03-14-2010, 12:21 | #1 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 222412 Status: Offline Thanks Meter: 9 | Rj45 0r dcu-60 Unlock Via Service Cable Connection (BOX AND RJ45 CABLES) or (FIGHTER CABLE) or (TOTAL MULTI-SERVER CABLE)
spitroast |
The Following User Says Thank You to spit roast For This Useful Post: |
03-14-2010, 12:43 | #2 (permalink) |
Member: 222412 Status: Offline Thanks Meter: 9 | Cleared up...Box and a cable pack is needed to connect DB2000, DB2101x, DB2020 phones to PC to unlock them, it will work with se tool box and cruiser box spitroast |
08-04-2010, 16:25 | #8 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,439 | better to use uart(ftdi) k750 for older models and dcu-65 for A2 (it is required) or db2020 for the w810i use k750 (ftdi) cable Best regards, Aishur |
The Following User Says Thank You to :Aishur: For This Useful Post: |
08-04-2010, 16:59 | #9 (permalink) |
Freak Poster Join Date: Aug 2008 Location: Santiago de Cuba, CUBA
Member: 836938 Status: Offline Thanks Meter: 18 | I have the Cable SE K750i. In the Devices Manager of appears like UC-10 USB Composite Device. Is this correct? It is this the k750 (ftdi) cable that you mention? SonyEricsson A1 mode Supported interfaces / chipsets: Service cable: DB2000, DB2010, DB2012, DB2020 USB cable: DB2020 Supported models: DB2000: K600, K608, V600, V800, W900, Z800, Z1010 DB201X: J300, F500, K310, K310, K320, K500, K508, K510, K700, K750, S700, W200, W300, W310, W550, W600, W700, W800, W810, Z520, Z525, Z530, Z550 DB2020: K530, K550, K610, K618, K770, K790, K800, K810, S500, T650, V630, W580, W610, W660, W710, W830, W850, W880, W888, Z610, Z710 Looking for the NEROkey...OK Using reader: USB SMART CARD READER 0 Checking for card status...OK Serial:xxxxxx Free:1000 A1:100 A2:100 Other:0 Blocked:NO Quering key slots...OK 1. KIDP96_EMP_DUMP_R1A - Free, Used:0 2. KIDP96315035 - A2, Used:0 3. KIDP96320035 - A2, Used:0 4. KIDP96321035 - A2, Used:0 5. KIDP96335035 - A2, Used:0 6. KIDP96200133 - A1, Used:0 7. KIDP96201233 - A1, Used:0 8. KIDP96202033 - A1, Used:0 9. KIDP96SUZIR2 - A1, Used:0 Power OFF the phone, connect COM cable and press POWER short Connected to COM9 Device identification... Never Identify the phone!!!! Help Thanks |
08-04-2010, 17:39 | #10 (permalink) |
Member: 836938 Status: Offline Thanks Meter: 18 | In this url the cable appears that am utilizing, I have verified that is USB FTDI, apparently the cable is correct. Cable USB FTDI SonyEricsson K750 | Sony Ericsson | Liberar, Cables Unlock, Box Liberacion, Codigos Desbloqueo por IMEI, Programas GRATIS, Abrir Bandas y Software para Desbloquear! I need indicate me the steps to free this w810i. I am new with this tool, is my first unlock. I this the following steps: 1. Putting out the telephone. 2. Withdrawing the battery. 3. Connecting the Cable SE K750i to the port USB of the PC. In the Divice Manager appears like: UC-10 USB Composite Devive CruiserTeam Universal Cable UC-10(COM9) 5. Executing Nero Team Studio 6. Click in the button START 7. Select COM 9 8. Connecting the battery 9. Connecting the Cable to the telephone 10. Power Shorts to the telephone The telephone is ON, and show the logo Charging battery. I believe that not enters the way required. I have tried with other ports COM, but not achievement swims still. It helps Thanks |
08-04-2010, 18:00 | #11 (permalink) |
Member: 1315677 Status: Offline Thanks Meter: 1,439 | check the cable or clean the connector I just tested a k750 and it should work for you Code: Looking for the NEROkey...OK Using reader: USB SMART CARD READER 0 Checking for card status...OK Power OFF the phone, connect COM cable and press POWER short Connected to COM15 Device identification...OK Sending Preloader...OK Starting GDFS service...OK Chip:DB2010 Model:W800i IMEI:35655300728510 CID:36 Domain:BROWN OTP LOCKED:1 CID:36 PAF:1 Uploading logic DB2010: Shutting down device...OK Selected current certificate: A1_DB2010_36_BROWN Power OFF the phone, connect COM cable and press POWER short Connected to COM15 Device identification...OK Uploading logic DB2010: Sending ResetLoader...OK Authenticating with key KIDP96201233...OK Reseting to factory defaults...OK Shutting down device...OK Power OFF the phone, connect COM cable and press POWER short Connected to COM15 Device identification...OK Uploading logic DB2010: Sending ProductionLoader...OK Writing EROM...OK Recompiling security area...OK Changing certificate to A1_DB2010_36_BROWN...OK Shutting down device...OK FINISHED [22sec] please try the below modified steps 1. Putting out the telephone. 2. Withdrawing the battery. 3. Connecting the Cable SE K750i to the port USB of the PC. In the Divice Manager appears like: UC-10 USB Composite Devive CruiserTeam Universal Cable UC-10(COM9) 5. Executing Nero Team Studio 6. Select COM 9 7. Click in the button START 8. Connecting the Cable to the telephone 9. Connecting the battery (push it) 10. Power Shorts to the telephone Best Regards |
W380 can not connect with rj45 and dcu-60. | nabhan9 | Sony Ericsson Hardware Repair | 0 | 04-20-2009 00:43 |
W380 can not connect with rj45 and dcu-60 | jiang0736 | Sony Ericsson Hardware Repair | 2 | 09-25-2008 04:04 |
Dcu-60 Dcu-65 | Taykelvin | Cruiser Suite | 0 | 03-28-2008 08:20 |
dcu-60 or dcu-65 | bubbles69 | SETool2 | 0 | 11-21-2007 18:43 |
