Whats wrong with this flashing to X5-01??? Code: Number of Image Files: 5 |
Hi, Uncheck this file: Miley_MC011_SD_2G_1.2.fpsx ... and flash phone again. It will be okay. BR |
Thank u. Worked. Phone flashed succesfully without problems. Now, Phone power on but its stuck on Nokia logo. As I told, initially phone was come with memory full and phone startup failed problems, but at least was can power on... What can be the problem? |
Full erase phone and flash with last flash file. Backup all important files. PM,RPL etc. |
bro :) |
@gsmator Can you get TEST MODE on the phone and Scan Phone? 1. Buscheck Phone to get TEST MODE 2. Go to FORMAT FS Tab and FORMAT all detected DRIVES Post Scan Phone Logs if phone is going into test/local mode. Your FLashing logs also shows some problems... 1. The File sequence is wrong,,, as Mass Memory should be flashed LAST This file: Miley_MC011_SD_2G_1.2.fpsx... So when you got the error,,, that means ROFS2 and UDA was not flashed at all to the phone... Solution: Download again the flash files and make sure you include the VPL file... or Make sure when you manual load the flash files that you put the MASS MEMORY FILE last! and that you have a 2GB SD Card inserted to the SD Card Slot of the phone... Miley_MC011_SD_2G_1.2.fpsx Easiest Solution: Do not flash This file: Miley_MC011_SD_2G_1.2.fpsx... Only flash the other 4 files which you already have... B.R. |
It can be hardware problem also.. I'm talking about "startup failed and memory full" ... BR |
Yup,, same problem as those E52s.... 250 degrees Celsius rework + 2.5 centimeters distance from the stacked rapu/onenand in a circular motion and 2.5 minutes should do the trick... However, customer might come back after 2.5 days with the same problem. Sometimes I put 325 degrees Celsius and 3.25 minutes if problem persists |
And customer might come back again after 3.25 days? :D |
