04-11-2011, 02:35 | #1 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Shenzhen, Hong Kong, Bangkok
Member: 611 Status: Offline Sonork: 100.33333 Thanks Meter: 29,604 | World's Fastest SL3 LBF "MARKOV" EDITION ---> oclHashcat-lite v0.10 by atom !!! Download it here: http://hashcat.net/oclhashcat-lite/ Code: This release is a big step forward. We have added both, many major and many minor features. Per-position markov-chains, aka markov-attack/incremental-attack/charset-files The markov-attack is a statistically based brute-force like attack, but instead of specifying a charset or a mask, we specify a file. This file is once generated by ourself in a previous step. It contains statistical informations which are made out an automated analysis of a given dictionary. It can fully replace Brute-Force since it covers the full keyspace. In Brute-Force Attack (or in Mask Attack) we can limit the keyspace by setting a smaller charset in order to reduce the attack-time. In Markov Attack we have something similar, the "threshold". All you do is to specify a number. The higher the number, the higher the threshold to add a new link between two characters on the two-level table on which the markov-attack bases on. This background is not so important, just remember that the lower the value, the smaller the keyspace and thus the faster the attack is. Check these threads for more details http://hashcat.net/forum/thread-1265.html http://hashcat.net/forum/thread-1285.html http://hashcat.net/forum/thread-1291.html Use .ptx ad .llvmir intermediate kernels The kernels are distributed in an "intermediate" format (aka IL). It cant be reversed to original C code but still its not a binary format that can be used for execution. The JIT (just-in-time) compilers from both OpenCL and CUDA, which ship with the driver, compile the final byte-code out of the IL. This takes a few seconds per kernel but once its done the byte-code is cached (CUDA does it automatically, OpenCL not but we add a function to do the same as CUDA does). This has some nice advantages: Not 32/64 bit specific Less HDD space Smaller .7z Less problems with driver specific problems as we often see with Catalyst There is no more need to release a new oclHashcat-* in case a new driver optimization has been added. oclHashcat-* caches driver specific. If it recognizes a driver change it will rebuild thge byte-code from the IL, but using the new JIT from the new driver resulting in driver specific optimized byte-code. Retaining GPU temperature When I started with oclHashcat-* Hardware mangement support, some people asked me for add support for fan-speed. For a long time I was not interessted in adding fan-speed code to oclHashcat-* since this is the job for the driver or some specialized controling software. I did not change my mind completly on this, but still we have added some fan-speed controlling code. The new parameters are: Code: --gpu-temp-disable Disable temperature and fanspeed readings and triggers --gpu-temp-abort=NUM Abort session if GPU temperature reaches NUM degrees celsius --gpu-temp-retain=NUM Try to retain GPU temperature at NUM degrees celsius (AMD only) So what this thing is doing is: If the temperature configured with the new --gpu-temp-retain parameter is reached, it starts to increase the fan-speed by 1 percent each second. Thats all. If you imagine a scenario what this means you will come to the conclusion that this feature also enables you to enfore your GPU running always to a very specific temperature. Some notes: --gpu-temp-disable you can completly disable all the temperature stuff. --gpu-temp-retain currently only works for AMD. --gpu-temp-abort parameter is just the renamed version of the old --gpu-watchdog. Both parameters accept the 0 value which disables only this specific feature. This means you can step back to the old behavior by specifying --gpu-temp-retain 0. The default for --gpu-temp-abort is still 90c. The default for --gpu-temp-retain is 80c. Built-in benchmarking mode Code: * Benchmark: -b, --benchmark Run benchmark --benchmark-mode Benchmark-mode, see references below