Error -1 ( A4 and A5 ) Devices ... hello i want to share some information about error -1 :- i faced this problem in some sets of iphone 3gs , 4g , 4s , 5 and this error was both hw and software problem but u have to try these steps 1st Software error solution :- ( A4 ) Devices 1- change cable and usb port ( some times if the baseband is hang or need to be refreshed this will help ) 2- restore iphone direct from itunes without selecting firmware from pc . 3- open tiny or redsnow and use fix recovery . 4- restore custom firmware . ( A5 ) Devices 1- change cable and usb port ( some times if the baseband is hang or needs to be re flashed this will help ) 2- restore iphone direct from itunes without selecting firmware from pc . 3- put in dfu mode and remove battery for some hours not less than 5hours and then restore . hardware solutions : ( A4 - A5 ) Devices 1- change battery ( some times if the battery not stable in charging ) 2- clean the board and check the battery connector . 3- reheat baseband and if necessary reball the baseband Your problem will be solve , i wish this may help u solve ur problem |
In all cases error is Baseband related, so with small brain steps are easy to discover ... |
There a good news is that glue in iPhones is easy to remove, so repairs are possibe |
Do we have to reball or change the basband IC ? |
i think so,In all cases error is Baseband related, so with small brain steps are easy to discover http://www.oksky.us/imiss/images/5.gif |
anyone have a pict ic baseband ipad 1st gen ?? . |
for who have 4s with itunes -1 error you can just simply restore with redsnow 0.9.15b3 select 6.1.3 firmware ;) |
Baseband error bro... |
thans bro dear bro ur information is usefull. A lot of thanks. I have a iphone 4g it just keep searching then no service pls help me for this thanks |
I have the same error |
