03-13-2019, 09:41 | #1 (permalink) |
No Life Poster Join Date: Dec 2002 Location: nigeria
Member: 18926 Status: Offline Sonork: ndagi Thanks Meter: 52 | Ipad 9.7 short on caps near cpu i,ve attempted to remove icloud from an ipad pro 9.7 wifi model by hardware and,after reprogramming the PCIE chip and replacing , im getting error 4014 on itunes. ive reballed another PCIE chip and must have changed it 10 times between the two and still i get the same error 4014. well, frustrated i decided to examine board , using diode mode,i found these capacitors short (see attachment). i have no clue as to what track theyre on but im 100% sure theyre the culprit. ive crawled the internet for schematics for this ipad model with no success.Unfortunately its the only one i have. I need help guys, anyone with the schematics of has the ipad pro 9.7 on hand should please help with reading and maybe i can revive this thing. it still comes up as an ipad in dfu on itunes and 3u. thanks in advance. |
The Following User Says Thank You to ndagi For This Useful Post: |
03-13-2019, 11:15 | #2 (permalink) |
Member: 18926 Status: Offline Sonork: ndagi Thanks Meter: 52 | Update: Removed shields on the borders of the board and traced short to power ic! dont know how it happened i guess heat shorts circuits too. i have to order a new power ic for the ipad |
03-19-2019, 17:56 | #5 (permalink) |
Junior Member Join Date: May 2016 Location: Italy
Member: 2568440 Status: Offline Thanks Meter: 4 | Are you sure it's a short film? pp_gpu line and almost 20 ohm. Be careful that this is not short. Check out all the pitches where the nand is welded. In case you remove you have interrupted some track. The mistake you mention concerns the nand. |
03-24-2019, 13:00 | #6 (permalink) | |
Member: 18926 Status: Offline Sonork: ndagi Thanks Meter: 52 | Quote:
Regards Ndagi | |
04-29-2019, 15:47 | #7 (permalink) |
Major Poster Join Date: Jan 2019 Location: Kansas City
Member: 2891996 Status: Offline Thanks Meter: 6 | I had a PP GPU short on a iphone X. I was working on a iPhone X yesterday. I ended up totaling it because of a PP GPU short. I tried the caps first, Then the PMIC, Then finally the A11. The A11 was the source of my problem |
05-19-2019, 06:53 | #8 (permalink) |
Junior Member Join Date: Apr 2011
Member: 1564017 Status: Offline Sonork: [email protected] Thanks Meter: 1 | Schematics ipad pro 9,7 Hi, my search gives no schematics for ipad pro 9,7 until today. The only thing is board view in ZXW. Free the right for repair and share :-) Best regards buzz |
06-13-2019, 11:29 | #9 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | up for this thread..i have also semilar problem..but mine after recovery it will not connect to restore mode instead go back to dfu again.. |
