Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 07-25-2017, 18:17   #1 (permalink)
Member: 2092009
Thanks Meter: 30
Exclamation iphone 6s full Short help
hello friends
i got a 6s which was in charge and dead it was full short the battery connector +and- so brought power supplay voltage to 1.5 volt and checked that q2300 heating so take out that and now the short gone but when power on nothing happens phone dont take voltage also the capistors near u2300 is short both side is ground i take out most of them like c2330 c2301 and all thos which was short but still short even i take out u2300 ic and u3700 ic but still short anyone can help me
now main problum PP_VCC_MAIN short
The Following User Says Thank You to gulzaib07 For This Useful Post:
Old 07-25-2017, 18:33   #2 (permalink)
Member: 2092009
Thanks Meter: 30
need advice plz i have to remove which ic to solve PP_VCC_MAIN short
Old 07-26-2017, 02:25   #3 (permalink)
Member: 1695545
Thanks Meter: 2
hi friend check capasitor c1552, c1597 and c5202_rf may be it shot
The Following User Says Thank You to piston33 For This Useful Post:
Old 07-26-2017, 08:11   #4 (permalink)
Member: 1929960
Thanks Meter: 27
Q2300 is not shorted, it passes current from vbatt to vcc_main and when there is a short on vcc_main, it heats up due to current overload.
what you need to do is bypass Q2300 by jumping from C2333 to C2303.
This will then allow a lot of current to bypass Q2300 and all that power will heat up the real short on VCC_main and make it easier to find.
The Following 3 Users Say Thank You to warboat For This Useful Post:
Old 07-26-2017, 11:47   #5 (permalink)
Member: 2092009
Thanks Meter: 30
thanks aloot warboat....you such a genius guy
Old 08-19-2017, 12:29   #6 (permalink)
Member: 985157
Thanks Meter: 3
Hi,
I have same problem , ip6s shorted q2300 gets heat, Can u pls clearly explain how to bypass q2300 by jumping c2333 and c2303 ? or removing q2300 injecting voltage point ?
Thanks
Old 11-04-2017, 13:36   #7 (permalink)
it-repair's Avatar
Member: 1442842
Thanks Meter: 103
Hi!
this solution is good on IPHONE 6 , but not on iPhone 6S and 6Splus !!!
Old 11-05-2017, 13:14   #8 (permalink)
ninos22's Avatar
Member: 1903358
Thanks Meter: 146
Originally Posted by gulzaib07 View Post
hello friends
Any heat on U2000? (PMIC)
The Following User Says Thank You to ninos22 For This Useful Post:
Old 02-18-2018, 18:02   #9 (permalink)
Member: 2092009
Thanks Meter: 30
no there is no heat on power ic
Old 03-24-2019, 10:01   #10 (permalink)
Member: 2697305
Shorted iPhone 6s and 6s plus
I realized after the jumping of c2300 and c2303, the pmic becomes hot. I think it's wasted and has to be changed or it's just a diversion?
Page generated in 0.17801 seconds with 8 queries
