02-12-2012, 01:15 | #31 (permalink) |
Junior Member Join Date: Feb 2012
Member: 1721295 Status: Offline Thanks Meter: 0 | Having been looking everywhere for the answer to no backlight on an iPad2 after repairs, this works. It has only got every alternate LED up right now along the long edge opposite the volume control, but it is also only at 5% charge, so that might fix itself as the voltage rises (or may not, it is still immensely better than no backlight and is usable as is) Many thanks to the original Russian poster and to those passing it on. |
02-16-2012, 14:29 | #32 (permalink) |
Member: 1722875 Status: Offline Thanks Meter: 0 | hey guys.. did the russian version of this fix and it worked. tried works solution as well but it didnt work (no backlight at all like originally) however it sounds like longboatman and I have the same issue with dark spots on the LCD on the left (volume button) side of the screen. any ideas? |
02-25-2012, 23:37 | #33 (permalink) | |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | Quote:
02-26-2012, 07:47 | #34 (permalink) | |
02-26-2012, 18:38 | #35 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | [QUOTE=CyberDoctor;8181720]we are talking about using z axis double sided conductive tape to do this repair right? [/QUOTE I guess so Once removed its impossible to attach back the old tape right? Well at least that is what i believe right now. |
03-21-2012, 14:34 | #36 (permalink) |
Junior Member Join Date: Mar 2012
Member: 1737115 Status: Offline Thanks Meter: 1 | I'm having a backlight issue with my 32gb WiFi iPad 2 (EU/UK version) and I was hoping you guys could give me a few pointers. I've tried all of the fixes currently mentioned in this thread to the best of my ability and understanding. Some of the language barriers have thrown me off so I may have made some mistakes, but I'll provide information and screenshots to my own problem. This iPad 2 was working perfectly fine aside from a crack in the digitizer. A friend of mine was kind enough to replace the digitizer (for the second time) before handing it to me. Once the digitizer came off, we were left with a still fully functioning screen but a certain something did come off which concerned us - shown in the last two images. At this point I can't remember if the screen backlight was still working or not. We found a severly damaged LCD flex cable with a few pins missing on the board connection side and we decided this was the cause of the backlight issue. After replacing the cable with a new one the problem still persisted. I got hold of a iPad 1 screen which had the same issue when connected my my iPad 2 (no backlight) making me rule out the screen as the issue. We have tried the multiple jumper methods discussed in this thread and still we have no backlight. The only thing I can think of is if somehow the coil was damaged during the original digitizer process or the piece which came off during the removal was something crucial for the backlight. Could anyone provide some advice as to what I could try next? |
The Following User Says Thank You to tastynoodle For This Useful Post: |
04-19-2012, 22:21 | #37 (permalink) |
Freak Poster Join Date: Jul 2010 Location: California
Member: 1352483 Status: Offline Thanks Meter: 24 | Thanks I measured the one side of the diode to ground and got nothing. Does it need to be powered up to check? I haven't worked inside the ipads much so far. lcd's glass etc. so this is new to me. So if i have to eventually jumper it. on the lcd i just bridge the 7 pins togethor and run it to the cap. that sounds easy enough and then from the coil area to the other end of the cap thanks tinner |
06-07-2012, 05:48 | #39 (permalink) |
Member: 1352483 Status: Offline Thanks Meter: 24 | I still havn't gotten the backlight working on this ipad. I ordred a new lcd just to be sure it was good. I did find a cople bad items in front of the lcd connector on the mainboard. the didn't beep so i jumped them.... I was thinking they might be the problem right next to each other. But they aren't the problem. So i have a new ic new coil and a new lcd ive looked around the board checking all the coils etc... so I'm stumped. Any help would be appreciated. Tinner |
06-15-2012, 16:55 | #42 (permalink) |
Freak Poster Join Date: Nov 2002 Location: pondicherry, india Age: 45
Member: 17720 Status: Offline Thanks Meter: 34 | my ipad ready , after made track , changing disply & removed the battery & inserted also but not succeed but it was a simply thing , just without lighting i manged to swicth off after power on it was working fine , my two days tension solved in mins ....... |
06-17-2012, 02:26 | #43 (permalink) |
Banned Join Date: Mar 2012
Member: 1738165 Status: Offline Thanks Meter: 206 | i thought I realdy fixed this problem :p youtube video iPad 2 No Backlight and Dim Screen solution fix CyberDoctorMD.com - YouTube there is also a small filter after this chip...can also get short and results no backlight I will post a picture of the small filter location on this website in a few days when it is listed. I fixed 3 no backlight ipad 2 logicboards with this solution I havent test this solution on ipad 1 or ipad 3 but I am pretty sure so I can fix those too. |
07-17-2012, 15:46 | #44 (permalink) |
Junior Member Join Date: Jul 2012
Member: 1784124 Status: Offline Thanks Meter: 0 | Hi there. I have the same problem as Vega69. All went well with the fix but now there are consistent dark spots on the left side of the screen. i couldnt find a fix for this. Any suggestions? I had a guy solder the jumper from logic board to LCD. and also ran that 1 jumper on the connection on the LCD. any advice would be greatly appreciated |
07-18-2012, 00:00 | #45 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Moldova,Chisinau. Age: 38
Member: 1017374 Status: Offline Thanks Meter: 2,594 | Quote:
Here is right solution http://forum.gsmhosting.com/vbb/8532185-post102.html | |
The Following User Says Thank You to Wites OM Tesla For This Useful Post: |
