Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone, iPad, iPod Hardware Repair
iPhone, iPad, iPod Hardware Repair Hardware Repair discussions for iPhone, iPod , iPad & Apple Products, help, guides.
Old 04-15-2015, 20:45   #1 (permalink)
Member: 2289832
Thanks Meter: 48
ipad 4 no power no recognise
Hi
I received an ipad 4 gsm with no power no dfu mode nothing. as i connect to power supply it shows 0.05 power consuption. And stay there. nothing happens. I measured all voltage they are all ok. I dont think it is pmu. I tried reheating nand 230 c but still same. itunes no detect. Do you think i have to reball nand? What can couse this problem.
Old 04-21-2015, 08:00   #2 (permalink)
Member: 2012593
Thanks Meter: 4
same problem. I changed U2 and still same.
Device was unopened.
Any thoughts?
Old 04-21-2015, 08:06   #3 (permalink)
Member: 1210561
same problem. thanks
Old 04-21-2015, 08:19   #4 (permalink)
Member: 2289832
Thanks Meter: 48
I removed yesterday nand ic. Today im going to reball i tell u if it works
Old 04-21-2015, 17:44   #5 (permalink)
Member: 2289832
Thanks Meter: 48
reballed nand but still same problem no life no recognise. all voltage ok. maybe it is cpu. device is clean everywhere no water not opened. im gonna return back to customer.
Old 05-02-2015, 19:57   #6 (permalink)
Member: 2289832
Thanks Meter: 48
Now another ipad 4 same problm. Nobody has any idea?
Old 07-26-2015, 14:53   #7 (permalink)
Member: 1668980
Thanks Meter: 35
Hi
did you fix this problem?, if so can you please post solution
thank you
Old 07-27-2015, 06:06   #8 (permalink)
Member: 2289832
Thanks Meter: 48
Hi
I removed nand ic device recognised in dfu mode.
I put on a nand ic from iphone 5 device recognised but error 4013.
With original nand device dead nothing happens. I think it is faulty nand ic.
Maybe u have other problm.
The Following User Says Thank You to kaptanci For This Useful Post:
Old 07-27-2015, 09:04   #9 (permalink)
Member: 1668980
Thanks Meter: 35
i heated nand ic with 350C for 30 seconds and it works, the ipad had password lock so i tried restoring but now error 14
will try and download from another source, iclarified
Old 07-27-2015, 12:23   #10 (permalink)
Member: 1668980
Thanks Meter: 35
tried a new restore now, ipad freezes during restore process
no error, has anyone have any ideas
what it might be?
Old 07-27-2015, 20:50   #11 (permalink)
Member: 2289832
Thanks Meter: 48
U have to reball nand to solve this. Heating is not a solution. I heated many times and customer come always back.
Old 07-27-2015, 23:07   #12 (permalink)
Member: 2398349
Thanks Meter: 62
its either U2 ic or power ic
I fixed a dead phone with replacing power ic
try it maybe it works for u too!!
The Following User Says Thank You to sasan500 For This Useful Post:
Old 07-28-2015, 14:12   #13 (permalink)
Member: 1668980
Thanks Meter: 35
It freezes when it is preparing ipad for restore so i think reballing nand IC is a good option for now
The Following User Says Thank You to calais250 For This Useful Post:
Old 07-28-2015, 19:32   #14 (permalink)
Member: 2289832
Thanks Meter: 48
I not know really if it is u2 it would boot with a fully charged battery i think if it was u2. All voltage exist if i press power key so it cannot be pmu. I had 5 ipad 4 with same problm. I still have 3 the customer gave them to me. If i have time im gonna try replace both u2 and then pmu. I hope it works. Thanks for ur suggestion.
Old 07-28-2015, 23:47   #15 (permalink)
Member: 1668980
Thanks Meter: 35
I tried last night to remove the nand ic but couldn't remove it too much black epoxy
so left it for now, but i replaced the U2 ic and still the same, keeps freezing now waiting for ipad on itunes, so I am sure it is the nand ic
i tried my best to cleaned as much black crap around the nand ic, but it still does not lift out, how much heat do you recommend?
Page generated in 0.19992 seconds with 9 queries
