04-15-2015, 20:45 | #1 (permalink) |
Freak Poster Join Date: Nov 2014 Location: Germany
Member: 2289832 Status: Offline Thanks Meter: 48 | ipad 4 no power no recognise I received an ipad 4 gsm with no power no dfu mode nothing. as i connect to power supply it shows 0.05 power consuption. And stay there. nothing happens. I measured all voltage they are all ok. I dont think it is pmu. I tried reheating nand 230 c but still same. itunes no detect. Do you think i have to reball nand? What can couse this problem. |
04-21-2015, 17:44 | #5 (permalink) |
Member: 2289832 Status: Offline Thanks Meter: 48 | reballed nand but still same problem no life no recognise. all voltage ok. maybe it is cpu. device is clean everywhere no water not opened. im gonna return back to customer. |
07-27-2015, 06:06 | #8 (permalink) |
Member: 2289832 Status: Offline Thanks Meter: 48 | Hi I removed nand ic device recognised in dfu mode. I put on a nand ic from iphone 5 device recognised but error 4013. With original nand device dead nothing happens. I think it is faulty nand ic. Maybe u have other problm. |
The Following User Says Thank You to kaptanci For This Useful Post: |
07-27-2015, 09:04 | #9 (permalink) |
Freak Poster Join Date: Oct 2011
Member: 1668980 Status: Offline Thanks Meter: 35 | i heated nand ic with 350C for 30 seconds and it works, the ipad had password lock so i tried restoring but now error 14 will try and download from another source, iclarified |
07-27-2015, 20:50 | #11 (permalink) |
Member: 2289832 Status: Offline Thanks Meter: 48 | U have to reball nand to solve this. Heating is not a solution. I heated many times and customer come always back. |
07-27-2015, 23:07 | #12 (permalink) |
No Life Poster Join Date: May 2015 Location: Los Angeles
Member: 2398349 Status: Offline Thanks Meter: 62 | its either U2 ic or power ic I fixed a dead phone with replacing power ic try it maybe it works for u too!! |
The Following User Says Thank You to sasan500 For This Useful Post: |
07-28-2015, 19:32 | #14 (permalink) |
Member: 2289832 Status: Offline Thanks Meter: 48 | I not know really if it is u2 it would boot with a fully charged battery i think if it was u2. All voltage exist if i press power key so it cannot be pmu. I had 5 ipad 4 with same problm. I still have 3 the customer gave them to me. If i have time im gonna try replace both u2 and then pmu. I hope it works. Thanks for ur suggestion. |
07-28-2015, 23:47 | #15 (permalink) |
Member: 1668980 Status: Offline Thanks Meter: 35 | I tried last night to remove the nand ic but couldn't remove it too much black epoxy so left it for now, but i replaced the U2 ic and still the same, keeps freezing now waiting for ipad on itunes, so I am sure it is the nand ic i tried my best to cleaned as much black crap around the nand ic, but it still does not lift out, how much heat do you recommend? |
