<<< NBA - Nokia Battery Adapter - 9 usd / 10 pcs - FIRST IN THE WORLD AGAIN >>> NBA - Nokia Battery Adapter powered by UFC3GS in collaboration with MXKEY Team http://i782.photobucket.com/albums/y...g?t=1277758823 The NBA it's a revolution in itself: Small, Smart, Cheap, Usefull, Solid, Strong, Compatible, everythink you can wish for. http://i782.photobucket.com/albums/y...g?t=1277757295 Features: - powerful catch, stronger than usual battery connectors - you will be finally able to rest assure that your phone will finish flashing without unwanted interruptions - simple to use, just connect it inside your mobile phone as shown in the pictures - small yet big enough to use your hand to attach or remove - compatible with over 71 Nokia phone models and more than 10 battery types - compatible with all crocodile style connectors used by most of GSM product manufacturers - durable, make from quality materials - high quality gold plated connector pins - special designed connector with quality ABS plastic - solder wires to it and you can forget about problems - double sided PCB http://i782.photobucket.com/albums/y...g?t=1277757300 Built using: - high quality smart design PCB - custom made gold plated PINS - custom made special connector plastic with special shape to fit all Nokia phone that use this style of connectors - 3 double sided holes to fit any crocodile type connector - large metal pads to easy solder your custom power cable directly to it http://i782.photobucket.com/albums/y...g?t=1277757969 NBA - Nokia Battery Adapter works with any Nokia mobile phones that uses this type of battery conector. http://i782.photobucket.com/albums/y...g?t=1277757943 http://i782.photobucket.com/albums/y...g?t=1277757945 NBA - Nokia Battery Adapter There are many ways you can use the NBA. Here is just a few of them. http://i782.photobucket.com/albums/y...g?t=1277757288 BR, Manole . |
thanks manole pls do something for sl3 unlock expecting from you soon |
really extra ordinaire nthank you so much |
yes max key is the best ;) |
Yes, goooooooooooood work |
Good Working Nice Adapter's.................... |
really they have goood thinking thanx mr manole greeeeet |
tkz for the idea. b.r. SEBAELPOTRO! |
@MANOLE nice improvement on nokia technology again froM Pecious MX KEY TEAM,as is the best supportd tool ever:D |
Yes that idea is very good, sometimes during the flashing operation the power supplies slip out on connector. Well done! |
We proof one more time we always come into market with innovative and ingenious ideas. I have done some more images, hope will help all peoples with all types of UFC from all producers (UFC, GPGUFC, UFCv2, UFC4 and UFC3GS) to understand they really need this, even if is cheap product, is need it in all service centers around the world. On the left side you can see normal connection to a Nokia 7310c where the crocodile connectors are easy to slip out and fails to flash the phone, can even kill the phone is flashing is interrupted in this way. On the right side a wired NBA (Nokia Batter Adapter) does the job perfectly ! http://i782.photobucket.com/albums/y...g?t=1277766144 On the left side you can see normal connection to a Nokia 3600s where the crocodile connectors are easy to slip out and fails to flash the phone, can even kill the phone is flashing is interrupted in this way. On the right side NBA (Nokia Batter Adapter) + Normal UFC3GS Style crocodiles does perfect job ! http://i782.photobucket.com/albums/y...g?t=1277766143 BR, Manole |
[IMG]http://www.**********.com/000/ALL%20PHOTO%20OF%20BOXES/thanks/1.jpg[/IMG] |
thanks mx key team all with your big update sl3 unlock |
Advice: Output and 3 bronze ring, prevent oxidation resistance of the original |