Nothing much to explain here I think, but some notes to the benchmark mode: As long as you do not set the --benchmark-mode you can modify all the configuration parameters you always use. Something like -d, -n, --gpu-accel or --runtime. With --runtime you can specify the duration how long each test lasts. If you add -m you can limit to a specific hash-type. If you do not set it, it will iterate through all hash-types. All unneccessary parallel threads like hardware monitor, restore-support and outfile-watch are disabled. Also the quiet mode is enabled. On NVidia, the hashes based on SHA256, SHA512 and DES are limited to -n 32, otherwise the driver throws the error cuStreamSynchronize() 702. New Algorithms supported SHA512 Oracle 7-10g, DES(Oracle) md4($pass.$salt) sha256($pass.$salt) sha512($pass.$salt) Full Change Log: Code: type: feature file: kernels desc: added -m 0910 = md4($pass.$salt) type: feature file: kernels desc: added -m 1410 = sha256($pass.$salt) type: feature file: kernels desc: added -m 1700 = SHA512 type: feature file: kernels desc: added -m 1710 = sha512($pass.$salt) type: feature file: kernels desc: added -m 3100 = Oracle 7-10g, DES(Oracle) type: feature file: kernels desc: on AMD, switched from .kernel to .llvmir to reduce diskspace type: feature file: kernels desc: on NV, switched from .cubin to .ptx to reduce diskspace type: feature file: kernels desc: added kernel cache to avoid unnecessary recompilation cred: m4tr1x type: driver file: kernels desc: added support for NVidia CUDA 4.2 type: driver file: kernels desc: added support for NVidia sm_30 gpu-architecture [ Kepler ] type: driver file: host programs desc: added support for NVAPI R300 type: driver file: host programs desc: added support for NVidia NVML library and got rid of nvidia-smi command type: driver file: host programs desc: added support for AMD ADL v4.0 library type: feature file: host programs desc: splitted --gpu-watchdog to --gpu-temp-disable and --gpu-temp-abort type: feature file: kernels desc: added benchmarking mode cred: m4tr1x type: feature file: host programs desc: added --gpu-temp-retain to try retain temperature at NUM degrees celsius cred: m4tr1x type: feature file: host programs desc: workarounded AMD bug in clGetDeviceInfo() CL_DEVICE_MAX_CLOCK_FREQUENCY cred: m4tr1x type: feature file: kernels desc: added early check for zero-length password hashes cred: m4tr1x type: feature file: host programs desc: show LM-half as soon as it is cracked type: feature file: host programs desc: added support for charset files and some example charset files type: feature file: host programs desc: added support to read hashes from file type: feature file: host programs desc: implemented base64 parser that would allow for dynamic salt lengths in nsldaps type: feature file: host programs desc: added fan-speeds to status display type: feature file: host programs desc: removed --pw-skip-plain and --pw-limit-plain as they are incompatible to markov type: bug file: host programs desc: fixed bug in status display if ETA calculated > 60 years cred: arex type: bug file: host programs desc: fixed bug in Oracle 11g hash parsing function, salt length increased to 10 byte cred: flipit type: bug file: host programs desc: fixed bug in salt-length parser for MyBB1.2 hashes cred: code841 type: change file: host programs desc: changed default charset to the one which passpal outputs running on rockyou.txt cred: arex Welcome to oclHashcat-lite v0.9. Message from Atom (Hashcat-Lite Developer + Bruteforce Guru) Code: Hello Hashcat-Users, I am proud to announce version 0.09 of the oclHashcat-lite series. Download it here: http://hashcat.net/oclhashcat-lite/ The highlights of this release are: Support for AMD GCN cards (hd7xxx series) I already wrote some more detailed informations about the integration here: http://hashcat.net/forum/thread-817.html This card is a true DES killer. I wrote some more detailed informations about this topic here: http://hashcat.net/forum/thread-846.html Added the LM Algorithm After so many people requested this algorithm in the feature request section I decided to