Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 01-08-2018, 14:39   #46 (permalink)
Member: 2790571
Thanks Meter: 6
Can you inquire???????
Old 02-06-2018, 14:27   #47 (permalink)
Member: 604050
Originally Posted by agonya View Post
hey guys, we here in three days have solved one, "itunes 9" and two, "itunes 4013" error, and we could update without any activation errors. The model of iPhone's were two iPhone 6 and one iPhone 5s. First of all we encountered with activation problem. Interestingly we changed old NAND with used NANDs which were removed from other devices. And also brand of NANDs were different, for example we changed Skhynix with a Toshiba NAND. Surely we reprogrammed NANDs with the original S/N, Wifi and Bluetooth Address, Board Number, Color, Model, etc, etc. Briefly ios 11 didn't make any trouble for us.
what box you use to reprogram the nandflash?
Old 02-06-2018, 14:44   #48 (permalink)
Member: 604050
You are absolutely right my friend, yesterday we got one more experience. We forgot to change "Board Number" with the original one and when we tried to restore the iPhone we encountered with "Activation Problem". The necessary information that are needed to pass activation are;
Serial Number, Model, Area, Wifi and Bluetooth Adresses, Colour, Submodel and Board Number. All of these should be original.
And especially Serial Number, Wifi and Bluetooth Adresses, and Board Number are really important.
what box do you use to reprogram the nandflash and where can i find the original board serial number?
Old 02-11-2018, 14:58   #49 (permalink)
Member: 2467245
Hi,
I have iPhone with death nand, where I can find board number. Other information I bought from GSX (Wifi, BT etc), but this number I cant find.
Thanks for help
Old 02-13-2018, 09:30   #50 (permalink)
Member: 2805977
Originally Posted by venom230 View Post
Hi,
Thanks for help
Тhe board number is on the top of the sim card metal plate on the board. It's written in two lines but you have to write it together.
The Following User Says Thank You to Dian_ For This Useful Post:
Old 02-16-2018, 17:09   #51 (permalink)
Member: 2292360
Thanks Meter: 3
U Need To PAy IT To get Those information GSX service, there so many service WIFI BT adress in this forus use search bar
Old 02-18-2018, 15:55   #52 (permalink)
Member: 2812715
Thanks Meter: 2
confirm IOS 11 has failed on activation .
Old 02-18-2018, 17:54   #53 (permalink)
Cheater -Don't Deal with him-
Member: 1728299
Thanks Meter: 7
Originally Posted by PRO-mobile View Post
All devices on which there was a manipulation with memory, those are not activated on iOS11, even if I completely clone the old memory Has anyone solved this problem?
iphone errors solution
Old 03-22-2018, 20:39   #54 (permalink)
Member: 2731466
Thanks Meter: 4
still having activation fail even if i clone the old nandor just restore with the backup boot files, im using ipbox v2. Someone have done error 4013 successful with ipbox?
Old 06-07-2018, 13:07   #55 (permalink)
Member: 491655
Originally Posted by i was darling View Post
original wifi bt serial put then restore
wifi address Bluetooth address contact me
Hello, I need to consult 2 iphones, I need Mac bluetooth and Mac wifi
Old 08-21-2018, 09:46   #56 (permalink)
Member: 1388158
Thanks Meter: 30
Activation problem
NAND memory is poorly programmed data. Must be s / n and the corresponding mac Wi-Fi address and logicboard number. Bluetooth address you need iP box to count itself, but if you know the Wi-Fi mac address so bleettod address is the last character by one higher
Old 08-21-2018, 10:56   #57 (permalink)
Member: 2277735
Thanks Meter: 215
I have done 4013-14 with naviplus but others have not fixed and could be due to WiFi or other hardware issues!
Old 08-23-2018, 06:47   #58 (permalink)
Member: 1388158
Thanks Meter: 30
yes several times 4013 error corrected in iP box. error 4013 may also be a short circuit in the circuit on the logicboard.
Old 04-18-2019, 17:33   #59 (permalink)
Member: 675059
Hello everybody. Have an iphoneX that was working properly ,no icloud no issues. After I "erase all" I cant activate. Tried to restore on itunes with latest ios 12.2 still cannot activate. if I try to activate within the device it says try again. if I try on itunes, it says cannot get information, remove sim and try again. On the device I get a full signal from carrier but cannot activate. Tried 3uTools and I can see serial number,imei, mac adress, UDID, color... but still cannot activate. The device has not been modified at all. Apple support online wasnt a big help. They blamed it on my carrier (device is factoty unlocked) I appreciate any help
Old 06-25-2019, 22:25   #60 (permalink)
Member: 1622774
Sonork: 34610
Thanks Meter: 37
i got iphone 5s i lost board number how i can find it by sn or by imei ?
Page generated in 0.25162 seconds with 9 queries
