04-06-2017, 18:08 | #47 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Hello. Atf Gold coming with ALL module Activated, like Atf Jtag, Atf Network. So, or post clear Log and Screenshoot of this Atf Network NOT activated....or you are doing some error in Activate ATF Net. How is possible that you reseller have "Forgot" this activaction Who is reseller? |
04-07-2017, 04:26 | #48 (permalink) |
Freak Poster Join Date: Aug 2011
Member: 1626569 Status: Offline Thanks Meter: 6 | atf gold not activate jtag and network hi i have atf gold box . re seller GSM-Sources but my box without activate jtag and network. i couldn't login to support site. here is information about my gold box ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : AdvanceBox Turbo Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : F8B279F97C559620BFB9BFF4 Box Status : ACTIVATED ================================================ Box Successfully Initialized ================================================ |
04-07-2017, 04:49 | #49 (permalink) |
Member: 1626569 Status: Offline Thanks Meter: 6 | here is image of box and others ATF gold box image re seller GSM Sources https://preview.ibb.co/dNX2mF/box1.jpg https://preview.ibb.co/mpkitv/box_2.jpg ATF Jtag not active https://preview.ibb.co/ispRDv/113049.png ATF network not active https://preview.ibb.co/dyqYtv/acc.jpg Support section error https://preview.ibb.co/m6G6Dv/loh.jpg |
04-07-2017, 09:25 | #50 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | As i can se from this Log you Box is Activated: Quote:
For Jtag Not activated: Delete " hosts " file from C:\WINDOWS\system32\drivers\etc and try to Activate!! For other issue about Activaction contact you reseller for Activaction. BR | |
04-07-2017, 14:13 | #52 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Seen? what want means when one reseller "FORGOT" that Atf Gold must be selled with ALL activaction already Many "Reseller" have little memory and for me remain NOT trusted Reseller. Put here his name in Public, in mode that other users NOT buy from him. BR allumts |
04-10-2017, 16:17 | #55 (permalink) |
Junior Member Join Date: Jul 2013
Member: 1981082 Status: Offline Thanks Meter: 0 | i tried with ATF 12.60 & 12.67 & 12.70, but all server busy. ================================================ Advance Turbo Flasher Found ================================================ Driver Version : 00021206 Library Version : 00030210 Box Type : ATF Nitro Box Firmware : LogiCore 11.0.10 Software Version : v12.70 AdvanceBox SN : B6CADFF0BD5EA80EAD2A73FD ========================================= Please Try Again Later (Server Busy) ========================================= ================================================ ATF SOFTWARE IS NOT ACTIVATED ON THIS PC Please Activate your ATF Software ================================================ * Follow these Instructions 1. Connect this PC to the INTERNET 2. Restart ATF Software ================================================ Box Successfully Initialized ================================================ VBATT Powering Down <<<< VBATT Powering Up >>>> SET VCCIO Level Done SET BSI Load Done |
07-07-2017, 06:07 | #57 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2733918 Status: Offline Thanks Meter: 0 | Hello,Allumt,Is Server down, Still get error server connection = 12:57:19 : Driver Version : 00021206 12:57:19 : Library Version : 00030210 12:57:21 : Box Type : ATF Lightning 12:57:21 : Box Firmware : LogiCore 11.0.00 12:57:21 : Software Version : v12.70 12:57:21 : AdvanceBox SN : DAF57245D478BCB3D70E4255 12:57:21 : 12:57:21 : 12:57:21 : Please update your Box Firmware 12:57:21 : 12:57:21 : 12:57:21 : 12:57:21 : * Make sure you put ATF Software in Windows 12:57:21 : FireWall Exclusion List 12:57:21 : 12:57:21 : * Make sure you put ATF Software in your 12:57:21 : Virus Scanner Exclusion List 12:57:21 : 12:57:21 : ================================================ 12:57:21 : Box Successfully Initialized 12:57:21 : ================================================ Need help,Many Thanks BR |
07-07-2017, 09:32 | #59 (permalink) |
Member: 2733918 Status: Offline Thanks Meter: 0 | Thank you BR Hello allumts,I have add you SKYPE,and i dont know how to contact the Team or support? i just want to ask question,if the Firmware server DOWN,WHO can solve this problemand WHEN times ? Thank you in advance. BR |
