Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > NEROkey
Old 05-11-2011, 15:55   #1 (permalink)
Member: 713641
Thanks Meter: 5
W580i DEAD [SOLVED]
Bonjour
i have try to unlcok se w580i with nero key and since the 3 phone are dead
Old 05-11-2011, 15:57   #2 (permalink)
Member: 713641
Thanks Meter: 5
Thumbs down W580i DEAD
BJR
I TRY TO UNLOCK 3 W580i WITH NERO KEY AND 3 PHONE A RE DEAD AND IMPOSSIBLE TO FLASH IT... SAME ERROR TO UNLOCK OR FLASH...
Selected current certificate: A1_DB2020_49_BROWN
Power OFF the phone, connect USB cable holding '2-5'
Connected to USB1
Device identification...OK
Uploading logic DB2020:
Sending ResetLoader...OK
Authenticating with key KIDP96202033...OK
Serial:132F00949223 Free:946 A1:58 A2:48 Other:0 Blocked:NO
Reseting to factory defaults...OK
Shutting down device...OK
Shutdown command error
STOPPED [26sec]
ANY MASTER CAN HELP ME PLEASE
ALLYOUNEED IS
Old 05-11-2011, 16:35   #3 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Witch version of nerokey you use latest is 1F and working 100% correct.
If you use 1E then this is normal and was writed lots time to NOT USE THIS VERSION.
If you use 1F just in setting select "SET CERTYFICATE TO:" select ASK EVERY TIME
And when you will do unlock select RED 52. After this phone will work correct and will be unlocked too after this can fla**** problem is that now your phone got BROWN 49 certyficate and can't be flashed nothing to it.
Old 05-11-2011, 17:50   #4 (permalink)
Member: 713641
Thanks Meter: 5
Thanks
BJR
THANKS FOR HELP IS THERE ANY WAY TO REPAIR MY PHONE??
THAZNKS
ALLYOUNEEDIS
Old 05-11-2011, 20:23   #5 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Originally Posted by ALLYOUNEEDIS View Post
BJR
THAZNKS
ALLYOUNEEDIS
Man can you read I ask you question witch version you use !! !!
Witch nerokey version ?? ?? ??
Old 05-12-2011, 05:59   #6 (permalink)
Member: 713641
Thanks Meter: 5
Ok
BJR
I HAVE HAD THE PROBLEM WITH 1D BUT YESTERDAY I DOWNLOAD 1F .... AND NOW I USE 1F
SO IS THERE ANY POSSIBILITY TO REPAIR MY PHONES CAUSE COSTUMMER WANT TO TAKE THEM TODAY....
THANKS VERY MUCH
BEST REGARDS....
ALLYOU NEED IS....
PS I HAVE FORGET MY LOG AND PASS TO SUPPORT AND CONTACT NICOLY BUT NO ANSWER....
Old 05-12-2011, 08:58   #7 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
BJR
THANKS VERY MUCH
BEST REGARDS....
ALLYOU NEED IS....
I write you solution in post 3
Why you not read what I write ??
If you use 1F just in setting select "SET CERTIFICATE TO:" select ASK EVERY TIME
And when you will do unlock again (with 1F version !! !!) select RED 52.
After this phone will work correct and will be unlocked too after this can flash phone , problem is that now your phone got BROWN 49 certificate and can't be flashed and not work.
Old 05-12-2011, 10:51   #8 (permalink)
Member: 713641
Thanks Meter: 5
Work
BJR
I HAVE TRY WITH NEW PHONE OF MINE I CAN T SELECT CID52 .... AND AFTER TRYING TO UNLCO PHONE IS DEAD TOO..... THE SOFT DON T LET ME CHOOSE AN OTHER VERSION..... AND I HAVE VALIDATE select ASK EVERY TIME.....
ANY TRICK
THANKS
ALLYOUNEEDIS
Old 05-12-2011, 14:07   #9 (permalink)
Moderator
Member: 1139057
Sonork: 100.109924
Thanks Meter: 4,428
Mean you doing something wrong software work correcly I tested my self lots time check success unlocked topic.
If still you not know what to do install teamview 6 contact with me on sonork or msn or icq and give me your id and password when got time will check on your computer what you doing wrong.
Old 05-13-2011, 13:29   #10 (permalink)
Member: 13611
Sonork: 1
Thanks Meter: 368
Bonjour
Hi. PM me your unlock logs. Its in "%appdata%\NEROteam\Recovery Studio" folder.
As i can see unlock was not completed propertly. After factory reset it stops. So phone unable to boot because of missing EROM.
First u have to try to update USB drivers. Use another USB port. Seems some USB problems there.
Try also another PC to be sure problem is in your system settings.
You can also use serial (COM) cable instead of USB.
P.S. Your phones will be ok for sure. Dont worry
Old 05-17-2011, 06:05   #11 (permalink)
Member: 713641
Thanks Meter: 5
No no no
HI
I CAN T FIND LOG WHERE YOU TELL ME ONLY I CAN DO IS TO COPY FULL SCREEN OF NEROKEY....
I TRY TO INSTALL THE NERO KEY ON ANOTHER COMPUTER BUT THE DRIVERS CAN T BE INTALLATED.....
IS THERE A SOLUTION TO FULL FLASH THE W580 WITH NEROKEY OR AN OTHER SOLUTION??
THANKS
ALLYOUNEEDIS
Old 05-17-2011, 08:07   #12 (permalink)
Member: 13611
Sonork: 1
Thanks Meter: 368
You don't have to flash the phone in order to recover it. Just start Unlock again.
But YES you can flash with NEROkey if u like to (see Firmwares tab)
Old 05-17-2011, 11:00   #13 (permalink)
Member: 713641
Thanks Meter: 5
To darkman
BJR
SORRY BUT NOT WORKIN ALLWAYS .... STOPED BY SOFT
ANY TRICK
THANKS
ALLYOUNEEDIS
µ
Old 05-17-2011, 11:32   #14 (permalink)
Member: 13611
Sonork: 1
Thanks Meter: 368
Use COM cable if u have USB problems. DB2020 could be done by serial cable too.
And if u not have one. Play with your USB drivers. Remove and reinstall again by setup from our page.
Old 05-17-2011, 13:23   #15 (permalink)
Member: 713641
Thanks Meter: 5
Not good
BJR
I HAVE TRY WITH COM CABLE... AND SAME RESULT....Power OFF the phone, connect COM cable and press POWER short
Connected to COM9
Sending Preloader...OK
Starting GDFS service...
Identification failed: Failed to start GDFS service, code: 0x04
ChipB2020 Model:A1 IMEI:35651402-039307-0 CID:49 Domain:BROWN
OTP LOCKED:1 CID:51 PAF:1
Detecting flash type...OK
Chip: Intel Sibley 512 Mbit NOR
Certificate selected by user: A1_DB2020_49_BROWN
STOPPED [31sec]
OTHER SOLUTION,,,???
THANKS
ALLYOUNEEDIS
Repaired dead phone without backup Prodigal Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-29-2011 11:26
HELP Dead 5130 v5.00 N.Schmetz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 03-08-2011 04:51
help! Dead 5110 v5.30 aklishin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 04-04-2001 11:56
nokia 5110 dead alpha Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-28-2001 11:59
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) tcamilo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-19-1999 22:30
Page generated in 0.31804 seconds with 9 queries
