Wont flash Lumia 610! <<< ANSWERED >>> Windows Phone Flashing Started AMSS File Found: RM835_12w16_prod_generic_amss.esco WPOS File Found: RM835_12160_prod_426_01_boot.esco USER AREA ERASE File Found: RM835_12w16_prod_generic_user_area_erase.esco WARNING: OSBL File is not Loaded WARNING: MODEM ADSP File is not Loaded ================================================== ==== Windows Phone Lumia Flasher ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== ================================================ Basic Phone Information ================================================ ================================================ Extended Phone Information ================================================ Rebooting to OSBL MODE Switching to NOKIA MODE Polling Ports... (Please Wait) When I pressed the volume up button, and connected the usb cable, in the software only blink under the "inacializing connection" and maybe the "windows mobile function (Nokia Mode)" Blink so quickly, that I cannot read correctly.... Drivers uninstalled, Win USB Drivers x86 reinstalled. So, why wont flash the atf this phone? |
@Rocco Make sure you CLOSE ZUNE or Nokia Care Suite softwares... Turn ON Phone and wait until phone UI menu is 100% loaded. Connect USB cable to phone. On ATF Software, make sure you selected "Windows Phone" and "610" then click Scan Phone... You should see something like this... [img[http://174.120.45.27/tmp/610.png[/img] Click "Phoenix INI" so that the flash files will be loaded. Then click Flash Button. Code: Windows Phone Flashing Started |
Wont Work! Zune uninstalled Zune drivers from aft map installed. Scan phone OK but, by flashing its same error: Only blink under the "inacializing connection" and maybe the "windows mobile function (Nokia Mode)" I try with another pc...... ================================================== ==== If the Phone is ALIVE 1. Power On the Phone and Connect it to the USB Port If the Phone is DEAD 1. Press and Hold the VOLUME UP button 2. Connect it to the USB Port while still Pressing the VOLUME UP button 3. Continue to Press the VOLUME UP button for 8 more seconds ================================================== ==== Switching to NOKIA MODE Polling Ports... (Please Wait) ================================================ Basic Phone Information ================================================ SW Version : 1066.0000.8779.12201 IMEI Plain : 353263055895053 HW Version : 112.1569.1.0 Product Code : 059P5P0 Basic Product Code: 059L3R3 Module Code : 0205127 PSN Number : 47FAF46AB NCSD Version : 1.9 ================================================ Extended Phone Information ================================================ Public ID : F4329E5B2A0A0B169BF8912C6AF9028A Wireless Lan ID: A4:E7:31:74:A4:06:00:00 Bluetooth ID : A4:E7:31:72:CF:46:00:00:FF:FF:FF:FF Rebooting to OSBL MODE |
So On another PC: -I installed the aft 8.70 -connected the lumia 610 and installed the device drivers from the "c:\AdvanceBox Turbo Flasher\Driver\Zune Drivers\" map. - click to scan phone.. - Now the phone get to another modus Scanning USB Ports... Switching to NOKIA MODE Polling Ports... (Please Wait) -Pc finded new hardware: USB\Vid_0421&Pid_05ef -The "c:\AdvanceBox Turbo Flasher\Driver\Zune Drivers\" map not cotains the correct driver to this hardware! |
- I installed the drivers from the "c:\AdvanceBox Turbo Flasher\Driver\Lumia Phone Drivers\" map. This contains the good drivers now. - schan phone will be OK! - Flash started, VOL UP holded, and just blink the "inacializing connection" and maybe the "windows mobile function (Nokia Mode)" |
