Tutorial - How to use & Unlock Video Unlock Video For ZTEUNLOCKER f285 Unlocking video Same step For C33x OR c321 Phones !! Regards Advance cdma Team |
Repair white light in c5589 for repair it User special Pinout (UART) Select port -> Put phone in download mod 5 + pwr -> Go to huawei tab -> tik boot Repair for c5589 c115xx -> make repair When software ask for mmc flash Remove phone Use original file for mmc flashing (from support ) insert mmc press * + 9 + PWR wait for complete flashing Note ( Make sure battery full ) Regards Advance-cdma |
Unlocking C5589 With combo multi unlocker for Unlock it User special Pinout (UART) Select port -> Put phone in download mod 5 + pwr -> Go to huawei tab -> tick boot & Select C5589b115 -> make unlock Enjoy Safe unlocking Regards Advance Cdma Team |
Unlock Zte C33X , C321 ,F285 In one Click !! Download New Zte unlocker.exe 1: Select Port -> Select Model 2 : Make Unlock Without Any Tick ( No Any Tick ) 3 : After Some Time Software Asking Like This 4 :Remove Battery inset Again Until Phone Complete on In FTM Mode http://www.mygsmindia.com/vbb/attach...1&d=1263994367 5 : Connect Set Press OK 6 : After 5 Sec it Saying Done !! Regards Advacecdma Team |
LG Blinking & Dead Repair !! IF PHONE BECOME DEAD OR BLINKING AFTER THIS ERROR Quote:
PRESS 5+PWR FOR Emergency Mode TICK ON "Emergency Mode" MAKE UNLOCK Software will Ask you For Ver confirmation If You know it select it ( if you don't know make flash in Emergency Mode with Lg Tool ) * If boot mode Not Supported In Some Ver Make flash With Lg tool * All That New Sec Lg have Limited LEFT FOR Emergency Mode 3/3 IF In 3 time YOU fail For Emergency Work Then no way For Repair It How can flash with Lg tool
Advance Cdma Team |
How to c5589 v-jazz contact service repair. TO REPAIR C5589 V-JAZZ CONTACT SERVICE 1 USE USB CABLE COME WITH PHONE. 2 POWER ON PHONE FULLY INSERT USB CABLE LET IT AUTO INSTALL HUAWEI DRIVER. 3 ONCE READY SELECT PORT MODEL AND GO TO HUAWEI TAB. 4 CLICK ON Repair User Code & CS button and your phone will be repaired and restarted. |
How to lg emergency unlock or uart unlock. TO DO LG EMERGENCY UNLOCKING OR UART CABLE UNLOCKING OR REPAIR. 1 USE UART(RJ45) CABLE PLUG TO PHONE BACK SIDE. 2 CONNECT PHONE BY PRESSING 5 + POWER. 3 USE BUTTON BootDetect. 4 ONCE SOFTWARE SHOW YOU PHONE IS DETECTED IN BOOT MODE. AND MOST IMPORTANT Phone Version... WITH VERSION OF YOUR PHONE XXXXXXXXXXXXXXXXX 5 IF U DO NOT SEE PHONE VERSION MEANS MUST TRY AGAIN. IF YOU SEE REPLY WITH PHONE MODEL THEN CONTINUE. 6 TICK ON EMERGENCY MODE. 7 CLICK ON UNLOCK. IT ASK YOU PCB TYPE OF PHONE VERSION CAREFULLY SELECT CORRECT ONE ELSE PHONE BECOME DEAD FULLY. |
After unlocking zte phone show ftm mode why? how to repair ftm mode?. 1 fill meid to zte combo unlocker meid tab. 2 click on calculate. 3 press repair meid button. how to repair only e s n?. 1 fill "e s n" at zte combo unlocker e s n tab. 2 tick on skip meid. 3 click on calculate 4 click on repair meid button. PHONE SHOULD BE WITHOUT CARD INSERTED. THERE SHOULD BE NO CARD IN IT. |
Step to repair Corby cdma family http://tech2.in.com/media/images/200...corby-cdma.jpg 1 use usb cable only. 2 use code to set diag over usb u can use code *#123580# to get test menu and type 100 press ok diag will set it show you SIO TO DM. 3 use combo multi select modem port click on safe rebuild once you see phone date and phone version in software then you have did all step correct phone rebuild started. 4 after rebuild finish phone show card disable on screen you have to open hidden shortcut which at left side top which have engineering menu 5 in engineering menu you find factory defaults again use this. 6 your phone restart, unlocked and working. enjoy world first :D |
problem samsung dm not set... Error what to do. solution. solution a: to unlock samsung phone via hkf mode you must have uart1(rj45 cable). In phone also hkf should set to uart1 . How to verify that? For new phones b119 b309 b319 b619 you can use this code. 47*869#123580 find option "portamp" go in it find option "hkf" go in it set uart1 even if its selected to none select uart1 and save or ok it. Now back to main screen do not need to restarting phone. Unlock set now in combo . If you still face same error then go to solution b. solution b: power off your phone. Press unlock in combo. Please be ready to power on once you get message at combo. Quote:
use safe rebuild via usb cable modem port. Happy unlocking. |
HOW TO UNLOCK MICROMAX C111? SOLUTION USE V3 USB CABLE. DOWNLOAD DRIVER FROM SUPPORT AREA micromax usb driverxx.rar select diag port in combo multi unlocker v39 or new select model MX C111 go to MX tab press unlock in 30 to 35 sec unlocking will be done log will be saved to c:\advance cdma\logs\ |
How to unlock c2076 not found phone? How to unlock haier c2076 not found(diag disable)? SOLUTION. Open Combo Multi. Select model. Remove battery and usb cable from phone. Press and hold green calling button and insert usb cable, no need battery. Select diag port. Go to haier tab. Tick on boot. Press unlock. C2076 MV03 "D" "E" "F" ALL PCB TYPE SUPPORTED. IF YOU HAVE UNSUPPORTED FIRMWARE THEN CONTACT US WE READ PHONE VIA TEAM VIEWER AND SUPPORT IT. |
How to write scr Click On Show Scr Button. Now You Can See Full Scr Menu Option. Click On Select SCR Folder. We Have Added Scr_Folder Near To Advance Cdma\SCR_FOLDER . You Can Select This Or Your Own From Original Folder. If You Are Selecting From Our Folder Select Model With Version. If You Are Selecting From Original Flash File Select EFS_SCR Folder. Connect Phone Via Usb. Select Port Model And Click On Write SCR. Once Its Finish Phone Will Be Restarted. |
How to update rf part.... If You Face Any Network Problem Etc Connect Phone Via Usb. Select SCR Folder For Your Phone And Version. Tick On Update Rf Click On Write SCR In Few Sec Phone Will Be Restart And Network Will Be Ready... |
