help me k608i i can't unlocke k608i with nero key her is log for nero-key Supported interfaces / chipsets: Service cable: DB2000, DB2010, DB2012, DB2020 USB cable: DB2020 Supported models: DB2000: K600, K608, V600, V800, W900, Z800, Z1010 DB201X: J300, F500, K310, K310, K320, K500, K508, K510, K700, K750, S700, W200, W300, W310, W550, W600, W700, W800, W810, Z520, Z525, Z530, Z550 DB2020: K530, K550, K610, K618, K770, K790, K800, K810, S500, T650, V630, W580, W610, W660, W710, W830, W850, W880, W888, Z610, Z710 Looking for the NEROkey...OK Using reader: USB CCID SMART CARD READER 0 Checking for card status...OK Serial:132F009496B9 Free:1000 A1:98 A2:100 Other:0 Blocked:NO Quering key slots...OK 1. KIDP96_EMP_DUMP_R1A - Free, Used:0 2. KIDP96315035 - A2, Used:0 3. KIDP96320035 - A2, Used:0 4. KIDP96321035 - A2, Used:0 5. KIDP96335035 - A2, Used:0 6. KIDP96200133 - A1, Used:2 7. KIDP96201233 - A1, Used:0 8. KIDP96202033 - A1, Used:0 9. KIDP96SUZIR2 - A1, Used:0 Power OFF the phone, connect COM cable and press POWER short Connected to COM1 Device identification... Aborted by user Looking for the NEROkey...OK Using reader: USB CCID SMART CARD READER 0 Checking for card status...OK Serial:132F009496B9 Free:1000 A1:98 A2:100 Other:0 Blocked:NO Quering key slots...OK 1. KIDP96_EMP_DUMP_R1A - Free, Used:0 2. KIDP96315035 - A2, Used:0 3. KIDP96320035 - A2, Used:0 4. KIDP96321035 - A2, Used:0 5. KIDP96335035 - A2, Used:0 6. KIDP96200133 - A1, Used:2 7. KIDP96201233 - A1, Used:0 8. KIDP96202033 - A1, Used:0 9. KIDP96SUZIR2 - A1, Used:0 Power OFF the phone, connect COM cable and press POWER short Connected to COM4 Device identification...OK Sending Preloader...OK Starting GDFS service...OK Chip:DB2000 Model:K608i IMEI:35684200173376 CID:49 Domain:BROWN OTP LOCKED:1 CID:49 PAF:1 Uploading logic DB2000: Shutting down device...OK Selected current certificate: A1_DB2000_49_BROWN Power OFF the phone, connect COM cable and press POWER short Connected to COM4 Device identification...OK Uploading logic DB2000: Sending ResetLoader...OK Authenticating with key KIDP96200133...OK Serial:132F009496B9 Free:1000 A1:97 A2:100 Other:0 Blocked:NO Reseting to factory defaults...OK Shutting down device...OK Power OFF the phone, connect COM cable and press POWER short Connected to COM4 Device identification...OK Uploading logic DB2000: Sending ProductionLoader...OK Writing EROM...OK Recompiling security area... Error unlocking security: Simlock sign error, code: 0x03 |
Just use nerokey1e and all will work ok. |
