05-26-2013, 10:21 | #1 (permalink) |
Junior Member Join Date: May 2013
Member: 1946602 Status: Offline Thanks Meter: 0 | iPhone 5 Headphone Jack not working 1. Took apart and checked/cleaned connections, all good. 2. Replaced headphone jack assembly with a brand new part, no change. 3. Replaced headphone jack assembly with a known working part from another phone, however, the "non-working" jack works in that other phone. 4. Re-cleaned connection areas, no change. 5. Swapped to a new frame, no change. 6. Booted iPhone into safe mode, no change. Everything else on the assembly (home button, speaker, lightning connector) works perfectly fine aside from the headphone jack. So it's obviously something to do with the board. Just wanted to ask if anyone had any ideas before I tried restoring (which I REALLY don't want to do) or throwing back into the original frame going to an apple store to try and get it replaced. I'm also heavily jailbroken so I thought it could be one of the tweaks (hence the booting into safe mode) but that didn't change anything. It is a 64gb iPhone 5 on iOS 6.1 jailbroken with evasi0n. There is NO water damage either. Everything else on the phone works perfect but I use my headphones a lot so I would like to get it fixed as soon as possible. If you need a list of tweaks installed I can provide one. Any help is appreciated. Thanks! |
10-11-2013, 07:12 | #4 (permalink) |
No Life Poster Join Date: Mar 2003 Location: USA
Member: 23534 Status: Offline Thanks Meter: 17 | hello, Would any one give me the iphone 5 schimatics ? i have the same problem i cant find the solution: the headphoen jack dont output the audio sound to the headphones! when connecting the headphone jack not thing hapend (if the music was played it continue playing even i plug and unplug the headphone) i changed the audio&changing flex, clean the board, no thing work. maybe someone have the solution would share it with us?? thanks |
03-20-2014, 18:14 | #6 (permalink) | |
Junior Member Join Date: Jan 2014
Member: 2112917 Status: Offline Thanks Meter: 0 | Quote:
i cant post links so.. mediafire. com/download/t0tzn1qnsf63qad/iPhone5_schematic. rar in my case R107 is missing, do you know if the resistors size is 402? thanks | |
06-19-2015, 12:20 | #9 (permalink) |
Insane Poster Join Date: Oct 2011
Member: 1670865 Status: Offline Thanks Meter: 2 | http://forum.gsmhosting.com/vbb/f631...ution-1730749/ check this thread |