add it even I had not interesst in it. However, it turned out it was a good investment of time. I realized how many pentester still have need for it. See here for discussion: http://hashcat.net/forum/thread-167.html Vectorized datatype kernels for sm_21 NVidia architecture This a massive improvement for low- and mid-ranged NVidia GPUs. The gtx560Ti @ MD5, for example, increased by 23% (1252 Mhash/s -> 1660 Mhash/s). This improvement can be seen on nearly all algorithms for this architecture. MD4 based algorithm tuning To make it short: I found a way to reverse another step in MD4. Especially the NTLM and DCC algorithm benefit from this code change. The hd6990 @ NTLM broke the 20000 Mhash/s mark on stock clocks. Average increase is around + 9% (19100 Mhash/s -> 20864 Mhash/s). Updated EULA This goes back to a discussion we had HD Moore from Rapid7. The updated EULA is a lot more relaxed for professional pentesters than before. See changelog for more details. Fixed some major issues On thing that many user complained about in oclHashcat-lite 0.08 was its "instability" and problems with session restore. This popped in because of a default-settings change in oclHashcat-lite v0.07. It has been set back to oclHashcat-lite v0.06 default. Discussion can be found here: http://hashcat.net/forum/thread-681.html Harmonization with oclHashcat-plus The --help page, the --outfile-format and the -m parameter values, in case of an overlap, are now equal to oclHashcat-plus v0.08. It will help to avoid confusion, thats why I am planning to do the same change on CPU hashcat in the next version. Official Download Link: http://hashcat.net/oclhashcat-lite/ Official Hashcat Forum: http://hashcat.net/forum/ Official SL3 BF Cracking Guide http://hashcat.net/wiki/cracking_sl3/ oclHashcat now have a special SL3 Kernel with 12.24% Speed Increase on ALL SL3 LBF Tasks!!! Download here: (yes it's 100% free) Download oclHashcat-lite-0.06.7z - hashcat, advanced password recovery Changelogs from v0.05 to v0.06 Code: * changes v0.05 -> v0.06: type: performance increase file: kernels desc: MD5: AMD 1,07%, NVidia 0,62% desc: md5($pass.$salt): AMD 1,37%, NVidia 8,10% desc: md5(md5($pass)): AMD 0,94%, NVidia 0% desc: vBulletin < v3.8.5: AMD 0,30%, NVidia 0% desc: SHA1: AMD 11,14%, NVidia 13,62% desc: sha1($pass.$salt): AMD 16,96%, NVidia 39,10% desc: MySQL > v4.1: AMD 1,99%, NVidia 7,15% desc: MD4: AMD 13,46%, NVidia 3,34% desc: NTLM: AMD 13,16%, NVidia 2,57% desc: DCC: AMD 34,20%, NVidia 0,89% desc: MSSQL: AMD 11,23%, NVidia 17,89% desc: SL3: AMD 12,24%, NVidia 13,48% desc: Oracle 11G: AMD 16,93%, NVidia 13,53% type: password length increase file: kernels desc: MD5: from 15 to 55 desc: md5($pass.$salt): from 15 to 55 desc: md5(md5($pass)): from 15 to 55 desc: vBulletin < v3.8.5: from 15 to 55 desc: SHA1: from 15 to 55 desc: sha1($pass.$salt): from 15 to 55 desc: MySQL > v4.1: from 15 to 55 desc: MD4: from 15 to 55 desc: NTLM: from 15 to 27 desc: DCC: from 15 to 27 desc: MSSQL: from 15 to 25 desc: SHA256: from 15 to 55 desc: Oracle 11G: from 15 to 45 type: feature file: kernels desc: added -m 15 = vBulletin > v3.8.5 cred: chick0n type: feature file: kernels desc: increased salt length for DCC from 7 to 19 cred: Rabbitz type: feature file: host programs desc: hardcoded cpu affinity mask to one (cpu #0) to save energy cred: randyberger type: feature file: host programs desc: added --pw-skip and --pw-limit parameters for distributed computing cred: d3ad0ne type: feature file: host programs desc: added status codes on exit, see status_codes.txt for listing cred: hermix type: bug file: host programs desc: rewritten restore function check from scratch cred: anonymous type: bug file: host programs desc: fixed multiple instances check cred: FractalizeR type: bug file: host programs desc: fixed 8 bit characters from russian alphabet cred: Rolf 8,8xx Million Hash Per Second! HW Specs: 4 x 5870 @ 980 Mhz New and Faster SL3 LBF Kernel UPDATE for oclHashcat-lite v0.05 by atom Official Download Link: Download oclHashcat-lite-0.05.7z - hashcat, advanced password recovery Official oclHashcat-lite Homepage: oclHashcat-lite - advanced password recovery Official Discussion Forum and Discussion Thread: hashcat Forum Featuring: 1. Ultra Fast and Stable SL3 Kernel 2. Upto 4% Faster HASH Speeds on 5xxx and 6xxx Cards 3. 