Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 06-30-2020, 07:04   #1 (permalink)
Member: 1027544
Thanks Meter: 12
i need help ipad air 2
ipad air 2 waiting error 4005
after change sr bl and wifi with jc pro no removal tool
restore not working error 4005
i have backup from old sr bl and wifi the same problem error 4005
ipad air 2 A1566
3utools error : unable to switch dfu mode to recovery mode
Old 06-30-2020, 17:36   #2 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 859
3 cases with faulty possibilty :
- bad nand solder
- overheating sdram / ram
- faulty nand
Old 07-01-2020, 08:54   #3 (permalink)
Member: 1027544
Thanks Meter: 12
hi
sr is changed with no removal tool
nand flash not removed
Old 07-01-2020, 09:16   #4 (permalink)
orx
orx's Avatar
Member: 1825965
Thanks Meter: 859
hi
yes sorry my mistake , maybe more affordable job is to remove nand and to program it with read and write socket .
good luck
Old 09-10-2020, 23:35   #5 (permalink)
Member: 2257452
Thanks Meter: 16
My jc no removal tool can not detect it in dfu mode
Old 09-11-2020, 02:30   #6 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 930
No removal tool detect only nand ic....its not related to dfu mode...
For remove icloud dont touc any think
Deselect all and change just sn wm bt
Old 09-11-2020, 20:44   #7 (permalink)
Member: 2796406
3utools in itunes mode
You can see a more precise log and where it fails if you use the itunes flash within 3utools(not easy flash)
i have an ipad with same error and it stops on 21% when it tries to load micro os system from the ram(18% when using easy flash)
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.13837 seconds with 7 queries
