10-29-2012, 22:25 | #1 (permalink) |
Freak Poster Join Date: Jul 2008
Member: 809882 Status: Offline Thanks Meter: 19 | iphone 4 front camera not working HELP!!! And i have check all the volts that Mr Wites had put on his solutions page and all check ok Is there anything else i can try? Thanks. Last edited by raptor3; 10-29-2012 at 22:32. |
10-29-2012, 23:00 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,595 | Did you try to restore or other camera,did you try to jumper filters as in picture? |
The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
10-30-2012, 13:52 | #3 (permalink) |
Member: 809882 Status: Offline Thanks Meter: 19 | Thanks for you reply Wites Yes i have checked all the filters and they all beep with tester and done a restore with new camera were the volts say 2.85v on your picture mine say 2.86v |
10-30-2012, 15:00 | #4 (permalink) |
Member: 1017374 Status: Offline Thanks Meter: 2,595 | Friend a filter can beep on my multimeter up to 33ohm check each if it have not more than 00.6ohm if show more than replace or jump,8 leg filter i jump always i not trust to this components. |
10-30-2012, 15:45 | #5 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Wikon, Switzerland
Member: 1012778 Status: Offline Thanks Meter: 245 | - unplug the front camera and check all voltages direct at the connector when you have camera-app open! - check L8 for bad solderings / shorts - try another camera (that you be 101% sure that it works) remember: You have to kill the camera.app in the task-list and completely restart the phone before you try again!!! |
The Following User Says Thank You to kostelectronics For This Useful Post: |
10-30-2012, 21:48 | #6 (permalink) |
Member: 809882 Status: Offline Thanks Meter: 19 | Right i have checked all with multimeter and all reading 00.0ohm even jumped the 8 leg filter and checked the voltages at connector all voltages are there ok and tried 3 new camera on it but still the same shutter wont open? |
10-30-2012, 21:58 | #7 (permalink) | |
Member: 1017374 Status: Offline Thanks Meter: 2,595 | Quote:
This is to see if some line is not broken. | |