100% Free Software !!! 4. Fixed --restore for Resuming BF Tasks 5. Easier Command Line IMPORTANT CHANGES FOR COMMANDLINE INPUT 1. Change -m 101 into -m 1900 2. Change --output-file into --outfile 3. No need to use --pw-min and --pw-max 4. No need to use --hex-charset --hex-salt EXAMPLE: ORIGINAL COMMANDLINE for v0.03: oclHashcat-lite64 3D5D9E11835243015407B7BA327E30CCB70F4DB0:003519730379149500 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=351973037914952.txt NEW COMMANDLINE for v0.05: oclHashcat-lite64 3D5D9E11835243015407B7BA327E30CCB70F4DB0:003519730379149500 -1 00010203040506070809 -m 1900 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 -n 160 --outfile-format=1 --outfile=351973037914952.txt REAL SPEED with 2 x HD 6990 @ 950 Mhz, 7,6xx MILLION HASH per Second !!! REAL SPEED with 2 x HD 5970 @ 950 Mhz, 7,8xx MILLION HASH per Second !!! Fastest SL3 LBF Free and UPDATED!! OlcHashcat-lite v0.03 by atom!! (HD6xxx Supported). Thanks to atom for providing us with 100% Free and 100% fast SL3 LBF Software. Also 100% support for new ATI 6xxx cards (6970, 6990 etc)... BR Thomas BUGFIXES in v0.03 type: bug file: cudaHashcat-lite, oclHashcat-lite desc: fixed a bug in security causing hash was not found randomly cred: RaNdy type: bug file: cudaHashcat-lite, oclHashcat-lite desc: fixed a bug in --restore if command-line contains --pw-skip cred: Ciukut type: bug file: cudaHashcat-lite, oclHashcat-lite desc: fixed a bug in --restore if command-line contains --pw-min cred: hermix information taken from: oclHashcat-lite v0.03 official download area: oclHashcat-lite - advanced password recovery GPU Driver and SDK Requirements:
================================================== For more information about how to setup Windows or Ubuntu with oclHashcat-lite, you can visit atom's official forum or you can also post your inquiries in ATF Section on this thread: Fastest LBF Free Download!! OlcHashcat-lite v0.2!! HD6xxx Supported! You can now build yourself the fastest LBF "******* PC" by using: Motherboard: MSI Big Bang Marshal Video Card: 8 pieces ATI 6970 This will give you 14,170 Million HASH/s on STOCK CLOCKS... Overclock with give you more than 15,xxx HASH/s and the video cards will still be less than 80 degrees celcius with the stock cooling system. ================================================== ================================================== Here is OFFICIAL and UPDATED "HOWTO" for hashcat-lite v0.02 oclHashcat-lite SL3 cracking howto Check out Post # 6 Where atom discusses about MULTIPLE PC Setups to attack a single phone. atom's forum is 100% open for discussion about his work... [B]Happy BF to all! Last edited by Advance-Box; 07-02-2012 at 12:05. |
The Following 177 Users Say Thank You to gsmfun For This Useful Post: |
04-11-2011, 04:25 | #8 (permalink) |
No Life Poster Join Date: Dec 2007
Member: 651945 Status: Offline Thanks Meter: 20,118 | oclHashcat-lite, advanced password recovery Usage: oclHashcat-lite64 [options] hash [mask] Startup: -V, --version print version -h, --help print help --eula print eula Logging and Files: --quiet enable quiet -o, --output-file=FILE output-file for recovered hash --output-format=NUM 0 = hash*** 1 = hash:hex_pass 2 = hash***:hex_pass Misc: --hex-salt assume salt is given in hex --hex-charset assume charset is given in hex --runtime=NUM automatically abort session after NUM seconds Resources: --restore restore previous session --gpu-async use non-blocking async calls -d, --gpu-devices=STR CUDA devices to use, seperate with comma -n, --gpu-accel=NUM workload tuning: choose 1, 8, 40, 80 or 160 scales best if you choose the number of SP per SM --gpu-loops=NUM workload fine-tuning if -n is not precise enough --gpu-watchdog=NUM automatically abort session if NUM celsius (ATI only) Built-in charsets: ?l = abcdefghijklmnopqrstuvwxyz ?u = ABCDEFGHIJKLMNOPQRSTUVWXYZ ?d = 0123456789 ?s = !"#$%&'()*+,-./:;<=>?