01-19-2011, 19:04 | #1 (permalink) |
Freak Poster Join Date: Dec 2010
Member: 1481974 Status: Offline Thanks Meter: 42 | 3gs home button not working - logic board problem It seems that the voice control comes on when I first turn on the phone but then the home button does not work at all. Seems common problem with water damage which this phone does have. I looked around but couldn't find any solutions. Any ideas? |
06-10-2011, 12:07 | #3 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 809882 Status: Offline Thanks Meter: 19 | I have fixed this fault there was a damage to a capacitor near the dock connector which was shorting causing the home button to stay on and makes voice control comes on too.i just removed it and it is now working. |
06-11-2011, 01:56 | #4 (permalink) | |
Freak Poster Join Date: Oct 2007 Location: Phillipines
Member: 614098 Status: Offline Thanks Meter: 192 | Quote:
I have a same problem too.. Please.. Sorry for my bad english... | |
06-14-2011, 15:56 | #6 (permalink) |
Freak Poster Join Date: Feb 2011 Location: Galway, Ireland
Member: 1508411 Status: Offline Thanks Meter: 36 | I ahve had this issue a few times. Always after water damage. The phone boots up and immediately activates the voice memo. The home button does not work also. FIX remove the board from the phone and remove the shields. Now clean well with Isopropyl Alcohol taking care around the back side of the board near the wifi chip and all exposed back area. Dry well and reassemble. Works every time. Also fixes the home button issue. good luck. |
06-14-2011, 18:27 | #7 (permalink) |
Member: 809882 Status: Offline Thanks Meter: 19 | Yes I cleaned the motherboard with isopropyl alcohol as I do will all my repairs to water damaged iPhones. But in this case it the capacitor was shorting so I removed it and it is working 100% now. Anyway you sometimes need to pin point the fault rather than use isopropyl and have the fault come back again. |
07-07-2011, 23:47 | #9 (permalink) |
Member: 1481974 Status: Offline Thanks Meter: 42 | I tried raptor3 solution but it made no difference. What I did to get this issue resolved was peel off that silver tape on the back of the logic board and then putting some flux on the dot for the home button (shown on raptor3 picture) a tiny bit of lead and that seems to fix the issue. make sure that there is a small gap where you see the circle (you can't have extra lead or else you'd have the same result. |
08-22-2012, 21:09 | #11 (permalink) |
Junior Member Join Date: Sep 2011
Member: 1648149 Status: Offline Thanks Meter: 2 | Great tip! Thanks for the help!!! My board was booting up with the voice control at startup and the home button was not working. I cleaned the circumference around small circle pictured, (note: no perceptible corrosion to the bare eye, only under magnification did I see a small, small bit) After cleaning it worked great and saved a lot of time trying to figure it out! Thanks for the great post and easy to understand picture! |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
