does not require external power adapters to generate 9.0v and 12.0v -Uses a Fast Switching SEPIC design Hardware Upgradable using internal Expansion Slots Micro-SD Card Slot for future developments Dual RJ-4x Ports (RJ-45 and RJ-48) for External Communication -The RJ-45 Port is the main "Turbo" Bus -The RJ-48 Port is the Secondary Bus that can be made to support parallel or serial protocols such as 2Mbps UART, JTAG, and Flashing Protocols. 5 Multi Colored LED Indicator Lights -Rectangular Orange : FBUS_RX -Rectangular Green : FBUS_TX -Circular Blue : USB_POWER / ACP-X_POWER -Circular Green : VBATT -Circular Orange : VPP http://www.advance-box.com/images/advanceatf01.jpg Unique Software Features: As the Name Itself says its a powerful tool which can flash all Nokia phones including new protocols via Fbus cable in unbelievable speed and stability in compare of any other 3rd party tool which currently present in market - New Protocols Device X3 ,X6 ,E52 ,E55 ,6700 ,etc and all Rapuyama Fbus Flashing (First In World) - High Speed Turbo Flashing with Full Speed (First In World) http://www.gsmhacker.com/atf4.jpg Tuning & Maintenance - Life Timer Tuning not only reset but you can write your desire life time(First In World) - Factory Reset - Warranty Edits - Production Data Edits - Camera Configuration Read/Write Imei & locks - Unlock Using Code Calculation so no more damages to phone warranty or certificates ( Supports SL1 SL2 & Some So called SL3 ) - Unlock / Relock Using RPL Method - Super Dongle Key Repair PM ( Permanent Memory) - Read Write Permanent Memory Using SX4 Server Phone Test - For Self Test Phone Features We will update features when we complete more feature on which we are working now. More cool things still under development. Buy only from ATF (Advance Turbo Flasher) authorized resellers: ATF [Advance Turbo Flasher] Authorized Distributors and Resellers List ATF [Advance Turbo Flasher] official web sites: International - http://www.advance-box.com/ ATF [Advance Turbo Flasher] official support forums: World Wide: Advance Turbo Flasher - GSM-Forum Indonesia: ATF (Advance Turbo Flasher)) Philippine: Gsmph Syria: Arabic Support (Syria) GsmVIP Chinese support forum : ATF Box Vietnam: Saigonmobile !!! Feel The Power Of Turbo Flashing Speed !!! |
nice and must use in ur mobile repairing shop |
add also all supported units. |
Yes, very powerful box for flash etc, more feature will be soon :-) Stock instant, Can order from us (www.eoem.cc) BR., Denis |
remove your tourbo flasher box it is very very very bad box of year 2010 i throw in toilet not working no no dct4 no usb flashing not for all models every time showing erer erer erere i buy this box in indian rupee 6500 rs i want sale this box 5000rs if any one are intersted plz call me in india 09892399914 |
or you only know shouting language so i can talk with you in you language ? or you were screwed by our competitor ? so now tell me what is your problem ? |
good new box for sure overtaking previous errors of other tools. |
i download new version but my problem is same i formate my destop but problem is same now plz tel me what i do |
did you post any logs? did you contact any team members for your problem? did you discusse your problem with any team member? look just contact me so i can help you Sonork: 100.50000 yahoo: javajohn222 |
BR Thomas |
Any new device has his merits! The key is to see your team to do the follow-up service! I have bought the equipment, initial sense is good still! Hope you be perfected as soon as possible |
ATF Best BOX Ever Handled Hi Im from Golden Motor Telecom - Telecare Service Center Dubai U.A.E. I just bought ATF from TST and its really work fast flashing and make dead phone!!! More Power to ATF Team!! from tcdxb |
BR Thomas |
中文支持一个………………………………································ ······································ |
then usb support , only after achieve the status of perfect nokia tool go for non nokia tab. presently all users of ATF bought it for repairing nokia phones , so wishing the team all the best to make it perfect nokia tool regards, NEIL |