@[\]^_`{|}~ ?h = 8 bit characters from 0xc0 - 0xff ?D = 8 bit characters from german alphabet ?F = 8 bit characters from french alphabet ?R = 8 bit characters from russian alphabet Custom charsets: -1, --custom-charset1=CS user-definable charsets -2, --custom-charset2=CS example: -3, --custom-charset3=CS --custom-charset1=?dabcdef -4, --custom-charset4=CS sets charset ?1 to 0123456789abcdef Attack options: --pw-min=NUM password-length minimum --pw-max=NUM password-length maximum Attack modes: -m, --hash-mode=NUM number of hash-mode 0 = MD5 1 = md5($pass.$salt) 3 = md5(md5($pass)) 5 = vBulletin 100 = SHA1 101 = sha1($pass.$salt) 300 = MySQL4.1/MySQL5 900 = MD4 1000 = NTLM 1100 = Domain Cached Credentials 1400 = SHA256 Example for Windows XP/Vista/7 64-bit and ATI Cards 5xxx or 6xxx: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt Example for Windows XP/Vista/7 32-bit and ATI cards 5xxx 6xxx: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 oclHashcat-lite32 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt Example for Windows XP/Vista/7 64-bit and NVIDIA Cuda Cards: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 cudaHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt Example for Windows XP/Vista/7 32-bit and NVIDIA Cuda Cards: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 cudaHashcat-lite32 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt B.R> Last edited by Advance-Box; 04-11-2011 at 10:27. |
The Following 30 Users Say Thank You to Advance-Box For This Useful Post: |
04-11-2011, 04:30 | #9 (permalink) |
No Life Poster Join Date: Sep 2004 Location: NeverL@Nd
Member: 82106 Status: Offline Thanks Meter: 1,208 | hmm... start to make totorial how to use it with ATF sir, then ATF would be the Leading in Nokia SL3. Undoubtly !! |
The Following 2 Users Say Thank You to Chevka For This Useful Post: |
04-11-2011, 04:35 | #12 (permalink) |
Member: 651945 Status: Offline Thanks Meter: 20,118 | Step 1: Download Catalyst 11.3 with Integrated OCL Driver here for Windows 7 64 bit... ATI Radeon Download Catalyst 11.3 with Integrated OCL Driver here for Windows 7 32 bit... ATI Radeon Step 2: Download oclHashcatlite software by atom here: oclHashcat-lite - advanced password recovery Step 3: Now let us convert your LOGS for Local Brute Force command line: Example File: 356046033398077.sha Open 356046033398077.sha in Notepad and you will see this: 0FA0023A35BE661697AAE37123CF06D18940C9E0 This is your HASH... And your IMEI is ... 356046033398077 Now take your HASH and first 14 digits of the IMEI and compose command line like this: Example for Windows XP/Vista/7 64-bit and ATI Cards 5xxx or 6xxx: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 oclHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt Example for Windows XP/Vista/7 32-bit and ATI cards 5xxx 6xxx: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 oclHashcat-lite32 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 -n 160 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt Example for Windows XP/Vista/7 64-bit and NVIDIA Cuda Cards: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 cudaHashcat-lite64 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt Example for Windows XP/Vista/7 32-bit and NVIDIA Cuda Cards: IMEI: 356046033398077 HASH: 0FA0023A35BE661697AAE37123CF06D18940C9E0 cudaHashcat-lite32 0FA0023A35BE661697AAE37123CF06D18940C9E0:003560460333980700 -1 00010203040506070809 -m 101 ?1?1?1?1?1?1?1?1?1?1?1?1?1?1?1 --pw-min=15 --pw-max=15 --hex-charset --hex-salt --output-format=1 --output-file=356046033398077_COD.txt B.R> Last edited by Advance-Box; 04-11-2011 at 10:29. |
The Following 75 Users Say Thank You to Advance-Box For This Useful Post: |
04-11-2011, 04:39 | #13 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: Auckland
Member: 160928 Status: Offline Thanks Meter: 338 | Quote:
LinkBacks (?)
LinkBack to this Thread: https://forum.gsmhosting.com/vbb/f609/worlds-fastest-sl3-lbf-markov-edition-oclhashcat-lite-v0-10-atom-1244843/ | ||||
Posted By | For | Type | Date | |
LBF computer configuration | This thread | Trackback: | 07-04-2011 20:15 |
