Help whith K700 Hello friends, trying to free this model gave me this error: SonyEricsson A1 mode Supported interfaces / chipsets: Service cable: DB2000, DB2010, DB2012, DB2020 USB cable: DB2020 Supported models: DB2000: K600, K608, V600, V800, W900, Z800, Z1010 DB201X: J300, F500, K310, K310, K320, K500, K508, K510, K700, K750, S700, W200, W300, W310, W550, W600, W700, W800, W810, Z520, Z525, Z530, Z550 DB2020: K530, K550, K610, K618, K770, K790, K800, K810, S500, T650, V630, W580, W610, W660, W710, W830, W850, W880, W888, Z610, Z710 Looking for the NEROkey...OK Using reader: USB SMART CARD READER 0 Checking for card status...OK Serial:xxxxxxxxxxxxxxxx Free:999 A1:93 A2:99 Other:0 Blocked:NO Quering key slots...OK 1. KIDP96_EMP_DUMP_R1A - Free, Used:1 2. KIDP96315035 - A2, Used:1 3. KIDP96320035 - A2, Used:0 4. KIDP96321035 - A2, Used:0 5. KIDP96335035 - A2, Used:0 6. KIDP96200133 - A1, Used:0 7. KIDP96201233 - A1, Used:2 8. KIDP96202033 - A1, Used:5 9. KIDP96SUZIR2 - A1, Used:0 Power OFF the phone, connect COM cable and press POWER short Connected to COM7 Device identification...OK Sending Preloader...OK Starting GDFS service... Identification failed: Failed to start GDFS service, code: 0x04 Chip:DB2010 Model:A1 IMEI:35401000xxxxxx CID:49 Domain:BROWN OTP LOCKED:1 CID:29 PAF:1 Uploading logic DB2010: Shutting down device...OK Certificate selected by user: A1_DB2010_49_BROWN Power OFF the phone, connect COM cable and press POWER short Connected to COM7 Device identification...OK Uploading logic DB2010: Sending ResetLoader...OK Authenticating with key KIDP96201233...OK Serial:xxxxxxxxxxxxxx Free:999 A1:92 A2:99 Other:0 Blocked:NO Reseting to factory defaults...OK Shutting down device...OK Power OFF the phone, connect COM cable and press POWER short Connected to COM7 Device identification...OK Uploading logic DB2010: Sending ProductionLoader...OK Writing EROM...OK Recompiling security area... Error unlocking security: Failed to start GDFS service, code: 0x04 Now the phone I remain itself dull and does not light. That is this error and as I can fix it???. Thanks to all |
Use R1E version. And You have to flash firmware before or after unlock. Seems GDFS config missing |
