IPAD 5TH GENERATION 9.7 schematic needed - A1823 I have ipad 5TH GEN 9.7 1823, I want to remove icloud on it, its WIFI AND 3G but i do not have schematic so I do not konw which resistor to remove for removing icloud. 1. Do you know which resistance to remove to remove ICLOUD? 2. Do you have schematic to remove so i can find resistor and remove icloud? Thankyou |
Regards |
Now on iOS11.x if you remove any resisters you will be stuck on itunes Activation error |
I need same schematics too. I am in same situation, I need to remove Icloud of this iPad 5th wifi+cellular. Thanks |
I was able to find a resistor in a1823 responsible for turning off the lte but after uploading the system I lost wi-fi so there is probably one more place where you need to make a bridge probably on the underside of the board |
Here is solution for A1823 -> A1822 Also need to replace wifi ic and remove PCIE and unlock wifi with a PCIE flasher. Credits to founder https://thumb.ibb.co/dfktjx/81_B85_F...61_E14_tmp.jpg |
yes, I know the resistors to remove I confirm exactly without a programmer, I do not get around, I stopped on blocked wifi |
YEs you have to remove nand. Remove wifi lock with a PCIE programmer and replace wifi ic. Restore again. |
Bump! Any news in A1822/ A1823 schematics? |
wifi replacement is required after PCIE unlock........ |
who solved the problem with gyroscope ???? |
for poknoj time of blocking it is necessary to replace Wifi ic 339S00308 ?? |
hi what do u mean by unlock wifi with a PCIE flasher. |
