07-07-2021, 17:32 | #1 (permalink) |
Junior Member Join Date: Jul 2014 Location: Portugal
Member: 2217208 Status: Offline Thanks Meter: 4 | iPad 4 PMIC faulty , no short Facts: - Ipad off battery plugged , connect charger and charges the battery, 1.5A, if I remove and plug charger again 0.1A and stays there and no regonition on pc - Ipad off, 4.2V at board battery conector press power to boot, no boot 107mah minimal heat around pmic Measurements with iPad Powered on ( no boot, stays at 107mah ) and NO DISPLAY and NO TOUCHSCREEN connected while testing : - PP1V8_ALWAYS : 0V never present - PP1V1_SRAM : 0.95V - PP1V0 : 1V - PP2V8_CAM : 2.85V - PP3V0_IO : 3V - PP3V0_S2R_HALL : 2.99V - PP3V0_S2R_TRISTAR : 3V - PP3V3_ACC : 0V - LDO5 : 0V - PP3V0_SENSOR : 3V - PP3V2_S2R_USBMUX: 3.2V - PP1V7_VA_VCP : 1.7 - PP3V0_GRAPE : 0V - LDO10 : 0V - PP1V1_CPU0_FET: 0.84V - PP1V1_CPU1_FET : 0.85V - PP1V1_CPUB : 0.84V - PP1V2_SOC : 1V, diode mode this line 0.14 and ohms is 122ohm line - PP1V8_S2R : 1.8V - PP1V2_S2R : 1.2V - PP3V3_OUT : 3.3V Is it normal to have PP3V0_GRAPE : 0V and PP1V8_ALWAYS : 0V and PP3V3_ACC : 0V ? As I didn't find any short is it possible to be PMIC problem? |
The Following User Says Thank You to ThaJoaoAragao For This Useful Post: |
07-08-2021, 13:08 | #2 (permalink) |
Major Poster Join Date: Feb 2018 Location: FRANCE
Member: 2816075 Status: Offline Thanks Meter: 8 | Hello, PP3V3_ACC 0V is normal if there is nothing connected to lightning port. PP1V8_ALWAYS 0V is abnormal. 1V8 ALWAYS is generated by U8100. Chech R0709 (value and connection) before changing U8100. |
The Following User Says Thank You to elecsoluces For This Useful Post: |
