11-10-2014, 17:22 | #33 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Galway, Ireland
Member: 1508411 Status: Offline Thanks Meter: 36 | I got a blue screen after a screen swap recently and having looked here was sick to think I had damaged that screw hole. I am very careful so couldn't believe I had put the wrong screw in. So instead I disconnected the battery and reconnected it and all worked fine again. The moral of the story is, disconnect and reconnect the battery first. |
11-13-2014, 09:14 | #34 (permalink) |
No Life Poster Join Date: Oct 2008 Location: dubai
Member: 884639 Status: Offline Sonork: 100.1597105 Thanks Meter: 266 | i have solved one phone today by replacing U2 (i got error 40 and 4013 in software ) when it kept in preheat for 5 minute it ON with blue screen restart, then i changed the U2 and it work for me |
11-28-2014, 15:37 | #36 (permalink) | |
Junior Member Join Date: Apr 2006
Member: 254518 Status: Offline Thanks Meter: 3 | Quote:
Bought a microscope from aliexpress(10x, 20x, 30x), and after many hours of with scratching and rubbing with fine sandpaper (grain 600-800) I could finally solder the tracks together again. Not easy work, but tested contuinity with multimeter, and the phone also startet up as it should straight away. Seems like I cant upload pictures on this forum yet... | |
12-04-2014, 14:24 | #39 (permalink) |
No Life Poster Join Date: Jan 2005 Location: On Roads... Age: 43
Member: 107839 Status: Offline Sonork: 100.1592822 Thanks Meter: 70 | First chk insert bsi if damaged - if not than blue screen is coused by U2 ic. insert fix example attached b.r |
The Following User Says Thank You to GSM Road Runner For This Useful Post: |
12-05-2014, 09:08 | #40 (permalink) |
Freak Poster Join Date: Mar 2005 Location: geva carmel,israel Age: 49
Member: 124909 Status: Offline Thanks Meter: 9 | camera i did 3 phone solusion work 100% but camera is not working any solusion? |
The Following User Says Thank You to noamlab For This Useful Post: |
12-07-2014, 00:27 | #41 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Brazil Age: 41
Member: 131402 Status: Offline Thanks Meter: 20 | can someone tell me if between these tracks spend some responsible for the camera? I already managed to solve the problem of blue screen, but the camera only works for videos and crashes if you try to take pictures |
